teknoid Posted March 3, 2024 Posted March 3, 2024 no WiFi Adapter after fresh installation. usbcore.autosuspend=-1 fixes it: ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to Armbian 24.2.1 Bookworm with Linux 6.6.16-current-meson64 System load: 46% Up time: 0 min Memory usage: 7% of 1.82G IP: 192.168.25.252 CPU temp: 28°C Usage of /: 66% of 3.0G [ Menu-driven system configuration (beta): sudo apt update && sudo apt install armbian-config ] root@odroid:~# cat /boot/armbianEnv.txt verbosity=1 console=both overlay_prefix=meson rootdev=UUID=1cf10f1a-aa21-4ff0-875d-c59f57c87173 rootfstype=ext4 extraboardargs=fastboot noswap isolcpus=3 usbcore.autosuspend=-1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u root@odroid:~# lsusb Bus 001 Device 007: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T Bus 001 Device 006: ID 7392:7822 Edimax Technology Co., Ltd EW-7612UAn V2 802.11n Wireless Adapter [Realtek RTL8192CU] Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 0 Quote
Scritch Posted March 6, 2024 Posted March 6, 2024 (edited) Since todays update to kernel 6.6 on my odroid c2, usb was broken. lsusb shows that no devices are found anymore using the new kernel: lsusb Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub dmesg shows the following error during boot: [ 5.777103] onboard-usb-hub 1-1: can't set config #1, error -71 Adding the "extraboardargs" option to /boot/armbianEnv.txt as described above, solved the problem for me. Edit: This recent kernel change might be connected: https://lore.kernel.org/lkml/1jleciyahv.fsf@starbuckisacylon.baylibre.com/T/ Edited March 6, 2024 by Scritch 0 Quote
all2 Posted March 20, 2024 Posted March 20, 2024 (edited) I have a rather janky fix for this issue. Basically, we reset all USB devices on the bus after boot. I created a systemd service file with the following contents: $ cat /etc/systemd/system/usb-reset.service [Unit] Description=Reset USB devices before SDDM Before=sddm.service [Service] Type=oneshot ExecStart=/root/usbreset.sh [Install] WantedBy=multi-user.target And the script is this: $ cat ~/usbreset.sh #!/usr/bin/env bash # Resets USB devices in a specified path. # Use with caution, as this may reset devices currently in use. base_path="/sys/bus/usb/devices/" # Function to reset a single USB device reset_usb_device() { dev_path="$1" echo "Resetting device at '$dev_path' ..." echo 0 | sudo tee "$dev_path/authorized" > /dev/null # Deactivate sleep 1 # Short delay echo 1 | sudo tee "$dev_path/authorized" > /dev/null # Reactivate } # Find USB devices echo "Looking for USB devices in '$base_path'..." for dev_path in "$base_path"/* do reset_usb_device "$dev_path" done echo "Done." Enable and start this service and your USB devices will be re-initialized after boot. I've also verified that adding the "extraboardargs" as in the first post works for me as well. Edited March 20, 2024 by all2 0 Quote
blaubarschbube Posted February 8 Posted February 8 On my Gentoo setup, I never had any USB issues before 6.6, even without the usbcore.autosuspend=-1 option. With 6.6, though, USB doesn’t work for me even with that option enabled. The fix from all2 worked for me, so thanks to that I put together what I think is a slightly more robust solution: Quote [Unit] Description=reinitialize USB (dwc2 c9100000.usb) on ODROID-C2 DefaultDependencies=no After=systemd-udev-settle.service Before=sysinit.target [Service] Type=oneshot ExecStart=/bin/sh -c 'echo c9100000.usb > /sys/bus/platform/drivers/dwc2/unbind; sleep 1; echo c9100000.usb > /sys/bus/platform/drivers/dwc2/bind' [Install] WantedBy=sysinit.target 0 Quote
