Zaerc Posted February 25, 2024 Posted February 25, 2024 So I was messing around with my new OrangePi-5+ and installed the EDK2 UEFI firmware for Rockchip RK3588 platforms onto the SPI flash (/dev/mtdblock0). After which I tried all sorts of images and kernels with varying success, only the 5.10.160-legacy-rk3588 kernel would really have a working display. Until I tried a generic UEFI arm64 image (Jammy-CLI on a USB stick) which gave a working display, albeit at 1080p max. (my monitor is 4K) with no acceleration (after the extra steps), and installed the Mate desktop (just my preference). The big caveat is that it does not recognize the SD-card, EMMC or SPI-flash, just regular drives (e.g. sda/nvme0n1 etc) and I'm sure a lot of other hardware isn't properly recognized either. But all of that was fixed by simply installing the old legacy kernel with apt, making a symbolic link to the correct dtb in /boot and updating grub, and a reboot later everything worked fine, the desktop popped up in 4K with acceleration and all. In the end I installed the whole thing to an NVME with armbian-config, which didn't create the separate EFI partition, so I had to corrected it manually, but that is another story. What surprises me is that the UEFI-arm64 kernel does not seem to need a Device-Tree-Blob, in fact it doesn't even boot with its own rk3588-orangepi-5-plus.dtb. Anyway if anyone want's to try this I'd suggest using Balena etcher to write the ED2K firmware onto an SD-card, and a generic UEFI armbian to an USB stick so you won't have to mess up anything permanently. Plug the stick in a USB2 port as it chokes during boot on the USB3 (blue) ports. And you will need a lot of patience as booting from a USB2 stick will be rather slow to say the least. Install legacy kernel: sudo apt update sudo apt install linux-image-legacy-rk35xx Create the symbolic link: (If you try this on another board or with another kernel version, you will need to adjust the link for the appropriate DTB instead) sudo ln -s /usr/lib/linux-image-5.10.160-legacy-rk35xx/rockchip/rk3588-orangepi-5-plus.dtb /boot/dtb-5.10.160-legacy-rk35xx Bonus tip, set the legacy kernel as a GRUB's default: (optional, adjust for different kernels) sudo echo 'GRUB_DEFAULT="Armbian GNU/Linux, with Linux 5.10.160-legacy-rk35xx"' > /etc/default/grub.d/99-legacy.cfg GRUB should now automatically pick up on the DTB after updating: sudo update-grub So far the only downside I have found is that the audio outputs are all labeled "Built-in Audio Stereo", which was easy to solve by adding some udev-rules as the Armbian build system does when building a regular OrangePi-5+ image. Spoiler Put the following lines in /etc/udev/rules.d/90-naming-audios.rules: SUBSYSTEM=="sound", ENV{ID_PATH}=="platform-hdmi0-sound", ENV{SOUND_DESCRIPTION}="HDMI0 Audio" SUBSYSTEM=="sound", ENV{ID_PATH}=="platform-hdmi1-sound", ENV{SOUND_DESCRIPTION}="HDMI1 Audio" SUBSYSTEM=="sound", ENV{ID_PATH}=="platform-hdmiin-sound", ENV{SOUND_DESCRIPTION}="HDMI-In Audio" SUBSYSTEM=="sound", ENV{ID_PATH}=="platform-dp0-sound", ENV{SOUND_DESCRIPTION}="DP0 Audio" SUBSYSTEM=="sound", ENV{ID_PATH}=="platform-es8388-sound", ENV{SOUND_DESCRIPTION}="ES8388 Audio" 0 Quote
maka Posted February 27, 2024 Posted February 27, 2024 (edited) Quote What surprises me is that the UEFI-arm64 kernel does not seem to need a Device-Tree-Blob, in fact it doesn't even boot with its own rk3588-orangepi-5-plus.dtb. Actually the kernel needs a dtb that is integrated in the UEFI EDK2 firmware and gives the dtb to the kernel EFI stub. If you are using a firmware for another SBC the dtb passed through is wrong. Wait a minute.... I'm wrong. EDK2 gives it's own drivers to the kernel. The above is for UEFI U-BOOT. Edited February 27, 2024 by maka 1 Quote
ozacas Posted March 26, 2024 Posted March 26, 2024 (edited) Hi, i went a slightly different route and built a custom image for UEFI support based on current amazingfate armbian build framework (edge kernel 6.8.1 with EDK2 0.9.1) which works well - with NVME boot support based on your instructions above. I needed to enable USB2 support in UEFI settings for the slow usb stick boot, but i've ended up with a nicely working grub on an arm64 box which feels weird 😁 ... but lovely! https://paste.armbian.com/obowabadak has the output from armbianmonitor -u I did get a kernel stack trace about 8s into the kernel boot, but doesnt seem to impact anything. In my case I could not get the EDK2 img md5sum to match during the SPI flash... same result everytime. I just assumed a bit of trailing garbage was the culprit and it booted anyway 🤪 Edited March 26, 2024 by ozacas just clarification 0 Quote
Hooutoo Posted July 31, 2024 Posted July 31, 2024 Good Morning I presently have loader - rk3588_spl_loader_v1.15.113.bin and uefi - orangepi-5plus_UEFI_Release_v0.11.2.img installed on my opi5+. I have Win11 arm64 installed on a nvme 1tb ssd. I also have a 64gb emmc chip installed giving me effectively 2 disk drives that are recognized by the uefi bios. What I'm hoping for is a linux based OS that can be installed to my emmc via a bootable sdcard or usb drive much like you would on a PC. This would allow me to power up opi5+ hit ESC key to enter bios select the desired drive, be it linux or Win11, and boot. Any ideas would be greatly appreciated. but if you have a link to linux based .img file, even better! 0 Quote
Werner Posted July 31, 2024 Posted July 31, 2024 1 hour ago, Hooutoo said: orangepi-5plus_UEFI_Release_v0.11.2.img I suggest to ask where you got this image from. We cannot help with 3rd party OS. 0 Quote
pageev Posted October 23, 2025 Posted October 23, 2025 https://github.com/manjaro-arm/opi5-plus-images/issues/22#issuecomment-3340442272 0 Quote
