@Maker39
in the afternoon/late evening @jock and me will investigate the 8723 wifi problem.
TY for reporting 8189 working
@MFaust
by your log it seems ppptd needs something in the kernel ( ppp filter) and infact it isn't compiled
# CONFIG_PPP_FILTER is not set
 should compile a new kernel with this flag on or use openvpn that surely works
@Maker39  again...
can you compile a new kernel for MFaust  with all ppp options set on , so me and jock keep concentrate on harware problems ?
if then ppptd works we will keep it on future releases
@fabiobassaSorry, but I do not have sufficient kernel assembly and firmware skills. And on Linux, almost every command has to be searched on google. If only to find step by step instructions.
@MFaustdoes not fit on 2GB unfortunately.:(    You can try to burn on a USB stick (may work, or maybe not).
root@xt-mx4vr-v01:/home# xzcat Armbian.img.xz | dd of=/dev/mmcblk0 bs=512 skip=8192 seek=32768 status=progress
1957212160 bytes (2.0 GB, 1.8 GiB) copied, 669 s, 2.9 MB/s
dd: error writing '/dev/mmcblk0': No space left on device
3829761+0 records in
3829760+0 records out
1960837120 bytes (2.0 GB, 1.8 GiB) copied, 680.681 s, 2.9 MB/s
root@xt-mx4vr-v01:/home# xzcat Armbian_R329q.img.xz | dd of=/dev/mmcblk0 bs=512 skip=8192 seek=32768 status=progress
1956859904 bytes (2.0 GB, 1.8 GiB) copied, 672 s, 2.9 MB/s
1960837120 bytes (2.0 GB, 1.8 GiB) copied, 683.041 s, 2.9 MB/s
@Maker39
 I was understandig you knew how to compile kernels. OK no matters
@MFaust
please wait some time since we are more focused on hardware problems at the moment
You can try "openvpn " that is surely working and if you open a new 3ad I will try to support you in configuring vpn ( server or client)
so we leave this discussion for hardware related problems
About RTL8703bs ...
From LibreElec forum "TANIX TX2, DDR3, RTL8703 Wifi (unsure, if wifi will work)"
I try LibreELEC-RK322x.arm-9.2-devel-20200301144541-b58333a-rk3229-tx2.img.gz
 And IT WORK !!! :)
LibreELEC:~ # lsmod
Module                  Size  Used by
8723cs               1699840  0
wlan                 1474560  0
ir_nec_decoder         16384  0
rc_rktvbox             16384  0
gpio_ir_recv           16384  0
rc_core                40960  4 rc_rktvbox,ir_nec_decoder,gpio_ir_recv
rtl8723ds            1794048  0
mali                  225280  1
wireguard             151552  0
ip6_udp_tunnel         16384  1 wireguard
8723cs, rtl8723ds loaded
LibreELEC:~ # ifconfig
eth0      Link encap:Ethernet  HWaddr 86:0A:7A:43:9D:4C
          inet addr:192.168.1.61  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:16541 errors:0 dropped:30 overruns:0 frame:0
          TX packets:10061 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:3686085 (3.5 MiB)  TX bytes:3487479 (3.3 MiB)
          Interrupt:57
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
p2p0      Link encap:Ethernet  HWaddr 02:E0:4C:80:79:85
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:3065 overruns:0 frame:0
wlan0     Link encap:Ethernet  HWaddr 00:E0:4C:80:79:85
          inet addr:192.168.1.56  Bcast:192.168.1.255  Mask:255.255.255.0
          RX packets:5840 errors:0 dropped:25 overruns:0 frame:0
          TX packets:202 errors:0 dropped:1 overruns:0 carrier:0
          RX bytes:1362099 (1.2 MiB)  TX bytes:57337 (55.9 KiB)
LibreELEC:~ #
Ok there's connman on current libreelec releases. Anyway with @fabiobassa I managed to do some tests on libreelec and 8723bs kernel module is not loaded at all, instead 8723cs and rtl8723ds modules are both loaded at startup and somehow the thing works. We are going to make some more tests and report here findings...
I am ready to test. Another 1 week at least I'm at your disposal
mmm I don't believe all this will finish in just one week ..
Tests on 8723 are going in right direction anyway ;)
1 week is the period that I will definitely spend at home.
"Thank you, COVID-19" for auto isolation.
Maybe then I can’t so quickly
ps And now I have a new "toy" - Kody.
I'm sitting thinking: which TV-box to leave under Libreelec :huh:
with @jock managed to have 8723 working
Let's say 80% is done , just need some tuning and jock will release how to
For my experience on those boards I can say:
if you need videos stay on android or libreelec and kodi
if you need a server or a decent desktop, office and pdf go on linux
If one day it will be implemented WAYLAND x server on thos board , we will have definetly a good replacement for an entry desktop pc ( I am speaking of 3229 and ddr3 )
@fabiobassa don't worry a out the VPN problem I was just playing around and found a bug and was thinking to report it (and in case it was easy to fix it myself)
@Maker39 thanks for trying to put the image on 2GB after playing a little more I found out that is not a good ideea to put in on 2GB because I am already at 92% of the space... Now I am asking if you can increase the space at least with one gb to be sure that it can everything that passes through my mind to install :D
Anyway... With the desktop environment deactivated the system runs more smoothly :D
The temperature is around 65, the ethernet speed is 97% of what the provider is giving
Managed to mount different USB with no problems. And the webdav server is running well.
About VPN, currently there are much more opensource-friendly VPN alternatives, OpenVPN is de-facto standard nowadays and it available for linux, windows and macos. If you need a stable solution, you may try it out. Armbian also has support for wireguard, which is one of the most exciting VPN recently merged into linux kernel due to being very fast and secure, and it is ideal for embedded devices.
About the 2GB partition size, normally armbian enlarges the partition on first boot to fit to the device size. You can, however, do it yourself enlarging the partition and then using ext4 standard tools to adapt the filesystem. It's a matter of seconds and there are plenty of tutorials on the internet on how to do that.
But today, after updating the repository ( Migrated all rk322x-legacy targets into single rk322x-box target, add…) , it broke.
solution "git clone -b rk3229 https://github.com/paolosabatino/armbian-build "
no longer works - no rk322x boards.
Yep, I'm finalizing the process of migrating all the boards into a single image, you should be able to find the board rk322x-box in the list if you want to compile. Tomorrow I will upload new images and new instructions.
Ok.
I will wait for instructions
ps  I tried again today git clone -b rk3229 https://github.com/paolosabatino/armbian-build
oops now there is rk322x-board :rolleyes:
All the images in the first page have been updated with the following news:
  • Single image for all boxes! Configure your box with sudo rk322x-config once the system has booted
  • Support for Realtek 8188eu, 8189es/etv, 88x2bu and various other wifi chips
  • General better stability
  • eMMC in DDR mode for some boards
Enjoy!
hello everyone, it is the first time I write in this forum, I have a tvbox based on rk3229 and I happily managed to boot armbian on sdcard, thanks to your advice, now I would like to install on internal memory but to do this I would first like to do a bakup  of android and here my problem arises .. first of all my device is an rk3229 with 2 gb of ram and 16 days of mmc memory m but when I went to try the rockchip tool to make the backup it tells me that it cannot find the device .. and in fact instead  of 2207:320b it is  2207:0006 ...  so I did a quick google search to see what it was and I arrived on the rockchip website which tells me that shoudl be an rk3066 (but is not)  and that flashes through fastboot, well it would not be a problem if it were not that after several attempts I could not get anything (I wanted to install the recovery twrp to make a backup etc) .. and I found that the bootloader is in security on, and I have no possibility to install custom recovery or different boot ..
The even more odd thing is that I can access adb as root and write the android 8 filesystem via adb does anyone know how i can unlock the bootloader? or in extremis an alternative method to backup android in order to then install armbian in memory?
the problem in what I fear is that I cannot write the recovery partition (I have not tried with the boot partition) I had also tried using dd to write on the recovery partition from armbian, but it does not give me write permission in any way, I did the same thing entering through adb shell by mounting in rw the android system, but nothing, I have no possibility to write the recovery partition.
Can't you just backup /dev/mmcblk2 from armbian using dd?
I have absolutely no experience with encrypted/secured devices because I never got any in my hands and I don't know what happens if the internal bootloader is wiped out here. Maybe @hexdump can give some advice.
Also, could you please post here the result of this command:
hexdump -C /sys/bus/devices/rockchip-efuse0/nvmem
Hello @nokirunner
For a full backup try using this tutorial
Good Luck!
 Since the changes from 10.04.2020 and the replacement of images on rk322x-box.
Firmware replaced with new ones.
LE_bootloader_Armbian_20.05.0-trunk_Rk322x-box_buster_current_5.5.16_minimal 2GB
LE_bootloader_Armbian_20.05.0-trunk_Rk322x-box_buster_legacy_4.4.194_minimal 2GB
LE_bootloader_Armbian_20.05.0-trunk_Rk322x-box_focal_legacy_4.4.194_desktop 4GB
These are img from first post with Libreelec bootloader for boot without erase eMMC. Just insert a card and turn on power.
Google Drive https://drive.google.com/open?id=1uoQvZUUFZyCWYFtatlTSJvJSSjUuJYLm
26.06.2020
Because at the moment, the firmware has lost its relevance. Deleted. :D
@jock I read this "Run sudo rk322x-config and select your board from the list to enable leds, wifi chips, high-speed eMMC, etc..." and tried all the available options.
I made several tests of new firmware on my rk3229 boards.
Legacy firmvare:
1. SSV6051 is working.
2. Wifi RTL8703BS works after blacklist exception 8723cs. The MAC is changes after every reboot.
3. Do not see eMMC . And there is no transfer of the image to the built-in eMMC in armbian-config.
root@rk322x-box:~# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
mmcblk0     179:0    0   1.9G  0 disk
└─mmcblk0p1 179:1    0   1.8G  0 part /
zram0       253:0    0    50M  0 disk /var/log
zram1       253:1    0 997.4M  0 disk [SWAP]
root@rk322x-box:~#
root@rk322x-box:~# dmesg | grep mmcblk
[    6.821106] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[    6.832960]  mmcblk0: p1
[    9.424874] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   12.126923] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
root@rk322x-box:~#
4. NTP client worked.
Did you blacklist 8723cs module to let rtl8703bs work? The MAC address unfortunately is still an open problem, it requires further attention but I haven't any board with 8703/8723 chips to test
This is strange. Are you using original images or those "cured" by you?
I suspect that if you're using the cured you have to change the device tree manually creating the resource.img file from the device tree and put it in the right partition.
Also can you post the whole dmesg output.
1. My blacklist-rk322x-box.conf for enable rtl8703bs
blacklist r8188eu
#blacklist 8723cs
blacklist ssv6051
2. No difference. I tried on the original images and with the replaced bootloader.
I'm sorry - I lied.
Trouble with "patched" img -_-
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47 SMP Thu Apr 9 17:37:46 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: RK3229 HK1mini
[    0.000000] earlycon: Early serial console at MMIO32 0x11030000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] cma: Reserved 128 MiB at 0xd8000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 520704
[    0.000000] free_area_init_node: node 0, pgdat b1236b40, node_mem_map eedfa000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 258560 pages, LIFO batch:31
[    0.000000]   HighMem zone: 262144 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @eed93000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 518400
[    0.000000] Kernel command line: earlyprintk root=UUID=1b14bb30-856d-486f-bf15-733486adb6a2 console=tty0 console=ttyS2,115200n8 rootwait rootfstype=ext4  consoleblank=0 loglevel=7 ubootpart=61151fa6-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 earlycon=uart8250,mmio32,0x11030000
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1906372K/2082816K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 45372K reserved, 131072K cma-reserved, 917504K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c8d53c   (12822 kB)
                     .init : 0xb10a1000 - 0xb1168000   ( 796 kB)
                     .data : 0xb1168000 - 0xb1242e94   ( 876 kB)
                      .bss : 0xb1244000 - 0xb1374ee4   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000757] Switching to timer-based delay loop, resolution 41ns
[    0.003171] Console: colour dummy device 80x30
[    0.004869] console [tty0] enabled
[    0.005249] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.006270] pid_max: default: 32768 minimum: 301
[    0.006882] Security Framework initialized
[    0.007340] Yama: becoming mindful.
[    0.007787] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.008445] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.010183] Initializing cgroup subsys io
[    0.010638] Initializing cgroup subsys memory
[    0.011114] Initializing cgroup subsys devices
[    0.011647] Initializing cgroup subsys freezer
[    0.012109] Initializing cgroup subsys net_cls
[    0.012564] Initializing cgroup subsys perf_event
[    0.013041] Initializing cgroup subsys net_prio
[    0.013522] Initializing cgroup subsys pids
[    0.014024] CPU: Testing write buffer coherency: ok
[    0.014565] ftrace: allocating 41720 entries in 123 pages
[    0.099077] /cpus/cpu@f00 missing clock-frequency property
[    0.099672] /cpus/cpu@f01 missing clock-frequency property
[    0.100222] /cpus/cpu@f02 missing clock-frequency property
[    0.100770] /cpus/cpu@f03 missing clock-frequency property
[    0.101312] CPU0: update cpu_capacity 430
[    0.101715] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.102545] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.106724] CPU1: update cpu_capacity 430
[    0.106735] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.108047] CPU2: update cpu_capacity 430
[    0.108056] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.109339] CPU3: update cpu_capacity 430
[    0.109350] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.109516] Brought up 4 CPUs
[    0.112792] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.113402] CPU: All CPU(s) started in SVC mode.
[    0.115742] devtmpfs: initialized
[    0.135761] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.137177] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.138175] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.145616] xor: measuring software checksum speed
[    0.183320]    arm4regs  :  1011.000 MB/sec
[    0.223431]    8regs     :   705.000 MB/sec
[    0.263540]    32regs    :   684.000 MB/sec
[    0.303648]    neon      :  1018.000 MB/sec
[    0.304067] xor: using function: neon (1018.000 MB/sec)
[    0.304622] pinctrl core: initialized pinctrl subsystem
[    0.307054] NET: Registered protocol family 16
[    0.311466] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.324350] cpuidle: using governor ladder
[    0.336356] cpuidle: using governor menu
[    0.354101] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.354274] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.354422] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.354587] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.361682] console [pstore-1] enabled
[    0.362082] pstore: Registered ramoops as persistent store backend
[    0.362689] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.366941] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.367761] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.465649] raid6: int32x1  gen()   133 MB/s
[    0.533654] raid6: int32x1  xor()   131 MB/s
[    0.601883] raid6: int32x2  gen()   166 MB/s
[    0.669955] raid6: int32x2  xor()   136 MB/s
[    0.738329] raid6: int32x4  gen()   163 MB/s
[    0.806449] raid6: int32x4  xor()   136 MB/s
[    0.874762] raid6: int32x8  gen()   166 MB/s
[    0.943028] raid6: int32x8  xor()   113 MB/s
[    1.011179] raid6: neonx1   gen()   382 MB/s
[    1.079308] raid6: neonx1   xor()   290 MB/s
[    1.147544] raid6: neonx2   gen()   519 MB/s
[    1.215683] raid6: neonx2   xor()   376 MB/s
[    1.283991] raid6: neonx4   gen()   581 MB/s
[    1.352136] raid6: neonx4   xor()   400 MB/s
[    1.420458] raid6: neonx8   gen()   559 MB/s
[    1.488647] raid6: neonx8   xor()   391 MB/s
[    1.489081] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.489605] raid6: .... xor() 400 MB/s, rmw enabled
[    1.490087] raid6: using intx1 recovery algorithm
[    1.491740] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.492345] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.493474] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.494051] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.494766] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.495465] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.496018] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.496982] iommu: Adding device 20020000.vpu-service to group 0
[    1.497826] iommu: Adding device 20030000.rkvdec to group 1
[    1.498479] iommu: Adding device 20050000.vop to group 2
[    1.499095] iommu: Adding device 20070000.iep to group 3
[    1.500271] rk_iommu 20020800.iommu: can't get sclk
[    1.501551] rk_iommu 20030480.iommu: can't get sclk
[    1.502416] rk_iommu 20053f00.iommu: can't get sclk
[    1.503065] rk_iommu 20070800.iommu: can't get aclk
[    1.503562] rk_iommu 20070800.iommu: can't get hclk
[    1.504051] rk_iommu 20070800.iommu: can't get sclk
[    1.505447] SCSI subsystem initialized
[    1.506362] usbcore: registered new interface driver usbfs
[    1.507008] usbcore: registered new interface driver hub
[    1.507752] usbcore: registered new device driver usb
[    1.508486] media: Linux media interface: v0.10
[    1.509018] Linux video capture interface: v2.00
[    1.509719] pps_core: LinuxPPS API ver. 1 registered
[    1.510272] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.511215] PTP clock support registered
[    1.513860] Advanced Linux Sound Architecture Driver Initialized.
[    1.515745] Bluetooth: Core ver 2.21
[    1.516193] NET: Registered protocol family 31
[    1.516644] Bluetooth: HCI device and connection manager initialized
[    1.517276] Bluetooth: HCI socket layer initialized
[    1.517769] Bluetooth: L2CAP socket layer initialized
[    1.518322] Bluetooth: SCO socket layer initialized
[    1.519900] NetLabel: Initializing
[    1.520273] NetLabel:  domain hash size = 128
[    1.520707] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.521301] NetLabel:  unlabeled traffic allowed by default
[    1.523550] clocksource: Switched to clocksource arch_sys_counter
[    1.630068] NET: Registered protocol family 2
[    1.631706] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.632515] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.633501] TCP: Hash tables configured (established 8192 bind 8192)
[    1.634260] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.634904] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.636005] NET: Registered protocol family 1
[    1.637344] RPC: Registered named UNIX socket transport module.
[    1.637953] RPC: Registered udp transport module.
[    1.638422] RPC: Registered tcp transport module.
[    1.638887] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.640022] Trying to unpack rootfs image as initramfs...
[    1.970681] Freeing initrd memory: 4460K
[    1.972408] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.976481] Initialise system trusted keyring
[    1.991696] VFS: Disk quotas dquot_6.6.0
[    1.992478] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.996140] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.000487] NFS: Registering the id_resolver key type
[    2.001104] Key type id_resolver registered
[    2.001529] Key type id_legacy registered
[    2.001957] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.002702] ntfs: driver 2.1.32 [Flags: R/W].
[    2.004247] JFS: nTxBlock = 8192, nTxLock = 65536
[    2.020332] SGI XFS with security attributes, no debug enabled
[    2.031144] NET: Registered protocol family 38
[    2.031729] Key type asymmetric registered
[    2.032161] Asymmetric key parser 'x509' registered
[    2.032779] bounce: pool size: 64 pages
[    2.033585] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.034809] io scheduler noop registered
[    2.035239] io scheduler deadline registered
[    2.035833] io scheduler cfq registered (default)
[    2.040190] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    2.046883] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    2.048151] rk-vcodec 20020000.vpu-service: probe device
[    2.049219] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    2.051401] rk-vcodec 20020000.vpu-service: could not find power_model node
[    2.052177] rk-vcodec 20020000.vpu-service: init success
[    2.053160] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    2.058209] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    2.058900] dma-pl330 110f0000.pdma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.061077] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.062364] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    2.062385] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    2.062405] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    2.062420] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    2.062434] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.062450] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.063194] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.063220] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.063236] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.063252] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    2.063265] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    2.063280] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    2.064646] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.066270] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.067261] console [ttyS2] enabled
[    2.074697] bootconsole [uart0] disabled
[    2.085337] [drm] Initialized drm 1.1.0 20060810
[    2.092822] [drm] Rockchip DRM driver version: v1.0.1
[    2.098319] rockchip-drm display-subsystem: devfreq is not set
[    2.105173] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d111b0)
[    2.113066] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.119795] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.127734] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.139048] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    2.146627] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.153311] [drm] No driver support for vblank timestamp query.
[    2.159432] rockchip-drm display-subsystem: failed to parse display resources
[    2.790567] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.791356] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    2.791365] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    2.791372] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    2.791379] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    2.791386] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    2.791393] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    2.791399] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    2.791406] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    2.791413] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    2.791420] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    2.791427] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    2.791434] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    2.791440] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    2.791447] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    2.791455] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    2.878524] Console: switching to colour frame buffer device 240x67
[    3.068029] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.093444] brd: module loaded
[    3.113766] loop: module loaded
[    3.117327] lkdtm: No crash points registered, enable through debugfs
[    3.127802] libphy: Fixed MDIO Bus: probed
[    3.132266] tun: Universal TUN/TAP device driver, 1.6
[    3.137594] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.144645] CAN device driver interface
[    3.150838] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    3.158345] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    3.164310] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    3.170308] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    3.177080] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    3.189481] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.227781] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.233141]  Ring mode enabled
[    3.236387]  DMA HW capability register supported
[    3.241146]  Normal descriptors
[    3.244674]  RX Checksum Offload Engine supported (type 2)
[    3.250407]  TX Checksum insertion supported
[    3.254887]  Wake-Up On Lan supported
[    3.271570] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 86:0a:7a:43:9d:4c
[    3.292916] eth%d: device MAC address 86:0a:7a:43:9d:4c
[    3.310962]  Enable RX Mitigation via HW Watchdog Timer
[    3.329299] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.968742] libphy: stmmac: probed
[    3.985280] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    4.004926] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    4.023830] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    4.042105] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    4.060205] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    4.078073] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    4.095741] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    4.113149] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    4.130499] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    4.147764] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    4.164857] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    4.182018] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    4.199048] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    4.215928] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    4.232596] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    4.249006] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    4.265225] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    4.281230] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    4.296917] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    4.312427] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    4.327699] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    4.342802] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    4.357817] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    4.372723] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    4.387359] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    4.401743] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    4.415606] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    4.429278] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    4.442975] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    4.456743] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    4.470491] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    4.484146] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    4.500036] PPP generic driver version 2.4.2
[    4.512877] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    4.526836] usbcore: registered new interface driver at76c50x-usb
[    4.541259] usbcore: registered new interface driver rtl8187
[    4.555189] usbcore: registered new interface driver rndis_wlan
[    4.569100] usbcore: registered new interface driver zd1201
[    4.583029] usbcore: registered new interface driver rt2800usb
[    4.596836] Rockchip WiFi SYS interface (V1.00) ...
[    4.609643] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    4.624967] usbcore: registered new interface driver pegasus
[    4.638663] usbcore: registered new interface driver rtl8150
[    4.652105] usbcore: registered new interface driver r8152
[    4.665156] usbcore: registered new interface driver asix
[    4.678141] usbcore: registered new interface driver ax88179_178a
[    4.691660] usbcore: registered new interface driver cdc_ether
[    4.704826] usbcore: registered new interface driver dm9601
[    4.717720] usbcore: registered new interface driver smsc75xx
[    4.730335] usbcore: registered new interface driver smsc95xx
[    4.742729] usbcore: registered new interface driver net1080
[    4.755189] usbcore: registered new interface driver rndis_host
[    4.767900] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    4.782233] usbcore: registered new interface driver cdc_ncm
[    4.794583] usbcore: registered new interface driver cdc_mbim
[    4.807783] 30040000.usb supply vusb_d not found, using dummy regulator
[    4.821431] 30040000.usb supply vusb_a not found, using dummy regulator
[    4.848854] dwc2 30040000.usb: DWC OTG Controller
[    4.860260] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    4.874064] dwc2 30040000.usb: irq 48, io mem 0x30040000
[    4.886492] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.900069] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.913816] usb usb1: Product: DWC OTG Controller
[    4.924894] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    4.937618] usb usb1: SerialNumber: 30040000.usb
[    4.950211] hub 1-0:1.0: USB hub found
[    4.960457] hub 1-0:1.0: 1 port detected
[    4.973194] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.986470] ehci-platform: EHCI generic platform driver
[    5.001278] ehci-platform 30080000.usb: EHCI Host Controller
[    5.014440] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    5.029822] ehci-platform 30080000.usb: irq 49, io mem 0x30080000
[    5.051684] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    5.065504] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.079559] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.094035] usb usb2: Product: EHCI Host Controller
[    5.106484] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    5.120231] usb usb2: SerialNumber: 30080000.usb
[    5.134081] hub 2-0:1.0: USB hub found
[    5.145879] hub 2-0:1.0: 1 port detected
[    5.161125] ehci-platform 300c0000.usb: EHCI Host Controller
[    5.175722] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    5.192293] ehci-platform 300c0000.usb: irq 51, io mem 0x300c0000
[    5.215694] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    5.216148] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    5.216158] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.216166] usb usb3: Product: EHCI Host Controller
[    5.216173] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    5.216181] usb usb3: SerialNumber: 300c0000.usb
[    5.217621] hub 3-0:1.0: USB hub found
[    5.217716] hub 3-0:1.0: 1 port detected
[    5.221009] ehci-platform 30100000.usb: EHCI Host Controller
[    5.221605] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    5.222257] ehci-platform 30100000.usb: irq 53, io mem 0x30100000
[    5.231648] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    5.232063] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    5.232077] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.232084] usb usb4: Product: EHCI Host Controller
[    5.232091] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    5.232098] usb usb4: SerialNumber: 30100000.usb
[    5.233482] hub 4-0:1.0: USB hub found
[    5.233585] hub 4-0:1.0: 1 port detected
[    5.234614] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.234668] ohci-platform: OHCI generic platform driver
[    5.235353] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    5.236231] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    5.236685] ohci-platform 300a0000.usb: irq 50, io mem 0x300a0000
[    5.296342] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    5.296363] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.296378] usb usb5: Product: Generic Platform OHCI controller
[    5.296391] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    5.296405] usb usb5: SerialNumber: 300a0000.usb
[    5.298686] hub 5-0:1.0: USB hub found
[    5.298821] hub 5-0:1.0: 1 port detected
[    5.301159] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    5.302213] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    5.303107] ohci-platform 300e0000.usb: irq 52, io mem 0x300e0000
[    5.360987] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    5.361018] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.361032] usb usb6: Product: Generic Platform OHCI controller
[    5.361042] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    5.361051] usb usb6: SerialNumber: 300e0000.usb
[    5.363476] hub 6-0:1.0: USB hub found
[    5.363800] hub 6-0:1.0: 1 port detected
[    5.365032] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    5.365661] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    5.366127] ohci-platform 30120000.usb: irq 54, io mem 0x30120000
[    5.399635] usb 1-1: new full-speed USB device number 2 using dwc2
[    5.424200] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    5.424216] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.424229] usb usb7: Product: Generic Platform OHCI controller
[    5.424237] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    5.424244] usb usb7: SerialNumber: 30120000.usb
[    5.426069] hub 7-0:1.0: USB hub found
[    5.426215] hub 7-0:1.0: 1 port detected
[    5.428919] usbcore: registered new interface driver cdc_acm
[    5.428926] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    5.429061] usbcore: registered new interface driver cdc_wdm
[    5.429390] usbcore: registered new interface driver usb-storage
[    5.429622] usbcore: registered new interface driver usbserial
[    5.429706] usbcore: registered new interface driver usbserial_generic
[    5.429767] usbserial: USB Serial support registered for generic
[    5.429871] usbcore: registered new interface driver keyspan
[    5.429929] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    5.429986] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    5.430064] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    5.430120] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    5.430228] usbcore: registered new interface driver option
[    5.430284] usbserial: USB Serial support registered for GSM modem (1-port)
[    5.430999] usbcore: registered new interface driver oti6858
[    5.431059] usbserial: USB Serial support registered for oti6858
[    5.431163] usbcore: registered new interface driver qcserial
[    5.431231] usbserial: USB Serial support registered for Qualcomm USB modem
[    5.431396] usbcore: registered new interface driver sierra
[    5.431454] usbserial: USB Serial support registered for Sierra USB modem
[    5.433193] usbcore: registered new interface driver iforce
[    5.433400] usbcore: registered new interface driver xpad
[    5.433758] usbcore: registered new interface driver usbtouchscreen
[    5.436717] i2c /dev entries driver
[    5.442401] usbcore: registered new interface driver uvcvideo
[    5.442406] USB Video Class driver (1.1.1)
[    5.446112] Boot mode: normal
[    5.448177] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    5.450552] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    5.451518] Bluetooth: Virtual HCI driver ver 1.5
[    5.452526] Bluetooth: HCI UART driver ver 2.3
[    5.452539] Bluetooth: HCI UART protocol H4 registered
[    5.452543] Bluetooth: HCI UART protocol LL registered
[    5.452553] Bluetooth: HCI UART protocol ATH3K registered
[    5.452558] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.452986] Bluetooth: HCI UART protocol BCM registered
[    5.453328] usbcore: registered new interface driver bfusb
[    5.453564] usbcore: registered new interface driver btusb
[    5.453580] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    5.455340] cpu cpu0: leakage=3
[    5.455382] cpu cpu0: leakage-volt-sel=0
[    5.456408] cpu cpu0: Failed to get pvtm
[    5.460647] cpu cpu0: avs=0
[    5.460748] cpu cpu0: scale_rate=1392000000
[    5.461472] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    5.461497] cpu cpu0: failed to read out thermal zone (-22)
[    5.462615] cpu cpu0: failed to find power_model node
[    5.464331] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    5.464340] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    5.464371] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    5.464954] Synopsys Designware Multimedia Card Interface Driver
[    5.465870] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    5.466094] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    5.466130] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    5.466362] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    5.466541] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    5.466546] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    5.466589] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    5.466600] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.466707] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    5.466838] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    5.466864] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    5.466878] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    5.466882] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.466892] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    5.466898] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    5.466909] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    5.466923] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    5.479921] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.492471] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    5.493758] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    5.494053] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    5.494513] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    5.494567] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    5.494765] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    5.494939] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    5.494944] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    5.494996] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    5.495019] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    5.495108] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    5.495144] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    5.495153] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    5.495200] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    5.495366] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    5.507849] mmc_host mmc1: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    5.519893] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    5.521540] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led_red[0]' - status (0)
[    5.521915] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led_blue[0]' - status (0)
[    5.522244] ledtrig-cpu: registered to indicate activity on CPUs
[    5.522380] hidraw: raw HID events driver (C) Jiri Kosina
[    5.523401] usbcore: registered new interface driver usbhid
[    5.523405] usbhid: USB HID core driver
[    5.524753] ashmem: initialized
[    5.525846] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[    5.541750] rockchip-dmc dmc: leakage=3
[    5.541766] rockchip-dmc dmc: leakage-volt-sel=0
[    5.541895] rockchip-dmc dmc: Failed to get pvtm
[    5.543146] rockchip-dmc dmc: avs=0
[    5.543197] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[    5.543206] rockchip-dmc dmc: failed to get vop pn to msch rl
[    5.544423] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    5.559730] rknandbase v1.2 2018-05-08
[    5.560109] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    5.560348] ftl_init fffffffe
[    5.560350] rk_ftl_init fail
[    5.561521] usbcore: registered new interface driver snd-usb-audio
[    5.561611] usbcore: registered new interface driver snd-ua101
[    5.561708] usbcore: registered new interface driver snd-usb-caiaq
[    5.561783] usbcore: registered new interface driver snd-usb-6fire
[    5.561919] usbcore: registered new interface driver snd-usb-hiface
[    5.561985] usbcore: registered new interface driver snd-bcd2000
[    5.562043] usbcore: registered new interface driver snd_usb_pod
[    5.562098] usbcore: registered new interface driver snd_usb_podhd
[    5.562155] usbcore: registered new interface driver snd_usb_toneport
[    5.562290] usbcore: registered new interface driver snd_usb_variax
[    5.566943] u32 classifier
[    5.566945]     input device check on
[    5.566947]     Actions configured
[    5.566957] Netfilter messages via NETLINK v0.30.
[    5.566981] nfnl_acct: registering with nfnetlink.
[    5.567051] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    5.567883] mmc_host mmc1: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[    5.568191] Initializing XFRM netlink socket
[    5.569081] mmc1: new high speed SDIO card at address 0001
[    5.570184] NET: Registered protocol family 10
[    5.571402] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    5.571803] sit: IPv6 over IPv4 tunneling driver
[    5.572541] NET: Registered protocol family 17
[    5.572571] NET: Registered protocol family 15
[    5.572628] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    5.572667] Bridge firewalling registered
[    5.572674] can: controller area network core (rev 20120528 abi 9)
[    5.572746] NET: Registered protocol family 29
[    5.572759] can: raw protocol (rev 20120528)
[    5.572765] can: broadcast manager protocol (rev 20120528 t)
[    5.572779] can: netlink gateway (rev 20130117) max_hops=1
[    5.573150] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.573336] mmc0: new high speed SD card at address e624
[    5.573782] Bluetooth: RFCOMM TTY layer initialized
[    5.573810] Bluetooth: RFCOMM socket layer initialized
[    5.573853] Bluetooth: RFCOMM ver 1.11
[    5.573903] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.573917] Bluetooth: HIDP socket layer initialized
[    5.574028] 8021q: 802.1Q VLAN Support v1.8
[    5.574069] lib80211: common routines for IEEE802.11 drivers
[    5.574075] lib80211_crypt: registered algorithm 'NULL'
[    5.574084] lib80211_crypt: registered algorithm 'WEP'
[    5.574092] lib80211_crypt: registered algorithm 'CCMP'
[    5.574100] lib80211_crypt: registered algorithm 'TKIP'
[    5.574106] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    5.574357] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    5.574375] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ssv6051
[    5.574378] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    5.574380] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    5.574386] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    5.574391] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    5.574396] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    5.574422] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    5.574426] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 0.
[    5.574435] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    5.574438] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    5.574445] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    5.574508] [BT_RFKILL]: Enter rfkill_rk_init
[    5.574741] Key type dns_resolver registered
[    5.575126] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[    5.575470] flash vendor_init_thread!
[    5.575473] flash vendor storage:20170308 ret = -1
[    5.575583] Error: Driver 'sc031gs' is already registered, aborting...
[    5.576275] Registering SWP/SWPB emulation handler
[    5.577443] registered taskstats version 1
[    5.577458] Loading compiled-in X.509 certificates
[    5.578925]  mmcblk0: p1
[    5.580405] Btrfs loaded
[    5.581519] rga2: Driver loaded successfully ver:4.01
[    5.581704] rga2: Module initialized.
[    5.581727] pvtm list NULL
[    5.582800] rk-vcodec 20030000.rkvdec: leakage=3
[    5.582815] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0
[    5.582906] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    5.583253] rk-vcodec 20030000.rkvdec: avs=0
[    5.583483] rk-vcodec 20030000.rkvdec: probe device
[    5.584140] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    5.585456] rk-vcodec 20030000.rkvdec: init success
[    5.586415] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    5.586421] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    5.586719] usb 1-1: New USB device found, idVendor=1915, idProduct=af11
[    5.586726] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.586730] usb 1-1: Product: Wireless Receiver
[    5.586735] usb 1-1: Manufacturer: 2.4G
[    5.587503] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    5.589699] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    5.589707] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    5.591005] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    5.591024] input: 2.4G  Wireless Receiver  as /devices/platform/30040000.usb/usb1/1-1/1-1:1.0/0003:1915:AF11.0001/input/input0
[    5.593203] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/power-key[0]' - status (-22)
[    5.593214] gpio-keys gpio_keys: Failed to get gpio flags, error: -22
[    5.593237] gpio-keys: probe of gpio_keys failed with error -22
[    5.593315] hctosys: unable to open rtc device (rtc0)
[    5.604874] ALSA device list:
[    5.604881]   #0: DW-I2S-HDMI
[    5.604883]   #1: SPDIF
[    5.644624] hid-generic 0003:1915:AF11.0001: input,hidraw0: USB HID v1.11 Keyboard [2.4G  Wireless Receiver ] on usb-30040000.usb-1/input0
[    5.651100] input: 2.4G  Wireless Receiver  as /devices/platform/30040000.usb/usb1/1-1/1-1:1.1/0003:1915:AF11.0002/input/input1
[    5.667559] usb 5-1: new low-speed USB device number 2 using ohci-platform
[    5.704061] hid-generic 0003:1915:AF11.0002: input,hidraw1: USB HID v1.11 Mouse [2.4G  Wireless Receiver ] on usb-30040000.usb-1/input1
[    5.709484] hid-generic 0003:1915:AF11.0003: hiddev0,hidraw2: USB HID v1.11 Device [2.4G  Wireless Receiver ] on usb-30040000.usb-1/input2
[    5.883636] usb 5-1: New USB device found, idVendor=1a2c, idProduct=0b23
[    5.883644] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.883648] usb 5-1: Product: USB Keyboard
[    5.883652] usb 5-1: Manufacturer: USB
[    5.892406] input: USB USB Keyboard as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:1A2C:0B23.0004/input/input2
[    5.948341] hid-generic 0003:1A2C:0B23.0004: input,hidraw3: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-300a0000.usb-1/input0
[    5.957015] input: USB USB Keyboard as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:1A2C:0B23.0005/input/input3
[    6.012035] hid-generic 0003:1A2C:0B23.0005: input,hidraw4: USB HID v1.10 Mouse [USB USB Keyboard] on usb-300a0000.usb-1/input1
[    7.892429] ttyS2 - failed to request DMA, use interrupt mode
[    7.905406] Freeing unused kernel memory: 796K
[    7.916200] This architecture does not have kernel memory protection.
[    8.595660] vendor storage:20190527 ret = -1
[    8.900198] random: nonblocking pool is initialized
[    8.932177] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    9.722601] systemd[1]: System time before build time, advancing clock.
[    9.751030] systemd[1]: Inserted module 'autofs4'
[    9.772941] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.796433] cgroup: cgroup2: unknown option "nsdelegate"
[    9.826382] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    9.865283] systemd[1]: Detected architecture arm.
[    9.896696] systemd[1]: Set hostname to <rk322x-box>.
[   10.231734] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   10.265245] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   10.695875] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.712836] systemd[1]: Reached target Swap.
[   10.732294] systemd[1]: Listening on udev Kernel Socket.
[   10.756255] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   10.784107] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.811798] systemd[1]: Reached target Paths.
[   10.835384] systemd[1]: Created slice system-getty.slice.
[   10.860492] systemd[1]: Listening on udev Control Socket.
[   10.887845] systemd[1]: Reached target Remote File Systems.
[   10.924603] systemd[1]: Listening on Syslog Socket.
[   10.948671] systemd[1]: Listening on Journal Socket.
[   10.978067] systemd[1]: Starting Set the console keyboard layout...
[   11.010892] systemd[1]: Mounting Kernel Debug File System...
[   11.041976] systemd[1]: Starting Nameserver information manager...
[   11.068779] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.086274] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[   11.086844] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   11.144598] systemd[1]: Starting Restore / save the current clock...
[   11.171930] systemd[1]: Reached target System Time Synchronized.
[   11.207510] systemd[1]: Mounting POSIX Message Queue File System...
[   11.242380] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   11.273397] systemd[1]: Created slice User and Session Slice.
[   11.299903] systemd[1]: Reached target Slices.
[   11.322110] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.339969] systemd[1]: Reached target Local Encrypted Volumes.
[   11.365313] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   11.392543] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.419904] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   11.442711] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.468534] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.500365] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   11.500954] systemd[1]: Starting udev Coldplug all Devices...
[   11.531545] dwmmc_rockchip 30000000.dwmmc: Unexpected interrupt latency
[   11.547604] dwmmc_rockchip 30000000.dwmmc: Unexpected interrupt latency
[   11.563544] dwmmc_rockchip 30000000.dwmmc: Unexpected interrupt latency
[   11.604221] systemd[1]: Starting Load Kernel Modules...
[   11.635899] systemd[1]: Started Set the console keyboard layout.
[   11.675010] systemd[1]: Mounted Kernel Debug File System.
[   11.707410] systemd[1]: Started Restore / save the current clock.
[   11.737084] systemd[1]: Mounted POSIX Message Queue File System.
[   11.766593] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   11.798637] systemd[1]: Started Remount Root and Kernel File Systems.
[   11.832696] systemd[1]: Started Load Kernel Modules.
[   11.860497] systemd[1]: Started Nameserver information manager.
[   11.892971] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   11.918197] systemd[1]: Mounting Kernel Configuration File System...
[   11.949559] systemd[1]: Starting Apply Kernel Variables...
[   11.982460] systemd[1]: Starting Load/Save Random Seed...
[   12.008163] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   12.033851] systemd[1]: Starting Create System Users...
[   12.047601] systemd[1]: Mounted Kernel Configuration File System.
[   12.060669] systemd[1]: Started Apply Kernel Variables.
[   12.071032] systemd[1]: Started Load/Save Random Seed.
[   12.109403] systemd[1]: Started Create System Users.
[   12.124533] systemd[1]: Starting Create Static Device Nodes in /dev...
[   12.190740] systemd[1]: Started Create Static Device Nodes in /dev.
[   12.202534] systemd[1]: Started udev Coldplug all Devices.
[   12.219067] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   12.227886] systemd[1]: Reached target Local File Systems (Pre).
[   12.245916] systemd[1]: Mounting /tmp...
[   12.261911] systemd[1]: Starting udev Kernel Device Manager...
[   12.280580] systemd[1]: Started Helper to synchronize boot up for ifupdown.
[   12.292961] systemd[1]: Mounted /tmp.
[   12.302325] systemd[1]: Reached target Local File Systems.
[   12.318211] systemd[1]: Starting Armbian ZRAM config...
[   12.324315] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   12.332327] systemd[1]: Starting Set console font and keymap...
[   12.352402] systemd[1]: Starting Raise network interfaces...
[   12.377072] systemd[1]: Started Set console font and keymap.
[   12.461894] systemd[1]: Started udev Kernel Device Manager.
[   12.620703] cfg80211: World regulatory domain updated:
[   12.620740] cfg80211:  DFS Master region: unset
[   12.620747] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   12.620760] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   12.620772] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   12.620781] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   12.620791] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   12.620801] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   12.620809] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   12.620818] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   12.620827] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   12.781473] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[   12.781510] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[   12.781525] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[   12.781559] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[   12.781625] rk3228-codec 12010000.codec: spk_depop_time use default value.
[   12.782659] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[   12.782694] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[   12.797162] systemd[1]: Found device /dev/ttyS2.
[   12.811157] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '17:33:02', on 'Apr  9 2020'.
[   12.811441] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[   12.811464] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[   12.811474] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[   12.811485] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[   12.811495] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[   12.811503] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[   12.811616] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[   12.811627] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[   12.811636] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[   12.811645] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[   12.811653] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[   12.811664] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[   12.811674] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[   12.811683] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[   12.811694] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[   12.812065] mali-utgard 20001000.gpu: leakage=3
[   12.812104] mali-utgard 20001000.gpu: leakage-volt-sel=0
[   12.812230] mali-utgard 20001000.gpu: Failed to get pvtm
[   12.814750] mali-utgard 20001000.gpu: avs=0
[   12.815135] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[   12.819704] zram: Added device: zram0
[   12.822677] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[   12.823074] zram: Added device: zram1
[   12.824024] Mali: Mali device driver loaded
[   12.825318] zram: Added device: zram2
[   13.149876] =======================================================
[   13.149884] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[   13.149891] =======================================================
[   13.149900] Realtek 8723CS SDIO WiFi driver (Powered by Rockchip,Ver v5.2.1.7_25082.20171108_COEX20170626-1a00_wifi_hal) init.
[   13.149912] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   13.149920] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[   13.149928] [WLAN_RFKILL]: wifi turn on power. -1
[   13.149937] mmc1:mmc host rescan start!
[   13.149944] RTW: module init start
[   13.149954] RTW: rtl8723cs v5.2.1.7_25082.20171108_COEX20170626-1a00_wifi_hal
[   13.149960] RTW: build time: Apr  9 2020 17:36:26
[   13.149967] RTW: rtl8723cs BT-Coex version = COEX20170626-1a00
[   13.149975] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[   13.161699] RTW: == SDIO Card Info ==
[   13.161733] RTW:   clock: 37500000 Hz
[   13.161752] RTW:   timing spec : sd high-speed
[   13.161763] RTW:   sd3_bus_mode: FALSE
[   13.161769] RTW: ================
[   13.201030] systemd[1]: Started Raise network interfaces.
[   13.205656] RTW: 0x000: 29 81 03 7C E1 00 28 00    B3 04 65 45 10 06 40 02
[   13.205738] RTW: 0x010: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.205796] RTW: 0x020: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.205853] RTW: 0x030: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.205915] RTW: 0x040: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.205977] RTW: 0x050: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206079] RTW: 0x060: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206180] RTW: 0x070: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206243] RTW: 0x080: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206307] RTW: 0x090: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206400] RTW: 0x0a0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206482] RTW: 0x0b0: FF FF FF FF FF FF FF FF    FF FF 35 FF FF FF FF FF
[   13.206557] RTW: 0x0c0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206627] RTW: 0x0d0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206699] RTW: 0x0e0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206803] RTW: 0x0f0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206902] RTW: 0x100: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.206982] RTW: 0x110: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207054] RTW: 0x120: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207147] RTW: 0x130: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207217] RTW: 0x140: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207276] RTW: 0x150: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207334] RTW: 0x160: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207471] RTW: 0x170: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207649] RTW: 0x180: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207796] RTW: 0x190: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.207902] RTW: 0x1a0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.208022] RTW: 0x1b0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.208154] RTW: 0x1c0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.208272] RTW: 0x1d0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.208359] RTW: 0x1e0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.208473] RTW: 0x1f0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[   13.208599] RTW: rtw_read_efuse_from_file /system/etc/wifi/wifi_efuse_8723cs.map is not readable
[   13.208619] RTW: ERROR invalid phy efuse and read from file fail, will use driver default!!
[   13.208671] RTW: rtw_read_macaddr_from_file /data/wifimac.txt is not readable
[   13.217543] RTW: hal_com_config_channel_plan use def_chplan:0x20
[   13.264399] zram1: detected capacity change from 0 to 1045864448
[   13.401263] Adding 1021348k swap on /dev/zram1.  Priority:5 extents:1 across:1021348k SS
[   13.508494] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[   13.508535] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[   13.652260] zram0: detected capacity change from 0 to 52428800
[   13.733117] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   13.743818] systemd[1]: Reached target Sound Card.
[   13.754198] systemd[1]: Started Armbian ZRAM config.
[   13.773370] systemd[1]: Starting Armbian memory supported logging...
[   13.872493] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   16.027604] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac address failed (-1)
[   16.027632] RTW: ERROR invalid mac addr:00:00:00:00:00:00, assign random MAC
[   16.029370] RTW: rtw_ndev_init(wlan0) if1 mac_addr=00:e0:4c:09:f7:af
[   16.031405] RTW: rtw_ndev_init(p2p0) if2 mac_addr=02:e0:4c:09:f7:af
[   16.036178] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   17.031598] RTW: module init ret=0
[   17.077163] systemd[1]: Started Load/Save RF Kill Switch Status.
[   17.620652] systemd[1]: Started Armbian memory supported logging.
[   17.639039] systemd[1]: Starting Journal Service...
[   18.098497] systemd[1]: Started Journal Service.
[   18.183440] systemd-journald[551]: Received request to flush runtime journal from PID 1
[   19.846422] nr_pdflush_threads exported in /proc is scheduled for removal
[   20.791672] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.922711] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[   21.621628] RTW: wlan0- hw port(0) mac_addr =00:e0:4c:09:f7:af
[   21.621783] RTW: p2p0- hw port(1) mac_addr =02:e0:4c:09:f7:af
[   21.625290] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[   21.657001] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   21.657527] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   22.015169] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   22.035503] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[   22.856006] rk_gmac-dwmac 30200000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   23.756356] RTW: nolinked power save enter
[   25.769788] RTW: wlan0- hw port(0) mac_addr =00:e0:4c:09:f7:af
[   25.769975] RTW: p2p0- hw port(1) mac_addr =02:e0:4c:09:f7:af
[   25.772515] RTW: nolinked power save leave
[   27.516350] RTW: nolinked power save enter
[   48.774858] RTW: wlan0- hw port(0) mac_addr =00:e0:4c:09:f7:af
[   48.775007] RTW: p2p0- hw port(1) mac_addr =02:e0:4c:09:f7:af
[   48.778005] RTW: nolinked power save leave
[   50.485024] RTW: nolinked power save enter
root@rk322x-box:~#
Clear image
└─mmcblk0p1  179:1    0  1.7G  0 part /
mmcblk2      179:16   0  7.3G  0 disk
└─mmcblk2p1  179:17   0  7.2G  0 part
mmcblk2boot0 179:32   0    4M  1 disk
mmcblk2boot1 179:48   0    4M  1 disk
mmcblk2rpmb  179:64   0  512K  0 disk
zram1        253:1    0  490M  0 disk [SWAP]
root@rk322x-box:~#
[    0.000000] Machine model: RK3229 Box A95X-R1
[    0.000000] cma: Reserved 128 MiB at 0x98000000
[    0.000000] On node 0 totalpages: 258560
[    0.000000] free_area_init_node: node 0, pgdat b1236b40, node_mem_map e76b9000
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] PERCPU: Embedded 14 pages/cpu @e7659000 s24856 r8192 d24296 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 256256
[    0.000000] Kernel command line: earlyprintk root=UUID=1b14bb30-856d-486f-bf15-733486adb6a2 console=tty0 console=ttyS2,115200n8 rootwait rootfstype=ext4  consoleblank=0 loglevel=7 ubootpart=89a45db9-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Memory: 867236K/1034240K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 35932K reserved, 131072K cma-reserved, 0K highmem)
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000023] Switching to timer-based delay loop, resolution 41ns
[    0.001697] Console: colour dummy device 80x30
[    0.002898] console [tty0] enabled
[    0.002955] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.003036] pid_max: default: 32768 minimum: 301
[    0.003199] Security Framework initialized
[    0.003244] Yama: becoming mindful.
[    0.003349] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003401] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.004404] Initializing cgroup subsys io
[    0.004479] Initializing cgroup subsys memory
[    0.004556] Initializing cgroup subsys devices
[    0.004609] Initializing cgroup subsys freezer
[    0.004658] Initializing cgroup subsys net_cls
[    0.004708] Initializing cgroup subsys perf_event
[    0.004756] Initializing cgroup subsys net_prio
[    0.004817] Initializing cgroup subsys pids
[    0.004918] CPU: Testing write buffer coherency: ok
[    0.005001] ftrace: allocating 41720 entries in 123 pages
[    0.084334] /cpus/cpu@f00 missing clock-frequency property
[    0.084405] /cpus/cpu@f01 missing clock-frequency property
[    0.084452] /cpus/cpu@f02 missing clock-frequency property
[    0.084500] /cpus/cpu@f03 missing clock-frequency property
[    0.084540] CPU0: update cpu_capacity 430
[    0.084578] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.084687] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.099154] CPU1: update cpu_capacity 430
[    0.099164] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.111412] CPU2: update cpu_capacity 430
[    0.111422] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.124016] CPU3: update cpu_capacity 430
[    0.124025] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.124164] Brought up 4 CPUs
[    0.124399] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.124436] CPU: All CPU(s) started in SVC mode.
[    0.125980] devtmpfs: initialized
[    0.144608] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.145202] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.145297] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.151401] xor: measuring software checksum speed
[    0.188028]    arm4regs  :  1011.000 MB/sec
[    0.228135]    8regs     :   705.000 MB/sec
[    0.268242]    32regs    :   684.000 MB/sec
[    0.308343]    neon      :  1018.000 MB/sec
[    0.308381] xor: using function: neon (1018.000 MB/sec)
[    0.308448] pinctrl core: initialized pinctrl subsystem
[    0.310055] NET: Registered protocol family 16
[    0.312711] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.324510] cpuidle: using governor ladder
[    0.336524] cpuidle: using governor menu
[    0.353063] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.353225] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.353371] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.353528] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.359488] console [pstore-1] enabled
[    0.359537] pstore: Registered ramoops as persistent store backend
[    0.359579] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.363099] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.363177] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.363427] sip_firmware_init: set rockchip sip version v2 failed
[    0.461407] raid6: int32x1  gen()   133 MB/s
[    0.529531] raid6: int32x1  xor()   131 MB/s
[    0.597728] raid6: int32x2  gen()   166 MB/s
[    0.665802] raid6: int32x2  xor()   136 MB/s
[    0.734155] raid6: int32x4  gen()   163 MB/s
[    0.802314] raid6: int32x4  xor()   137 MB/s
[    0.870561] raid6: int32x8  gen()   166 MB/s
[    0.938823] raid6: int32x8  xor()   113 MB/s
[    1.006813] raid6: neonx1   gen()   381 MB/s
[    1.075065] raid6: neonx1   xor()   290 MB/s
[    1.143298] raid6: neonx2   gen()   519 MB/s
[    1.211433] raid6: neonx2   xor()   376 MB/s
[    1.279658] raid6: neonx4   gen()   581 MB/s
[    1.347865] raid6: neonx4   xor()   400 MB/s
[    1.416063] raid6: neonx8   gen()   559 MB/s
[    1.484340] raid6: neonx8   xor()   391 MB/s
[    1.484380] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.484418] raid6: .... xor() 400 MB/s, rmw enabled
[    1.484456] raid6: using intx1 recovery algorithm
[    1.485487] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.485543] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.485944] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.486444] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.487055] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.487665] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.488169] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.489091] iommu: Adding device 20020000.vpu-service to group 0
[    1.489249] iommu: Adding device 20030000.rkvdec to group 1
[    1.489375] iommu: Adding device 20050000.vop to group 2
[    1.489495] iommu: Adding device 20070000.iep to group 3
[    1.490068] rk_iommu 20020800.iommu: can't get sclk
[    1.490717] rk_iommu 20030480.iommu: can't get sclk
[    1.491005] rk_iommu 20053f00.iommu: can't get sclk
[    1.491184] rk_iommu 20070800.iommu: can't get aclk
[    1.491233] rk_iommu 20070800.iommu: can't get hclk
[    1.491278] rk_iommu 20070800.iommu: can't get sclk
[    1.492068] SCSI subsystem initialized
[    1.492577] usbcore: registered new interface driver usbfs
[    1.492713] usbcore: registered new interface driver hub
[    1.492881] usbcore: registered new device driver usb
[    1.493109] media: Linux media interface: v0.10
[    1.493218] Linux video capture interface: v2.00
[    1.493467] pps_core: LinuxPPS API ver. 1 registered
[    1.493512] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.493609] PTP clock support registered
[    1.495552] Advanced Linux Sound Architecture Driver Initialized.
[    1.496729] Bluetooth: Core ver 2.21
[    1.496830] NET: Registered protocol family 31
[    1.496871] Bluetooth: HCI device and connection manager initialized
[    1.496921] Bluetooth: HCI socket layer initialized
[    1.496967] Bluetooth: L2CAP socket layer initialized
[    1.497049] Bluetooth: SCO socket layer initialized
[    1.497857] NetLabel: Initializing
[    1.497908] NetLabel:  domain hash size = 128
[    1.497945] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.498049] NetLabel:  unlabeled traffic allowed by default
[    1.499416] clocksource: Switched to clocksource arch_sys_counter
[    1.595482] NET: Registered protocol family 2
[    1.596396] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.596549] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.596935] TCP: Hash tables configured (established 8192 bind 8192)
[    1.597066] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.597167] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.597534] NET: Registered protocol family 1
[    1.598245] RPC: Registered named UNIX socket transport module.
[    1.598304] RPC: Registered udp transport module.
[    1.598342] RPC: Registered tcp transport module.
[    1.598379] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.598749] Trying to unpack rootfs image as initramfs...
[    1.899075] Freeing initrd memory: 4460K
[    1.900200] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.903121] Initialise system trusted keyring
[    1.917364] VFS: Disk quotas dquot_6.6.0
[    1.917733] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.920528] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.924020] NFS: Registering the id_resolver key type
[    1.924123] Key type id_resolver registered
[    1.924163] Key type id_legacy registered
[    1.924221] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.924346] ntfs: driver 2.1.32 [Flags: R/W].
[    1.925332] JFS: nTxBlock = 7834, nTxLock = 62673
[    1.934953] SGI XFS with security attributes, no debug enabled
[    1.944360] NET: Registered protocol family 38
[    1.944454] Key type asymmetric registered
[    1.944504] Asymmetric key parser 'x509' registered
[    1.944939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.945277] io scheduler noop registered
[    1.945338] io scheduler deadline registered
[    1.945451] io scheduler cfq registered (default)
[    1.948662] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    1.953807] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    1.954258] rk-vcodec 20020000.vpu-service: probe device
[    1.954728] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    1.956089] rk-vcodec 20020000.vpu-service: could not find power_model node
[    1.956153] rk-vcodec 20020000.vpu-service: init success
[    1.956674] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    1.961071] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.961138] dma-pl330 110f0000.pdma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.962304] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    1.962855] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    1.962874] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    1.962891] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    1.962905] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    1.962919] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    1.962934] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    1.963660] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    1.963684] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    1.963701] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    1.963715] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    1.963728] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    1.963743] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    1.964791] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.965649] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    3.032555] console [ttyS2] enabled
[    3.037970] [drm] Initialized drm 1.1.0 20060810
[    3.045251] [drm] Rockchip DRM driver version: v1.0.1
[    3.050637] rockchip-drm display-subsystem: devfreq is not set
[    3.057287] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d111b0)
[    3.065130] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    3.071839] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.079754] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    3.090740] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    3.098278] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.104952] [drm] No driver support for vblank timestamp query.
[    3.111031] rockchip-drm display-subsystem: failed to parse display resources
[    3.738735] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    3.739360] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    3.739368] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    3.739375] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    3.739381] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    3.739388] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    3.739462] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    3.739468] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    3.739475] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    3.739482] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    3.739488] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    3.739495] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    3.739502] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    3.739508] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    3.739514] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    3.739522] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    3.813952] Console: switching to colour frame buffer device 240x67
[    3.985499] rockchip-drm display-subsystem: fb0:  frame buffer device
[    4.010693] brd: module loaded
[    4.025861] loop: module loaded
[    4.029285] lkdtm: No crash points registered, enable through debugfs
[    4.038717] libphy: Fixed MDIO Bus: probed
[    4.043084] tun: Universal TUN/TAP device driver, 1.6
[    4.048344] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.055146] CAN device driver interface
[    4.060698] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    4.068145] rk_gmac-dwmac 30200000.ethernet: TX delay(0x26).
[    4.074031] rk_gmac-dwmac 30200000.ethernet: RX delay(0x11).
[    4.079941] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    4.086609] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    4.098892] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    4.139561] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    4.144838]  Ring mode enabled
[    4.148051]  DMA HW capability register supported
[    4.152769]  Normal descriptors
[    4.156234]  RX Checksum Offload Engine supported (type 2)
[    4.161915]  TX Checksum insertion supported
[    4.166348]  Wake-Up On Lan supported
[    4.179754] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: ee:5b:2a:c3:d3:47
[    4.197995] eth%d: device MAC address ee:5b:2a:c3:d3:47
[    4.213026]  Enable RX Mitigation via HW Watchdog Timer
[    4.228312] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    4.670567] libphy: stmmac: probed
[    4.683970] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    4.700351] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    4.716009] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    4.731486] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    4.746782] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    4.761903] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    4.776883] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    4.791685] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    4.806303] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    4.820881] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    4.835378] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    4.849955] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    4.864390] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    4.878729] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    4.892920] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    4.906941] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    4.920826] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    4.934549] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    4.948077] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    4.961425] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    4.974626] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    4.987645] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    5.000506] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    5.013258] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    5.025828] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    5.038236] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    5.050393] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    5.062416] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    5.074377] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    5.086318] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    5.098222] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    5.110076] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    5.123812] PPP generic driver version 2.4.2
[    5.134519] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    5.146406] usbcore: registered new interface driver at76c50x-usb
[    5.158760] usbcore: registered new interface driver rtl8187
[    5.170588] usbcore: registered new interface driver rndis_wlan
[    5.182610] usbcore: registered new interface driver zd1201
[    5.194527] usbcore: registered new interface driver rt2800usb
[    5.206502] Rockchip WiFi SYS interface (V1.00) ...
[    5.217493] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    5.230983] usbcore: registered new interface driver pegasus
[    5.242736] usbcore: registered new interface driver rtl8150
[    5.254349] usbcore: registered new interface driver r8152
[    5.265779] usbcore: registered new interface driver asix
[    5.276935] usbcore: registered new interface driver ax88179_178a
[    5.288699] usbcore: registered new interface driver cdc_ether
[    5.300110] usbcore: registered new interface driver dm9601
[    5.311184] usbcore: registered new interface driver smsc75xx
[    5.322315] usbcore: registered new interface driver smsc95xx
[    5.333292] usbcore: registered new interface driver net1080
[    5.344104] usbcore: registered new interface driver rndis_host
[    5.355187] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    5.367914] usbcore: registered new interface driver cdc_ncm
[    5.378775] usbcore: registered new interface driver cdc_mbim
[    5.390099] 30040000.usb supply vusb_d not found, using dummy regulator
[    5.401963] 30040000.usb supply vusb_a not found, using dummy regulator
[    5.427054] dwc2 30040000.usb: DWC OTG Controller
[    5.436981] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    5.449234] dwc2 30040000.usb: irq 48, io mem 0x30040000
[    5.459948] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.471916] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.484323] usb usb1: Product: DWC OTG Controller
[    5.494049] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    5.505307] usb usb1: SerialNumber: 30040000.usb
[    5.516030] hub 1-0:1.0: USB hub found
[    5.524869] hub 1-0:1.0: 1 port detected
[    5.535315] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.546964] ehci-platform: EHCI generic platform driver
[    5.559883] ehci-platform 30080000.usb: EHCI Host Controller
[    5.571238] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    5.584807] ehci-platform 30080000.usb: irq 49, io mem 0x30080000
[    5.607497] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    5.619565] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.632027] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.644979] usb usb2: Product: EHCI Host Controller
[    5.655610] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    5.667554] usb usb2: SerialNumber: 30080000.usb
[    5.679218] hub 2-0:1.0: USB hub found
[    5.689131] hub 2-0:1.0: 1 port detected
[    5.702227] ehci-platform 300c0000.usb: EHCI Host Controller
[    5.714635] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    5.729197] ehci-platform 300c0000.usb: irq 51, io mem 0x300c0000
[    5.751503] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    5.764539] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    5.778003] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.791920] usb usb3: Product: EHCI Host Controller
[    5.803585] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    5.816602] usb usb3: SerialNumber: 300c0000.usb
[    5.829413] hub 3-0:1.0: USB hub found
[    5.840335] hub 3-0:1.0: 1 port detected
[    5.854402] ehci-platform 30100000.usb: EHCI Host Controller
[    5.867970] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    5.883647] ehci-platform 30100000.usb: irq 53, io mem 0x30100000
[    5.907490] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    5.921521] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    5.936023] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.951030] usb usb4: Product: EHCI Host Controller
[    5.963723] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    5.977651] usb usb4: SerialNumber: 30100000.usb
[    5.991239] hub 4-0:1.0: USB hub found
[    6.002894] hub 4-0:1.0: 1 port detected
[    6.015535] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    6.029692] ohci-platform: OHCI generic platform driver
[    6.043365] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    6.058697] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    6.075023] ohci-platform 300a0000.usb: irq 50, io mem 0x300a0000
[    6.147754] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    6.162659] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.178000] usb usb5: Product: Generic Platform OHCI controller
[    6.192126] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    6.206498] usb usb5: SerialNumber: 300a0000.usb
[    6.220653] hub 5-0:1.0: USB hub found
[    6.232938] hub 5-0:1.0: 1 port detected
[    6.246206] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    6.262029] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    6.278924] ohci-platform 300e0000.usb: irq 52, io mem 0x300e0000
[    6.351720] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    6.367506] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.383714] usb usb6: Product: Generic Platform OHCI controller
[    6.398660] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    6.413839] usb usb6: SerialNumber: 300e0000.usb
[    6.428612] hub 6-0:1.0: USB hub found
[    6.441572] hub 6-0:1.0: 1 port detected
[    6.455771] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    6.472260] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    6.489573] ohci-platform 30120000.usb: irq 54, io mem 0x30120000
[    6.563741] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    6.579692] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.596003] usb usb7: Product: Generic Platform OHCI controller
[    6.610979] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    6.626127] usb usb7: SerialNumber: 30120000.usb
[    6.631488] usb 5-1: new low-speed USB device number 2 using ohci-platform
[    6.656913] hub 7-0:1.0: USB hub found
[    6.669943] hub 7-0:1.0: 1 port detected
[    6.684018] usbcore: registered new interface driver cdc_acm
[    6.698868] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    6.716350] usbcore: registered new interface driver cdc_wdm
[    6.731696] usbcore: registered new interface driver usb-storage
[    6.747177] usbcore: registered new interface driver usbserial
[    6.762245] usbcore: registered new interface driver usbserial_generic
[    6.777906] usbserial: USB Serial support registered for generic
[    6.793290] usbcore: registered new interface driver keyspan
[    6.808101] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    6.825165] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    6.841743] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    6.855524] usb 5-1: New USB device found, idVendor=1a2c, idProduct=0b23
[    6.855533] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.855540] usb 5-1: Product: USB Keyboard
[    6.855546] usb 5-1: Manufacturer: USB
[    6.916290] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    6.932931] usbcore: registered new interface driver option
[    6.947711] usbserial: USB Serial support registered for GSM modem (1-port)
[    6.964716] usbcore: registered new interface driver oti6858
[    6.979645] usbserial: USB Serial support registered for oti6858
[    6.994995] usbcore: registered new interface driver qcserial
[    7.010020] usbserial: USB Serial support registered for Qualcomm USB modem
[    7.026520] usbcore: registered new interface driver sierra
[    7.041468] usbserial: USB Serial support registered for Sierra USB modem
[    7.058805] usbcore: registered new interface driver iforce
[    7.074054] usbcore: registered new interface driver xpad
[    7.089152] usbcore: registered new interface driver usbtouchscreen
[    7.106065] i2c /dev entries driver
[    7.121949] usbcore: registered new interface driver uvcvideo
[    7.137048] USB Video Class driver (1.1.1)
[    7.152565] Boot mode: normal
[    7.166193] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    7.184438] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    7.202936] Bluetooth: Virtual HCI driver ver 1.5
[    7.217585] Bluetooth: HCI UART driver ver 2.3
[    7.231508] Bluetooth: HCI UART protocol H4 registered
[    7.246029] Bluetooth: HCI UART protocol LL registered
[    7.260449] Bluetooth: HCI UART protocol ATH3K registered
[    7.275053] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    7.290660] Bluetooth: HCI UART protocol BCM registered
[    7.305204] usbcore: registered new interface driver bfusb
[    7.319967] usbcore: registered new interface driver btusb
[    7.334467] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    7.349839] cpu cpu0: leakage=4
[    7.362044] cpu cpu0: leakage-volt-sel=0
[    7.375162] cpu cpu0: Failed to get pvtm
[    7.389777] cpu cpu0: avs=0
[    7.401536] cpu cpu0: scale_rate=1392000000
[    7.414763] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    7.430607] cpu cpu0: failed to read out thermal zone (-22)
[    7.445700] cpu cpu0: failed to find power_model node
[    7.457111] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    7.457129] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    7.457150] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    7.457529] Synopsys Designware Multimedia Card Interface Driver
[    7.470053] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    7.483258] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    7.495871] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    7.507384] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    7.522953] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    7.534952] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    7.546975] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    7.546987] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    7.547031] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    7.547080] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    7.547090] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    7.557804] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    7.557816] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    7.557827] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    7.557836] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    7.557843] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    7.557855] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    7.570717] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    7.598801] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    7.611764] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    7.627789] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    7.641736] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    7.655168] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    7.667615] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    7.684422] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    7.696900] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    7.709290] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    7.709307] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    7.709322] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    7.709332] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    7.709340] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    7.709351] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    7.709443] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    7.734299] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    7.762540] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    7.767821] mmc_host mmc0: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[    7.767933] mmc0: new high speed SD card at address e624
[    7.769208] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[    7.771619]  mmcblk0: p1
[    7.830246] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    7.844659] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    7.858447] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    7.871240] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    7.887370] dwmmc_rockchip 30020000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    7.901798] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    7.914282] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    7.926715] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    7.926731] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    7.926744] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    7.926754] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    7.926761] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    7.926773] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    7.939565] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    7.963694] mmc_host mmc1: Bus speed (slot 0) = 35714286Hz (slot req 37500000Hz, actual 35714286HZ div = 0)
[    7.967904] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    7.968450] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led_blue[0]' - status (0)
[    7.968718] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led_red[0]' - status (0)
[    7.969011] ledtrig-cpu: registered to indicate activity on CPUs
[    7.969221] hidraw: raw HID events driver (C) Jiri Kosina
[    7.982716] input: USB USB Keyboard as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:1A2C:0B23.0001/input/input0
[    8.004483] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[    8.036840] hid-generic 0003:1A2C:0B23.0001: input,hidraw0: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-300a0000.usb-1/input0
[    8.044535] input: USB USB Keyboard as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:1A2C:0B23.0002/input/input1
[    8.095954] hid-generic 0003:1A2C:0B23.0002: input,hidraw1: USB HID v1.10 Mouse [USB USB Keyboard] on usb-300a0000.usb-1/input1
[    8.096242] mmc1: new high speed SDIO card at address 0001
[    8.127860] usbcore: registered new interface driver usbhid
[    8.140764] usbhid: USB HID core driver
[    8.152393] ashmem: initialized
[    8.163598] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[    8.178860] rockchip-dmc dmc: no ATF memory for init
[    8.190868] rockchip-dmc: probe of dmc failed with error -12
[    8.204757] rknandbase v1.2 2018-05-08
[    8.216488] usbcore: registered new interface driver snd-usb-audio
[    8.229752] usbcore: registered new interface driver snd-ua101
[    8.242539] usbcore: registered new interface driver snd-usb-caiaq
[    8.255770] usbcore: registered new interface driver snd-usb-6fire
[    8.269008] usbcore: registered new interface driver snd-usb-hiface
[    8.282221] usbcore: registered new interface driver snd-bcd2000
[    8.295052] usbcore: registered new interface driver snd_usb_pod
[    8.307793] usbcore: registered new interface driver snd_usb_podhd
[    8.320815] usbcore: registered new interface driver snd_usb_toneport
[    8.334083] usbcore: registered new interface driver snd_usb_variax
[    8.351179] u32 classifier
[    8.360625]     input device check on
[    8.370970]     Actions configured
[    8.381046] Netfilter messages via NETLINK v0.30.
[    8.392504] nfnl_acct: registering with nfnetlink.
[    8.404104] nf_conntrack version 0.5.0 (15668 buckets, 62672 max)
[    8.417734] Initializing XFRM netlink socket
[    8.429531] NET: Registered protocol family 10
[    8.441948] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    8.454549] sit: IPv6 over IPv4 tunneling driver
[    8.466674] NET: Registered protocol family 17
[    8.477839] NET: Registered protocol family 15
[    8.489029] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    8.508448] Bridge firewalling registered
[    8.519318] can: controller area network core (rev 20120528 abi 9)
[    8.532458] NET: Registered protocol family 29
[    8.543660] can: raw protocol (rev 20120528)
[    8.554667] can: broadcast manager protocol (rev 20120528 t)
[    8.567130] can: netlink gateway (rev 20130117) max_hops=1
[    8.580563] Bluetooth: RFCOMM TTY layer initialized
[    8.592274] Bluetooth: RFCOMM socket layer initialized
[    8.604291] Bluetooth: RFCOMM ver 1.11
[    8.614788] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    8.627340] Bluetooth: HIDP socket layer initialized
[    8.639435] 8021q: 802.1Q VLAN Support v1.8
[    8.654004] lib80211: common routines for IEEE802.11 drivers
[    8.669924] lib80211_crypt: registered algorithm 'NULL'
[    8.669958] lib80211_crypt: registered algorithm 'WEP'
[    8.669997] lib80211_crypt: registered algorithm 'CCMP'
[    8.670019] lib80211_crypt: registered algorithm 'TKIP'
[    8.670054] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    8.683431] dwmmc_rockchip 30020000.dwmmc: Unexpected interrupt latency
[    8.699425] dwmmc_rockchip 30020000.dwmmc: Unexpected interrupt latency
[    8.715436] dwmmc_rockchip 30020000.dwmmc: Unexpected interrupt latency
[    8.730572] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    8.741757] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ssv6051
[    8.755090] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    8.767424] dwmmc_rockchip 30020000.dwmmc: Unexpected interrupt latency
[    8.781531] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    8.795265] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    8.795278] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    8.795286] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    8.795324] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    8.795335] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 0.
[    8.810862] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    8.824473] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    8.836099] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    8.847208] [BT_RFKILL]: Enter rfkill_rk_init
[    8.858173] Key type dns_resolver registered
[    8.869132] flash vendor_init_thread!
[    8.869289] Error: Driver 'sc031gs' is already registered, aborting...
[    8.870376] Registering SWP/SWPB emulation handler
[    8.874949] dwmmc_rockchip 30020000.dwmmc: Successfully tuned phase to 199
[    8.875086] mmc2: new HS200 MMC card at address 0001
[    8.876232] mmcblk2: mmc2:0001 8GME4R 7.28 GiB
[    8.876800] mmcblk2boot0: mmc2:0001 8GME4R partition 1 4.00 MiB
[    8.877401] mmcblk2boot1: mmc2:0001 8GME4R partition 2 4.00 MiB
[    8.877935] mmcblk2rpmb: mmc2:0001 8GME4R partition 3 512 KiB
[    8.880342] registered taskstats version 1
[    8.880362] Loading compiled-in X.509 certificates
[    8.880418]  mmcblk2: p1
[    8.883454] Btrfs loaded
[    8.884527] rga2: Driver loaded successfully ver:4.01
[    8.884735] rga2: Module initialized.
[    8.884761] pvtm list NULL
[    8.885841] rk-vcodec 20030000.rkvdec: leakage=3
[    8.885859] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0
[    8.885977] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    8.886410] rk-vcodec 20030000.rkvdec: avs=0
[    8.886714] rk-vcodec 20030000.rkvdec: probe device
[    8.887223] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    8.888814] rk-vcodec 20030000.rkvdec: init success
[    8.889683] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    8.889693] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    8.890907] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    8.893587] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    8.893593] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    8.894551] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    8.896563] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/power-key[0]' - status (-22)
[    8.896573] gpio-keys gpio_keys: Failed to get gpio flags, error: -22
[    8.896598] gpio-keys: probe of gpio_keys failed with error -22
[    8.896666] hctosys: unable to open rtc device (rtc0)
[    8.909156] ALSA device list:
[    8.909165]   #0: DW-I2S-HDMI
[    8.909167]   #1: SPDIF
[    9.191023] flash vendor storage:20170308 ret = -1
[    9.201600] ttyS2 - failed to request DMA, use interrupt mode
[    9.213803] Freeing unused kernel memory: 796K
[    9.223735] This architecture does not have kernel memory protection.
[    9.373626] vendor storage:20190527 ret = 0
[   10.321737] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   11.193353] systemd[1]: System time before build time, advancing clock.
[   11.221832] systemd[1]: Inserted module 'autofs4'
[   11.246153] ip_tables: (C) 2000-2006 Netfilter Core Team
[   11.275772] cgroup: cgroup2: unknown option "nsdelegate"
[   11.311000] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   11.346241] systemd[1]: Detected architecture arm.
[   11.376806] systemd[1]: Set hostname to <rk322x-box>.
[   11.730314] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   11.756762] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   12.188856] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[   12.214446] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[   12.235769] systemd[1]: Created slice system-getty.slice.
[   12.263693] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[   12.281585] systemd[1]: Listening on fsck to fsckd communication Socket.
[   12.307699] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[   12.325763] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.351716] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[   12.380048] systemd[1]: Listening on Syslog Socket.
[   12.407730] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[   12.428584] systemd[1]: Created slice User and Session Slice.
[   12.455672] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[   12.473615] systemd[1]: Reached target Slices.
[   12.510342] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   12.527383] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[   12.548641] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   12.575770] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[   12.595130] systemd[1]: Listening on Journal Socket.
[   12.616200] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[   12.640130] systemd[1]: Mounting POSIX Message Queue File System...
[   12.670760] systemd[1]: Starting Restore / save the current clock...
[   12.702615] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   12.732435] systemd[1]: Listening on udev Kernel Socket.
[   12.760889] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   12.778736] systemd[1]: Reached target Swap.
[   12.806505] systemd[1]: Starting Nameserver information manager...
[   12.832165] systemd[1]: Reached target Remote File Systems.
[   12.860259] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   12.893748] systemd[1]: Starting Set the console keyboard layout...
[   12.920090] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[   12.946940] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   12.968076] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.995900] systemd[1]: Reached target Paths.
[   13.015997] systemd[1]: Reached target Local Encrypted Volumes.
[   13.044430] systemd[1]: Reached target System Time Synchronized.
[   13.075913] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   13.107617] systemd[1]: Starting Remount Root and Kernel File Systems...
[   13.144602] systemd[1]: Mounting Kernel Debug File System...
[   13.184727] systemd[1]: Starting Load Kernel Modules...
[   13.202417] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   13.224760] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   13.252819] systemd[1]: Listening on udev Control Socket.
[   13.281943] systemd[1]: Starting udev Coldplug all Devices...
[   13.314914] systemd[1]: Mounted POSIX Message Queue File System.
[   13.343565] systemd[1]: Started Restore / save the current clock.
[   13.386431] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   13.424084] systemd[1]: Started Set the console keyboard layout.
[   13.455087] systemd[1]: Started Remount Root and Kernel File Systems.
[   13.484673] systemd[1]: Mounted Kernel Debug File System.
[   13.514627] systemd[1]: Started Load Kernel Modules.
[   13.552868] systemd[1]: Started Nameserver information manager.
[   13.596444] systemd[1]: Mounting Kernel Configuration File System...
[   13.636791] systemd[1]: Starting Apply Kernel Variables...
[   13.668485] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   13.694019] systemd[1]: Starting Load/Save Random Seed...
[   13.724171] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   13.731768] systemd[1]: Starting Create System Users...
[   13.748034] systemd[1]: Mounted Kernel Configuration File System.
[   13.761171] systemd[1]: Started Apply Kernel Variables.
[   13.773415] systemd[1]: Started Load/Save Random Seed.
[   13.828629] systemd[1]: Started Create System Users.
[   13.841818] systemd[1]: Starting Create Static Device Nodes in /dev...
[   13.913980] systemd[1]: Started Create Static Device Nodes in /dev.
[   13.924462] systemd[1]: Reached target Local File Systems (Pre).
[   13.942369] systemd[1]: Mounting /tmp...
[   13.958539] systemd[1]: Starting udev Kernel Device Manager...
[   13.974659] systemd[1]: Started udev Coldplug all Devices.
[   13.988811] systemd[1]: Mounted /tmp.
[   13.996651] systemd[1]: Reached target Local File Systems.
[   14.013068] systemd[1]: Starting Armbian ZRAM config...
[   14.024136] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   14.032238] systemd[1]: Starting Set console font and keymap...
[   14.054793] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   14.073609] systemd[1]: Started Set console font and keymap.
[   14.104484] systemd[1]: Started Helper to synchronize boot up for ifupdown.
[   14.124486] systemd[1]: Starting Raise network interfaces...
[   14.201096] systemd[1]: Started udev Kernel Device Manager.
[   14.343133] zram: Added device: zram0
[   14.350495] zram: Added device: zram1
[   14.352299] zram: Added device: zram2
[   14.583131] zram1: detected capacity change from 0 to 513826816
[   14.629460] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[   14.629497] systemd[1]: Found device /dev/ttyS2.
[   14.629507] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[   14.629518] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[   14.629562] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[   14.629650] rk3228-codec 12010000.codec: spk_depop_time use default value.
[   14.630927] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[   14.630966] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[   14.656893] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '17:33:02', on 'Apr  9 2020'.
[   14.657250] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[   14.657276] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[   14.657287] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[   14.657297] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[   14.657309] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[   14.657318] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[   14.657327] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[   14.657338] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[   14.657348] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[   14.657358] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[   14.657368] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[   14.657377] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[   14.657400] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[   14.657415] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[   14.657427] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[   14.657785] mali-utgard 20001000.gpu: leakage=3
[   14.657818] mali-utgard 20001000.gpu: leakage-volt-sel=0
[   14.657936] mali-utgard 20001000.gpu: Failed to get pvtm
[   14.658481] mali-utgard 20001000.gpu: avs=0
[   14.659848] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[   14.662420] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[   14.668170] Mali: Mali device driver loaded
[   14.688426] systemd[1]: Started Raise network interfaces.
[   14.755606] devfreq 20001000.gpu: Couldn't update frequency transition information.
[   15.170942] generic_wifi_init_module
[   15.447697]
               *** sta_cfg_set, /etc/firmware/ssv6051-wifi.cfg ***
[   15.457660] ssv6xxx_sdio_init
[   15.463549] =======================================
[   15.463594] ==           RUN SDIO                ==
[   15.463601] =======================================
[   15.463619] ssv6xxx_set_sdio_clk:set sdio clk 25000000Hz
[   15.463727] mmc_host mmc1: Bus speed (slot 0) = 25000000Hz (slot req 25000000Hz, actual 25000000HZ div = 0)
[   15.482060] cfg80211: World regulatory domain updated:
[   15.482074] cfg80211:  DFS Master region: unset
[   15.482075] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   15.482086] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.482093] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   15.482096] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   15.482102] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   15.482106] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   15.482110] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   15.482114] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   15.482119] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   15.483852] SSV6XXX_SDIO mmc1:0001:1: vendor = 0x3030 device = 0x3030
[   15.494901] ssv6xxx_sdio_power_on
[   15.507736] SSV6XXX_SDIO mmc1:0001:1: dataIOPort 0x10000 regIOPort 0x10020
[   15.508349] ssv6xxx_dev_probe(): ssv6200 device found !
[   15.508875] ssv6xxx_sdio_irq_disable
[   15.509650] MAC address from e-fuse
[   15.509653] EFUSE configuration
[   15.509662] Read efuse chip identity[75000000]
[   15.509664] r_calbration_result- 0
[   15.509665] sar_result- 0
[   15.509666] crystal_frequency_offset- 0
[   15.509668] tx_power_index_1- 0
[   15.509669] tx_power_index_2- 0
[   15.509676] MAC address - 3c:cf:5b:13:4b:f5
[   15.509976] Registering Vendor80211
[   15.509983] Register SSV cfg80211 vendor cmd(0x67) interface
[   15.510090] [MT-ENCRYPT]: create kthread e638d540 for CPU 0, ret = 0
[   15.510199] SSV WLAN driver ssv6200: Crypto task 440 running with priority 120.
[   15.510227] [MT-ENCRYPT]: create kthread e638dd00 for CPU 1, ret = 0
[   15.510334] [MT-ENCRYPT]: create kthread e638e4c0 for CPU 2, ret = 0
[   15.510362] SSV WLAN driver ssv6200: Crypto task 442 running with priority 120.
[   15.510435] [MT-ENCRYPT]: create kthread e638ec80 for CPU 3, ret = 0
[   15.510476] SSV WLAN driver ssv6200: Crypto task 443 running with priority 120.
[   15.510564] SSV6XXX TX Task started.
[   15.510639] Pre-load cipher
[   15.510649] SSV6XXX RX Task started.
[   15.510844] flash_file /tmp/flash.bin not found, disable sar
[   15.510848] SSV6051P setting
[   15.510853] SSV6XXX_IQK_CFG_XTAL_24M
[   15.510861] SSV6051P setting [0x6C726C72]
[   15.510865] TX power setting 0x6c726c72
[   15.510866] Volt regulator LDO
[   15.512301] reset PLL
[   15.516484] SSV WLAN driver ssv6200: Crypto task 441 running with priority 120.
[   15.531011] ieee80211 phy0: Selected rate control algorithm 'ssv6xxx_rate_control'
[   15.534570] ieee80211 phy0: SSV6200 of South Silicon Valley
[   15.665051] Adding 501780k swap on /dev/zram1.  Priority:5 extents:1 across:501780k SS
[   15.797548] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   15.808289] systemd[1]: Reached target Sound Card.
[   15.822805] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   15.870836] zram0: detected capacity change from 0 to 52428800
[   16.099098] systemd[1]: Started Load/Save RF Kill Switch Status.
[   17.989773] systemd[1]: Started Armbian ZRAM config.
[   18.011802] systemd[1]: Starting Armbian memory supported logging...
[   18.126005] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   21.102873] systemd[1]: systemd-rfkill.service: Succeeded.
[   21.109398] random: nonblocking pool is initialized
[   21.425425] systemd[1]: Started Armbian memory supported logging.
[   21.442743] systemd[1]: Starting Journal Service...
[   21.879087] systemd[1]: Started Journal Service.
[   21.958213] systemd-journald[556]: Received request to flush runtime journal from PID 1
[   23.956599] nr_pdflush_threads exported in /proc is scheduled for removal
[   25.013724] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   25.122874] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[   25.123683] SVN version 16529
[   25.123735] SVN ROOT URL http://192.168.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx
[   25.123746] COMPILER HOST icomm-buildserver-T320
[   25.123752] COMPILER DATE 12-08-2017-10:34:54
[   25.123759] COMPILER OS linux
[   25.123770] COMPILER OS ARCH x86_64-linux-gnu-thread-multi
[   25.125184] CHIP TAG: 2014012420010960
[   25.126090] CHIP ID: RSV6200A0-201311
[   25.139713] 0x800e0000
[   25.212066] ADR_INFO_IDX_ADDR[80000230] ADR_INFO_LEN_ADDR[800002cc]
[   25.216408] Writing firmware to SSV6XXX...
[   25.230360] (block_count << 16) = 500000,reg =500000
[   25.230437] Firmware "/etc/firmware/ssv6051-sw.bin" loaded
[   25.283760] Firmware check OK.d0000 = d0000
[   25.339522] Firmware name cfgfirmwarepath=/etc/firmware/ssv6051-sw.bin
[   25.339935] Firmware version 16380
[   25.339964] ssv6xxx_watchdog_controller 6
[   25.340313] ssv6xxx_sdio_irq_enable
[   25.340587] # Do init_cali (iq)
[   25.340848] FW TX LOOPBACK OK
[   25.508096] FW TX LOOPBACK OK
[   25.508168] +++++++++++++++++++++++++++222222222222222!!
[   25.508435] ssv6200_start(): current channel: 1,sc->ps_status=0
[   25.512288] ssv6200_add_interface(): vif->type = 2, NL80211_IFTYPE_AP=3
[   25.512321] ssv6xxx_config_vif_res id[0].
[   25.512347] SSV WLAN driver ssv6200: VIF 3c:cf:5b:13:4b:f4 of type 2 is added.
[   25.512397] BSS Changed use_short_preamble[0]
[   25.512405] BSS_CHANGED_ERP_SLOT: use_short_slot[0]
[   25.512843] NL80211_IFTYPE_STATION!!
[   25.512869] ssv6200_bss_info_changed(): leave
[   25.512917] sv6200_conf_tx vif[0] qos[0] queue[0] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.513218] sv6200_conf_tx vif[0] qos[0] queue[1] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.513513] sv6200_conf_tx vif[0] qos[0] queue[2] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.513832] sv6200_conf_tx vif[0] qos[0] queue[3] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.514107] NL80211_IFTYPE_STATION!!
[   25.514136] ssv6200_bss_info_changed(): leave
[   25.514156] Disable IEEE80211_CONF_PS ps_aid=0
[   25.514363] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[   25.581422] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   25.582185] ssv6200_add_interface(): vif->type = 2, NL80211_IFTYPE_AP=3
[   25.582214] ssv6xxx_config_vif_res id[1].
[   25.582239] SSV WLAN driver ssv6200: VIF 3c:cf:5b:13:4b:f5 of type 2 is added.
[   25.582299] BSS Changed use_short_preamble[0]
[   25.582316] NL80211_IFTYPE_STATION!!
[   25.582327] ssv6200_bss_info_changed(): leave
[   25.582362] sv6200_conf_tx vif[1] qos[0] queue[0] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.582389] SSV WLAN driver ssv6200: WMM setting applicable to primary interface only.
[   25.582403] sv6200_conf_tx vif[1] qos[0] queue[1] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.582424] SSV WLAN driver ssv6200: WMM setting applicable to primary interface only.
[   25.582435] sv6200_conf_tx vif[1] qos[0] queue[2] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.582448] SSV WLAN driver ssv6200: WMM setting applicable to primary interface only.
[   25.582468] sv6200_conf_tx vif[1] qos[0] queue[3] aifsn[2] cwmin[15] cwmax[1023] txop[0]
[   25.582480] SSV WLAN driver ssv6200: WMM setting applicable to primary interface only.
[   25.582491] NL80211_IFTYPE_STATION!!
[   25.582498] ssv6200_bss_info_changed(): leave
[   25.582816] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   25.987823] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   26.019194] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[   27.076083] rk_gmac-dwmac 30200000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
root@rk322x-box:~#
  Then everything is true, replacing the bootloader by the method @hexdump allows you to boot from SD without erasing eMMC, but will not allow you to transfer the system.
I did not know before.
