In my project I want to use UART on GPIO pin (8,10). I wrote a simple Java app to decet serial ports on my orange PC but it return only /dev/ttyS0 - Serial
Here is simple java code using rxtxlibrary..
package org.mbp;
import gnu.io.CommPortIdentifier;
 * @author Peter
public class TestCom {
     * @param args the command line arguments
    public static void main(String[] args) {
        System.out.println("-------------------------------");
        System.out.println(System.getProperty("java.version"));
        System.out.println(System.getProperty("os.name"));
        java.util.Enumeration<CommPortIdentifier> portEnum = CommPortIdentifier.getPortIdentifiers();
        while (portEnum.hasMoreElements()) {
            CommPortIdentifier portIdentifier = portEnum.nextElement();
            System.out.println(portIdentifier.getName() + " - " + getPortTypeName(portIdentifier.getPortType()));
    static String getPortTypeName(int portType) {
        switch (portType) {
            case CommPortIdentifier.PORT_I2C:
                return "I2C";
            case CommPortIdentifier.PORT_PARALLEL:
                return "Parallel";
            case CommPortIdentifier.PORT_RAW:
                return "Raw";
            case CommPortIdentifier.PORT_RS485:
                return "RS485";
            case CommPortIdentifier.PORT_SERIAL:
                return "Serial";
            default:
                return "unknown type";
Whe I run the code on orangepiPC I get only one UART which is /dev/ttyS0
1.7.0_121
Linux
/dev/ttyS0 - Serial
Is there some configuration file to enable / disable UARTS?
thank you.
Other UARTs are not enabled by default.
For Legacy, you need to edit the FEX.
For Mainline, where we have now overlays, you need to add them in the /boot/armbianEnv.txt :
overlays=sun8i-h3-uart1 sun8i-h3-uart2 sun8i-h3-uart3
Ok!
will this be fine? will try.. thank you
verbosity=7
console=both
machid=1029
bootm_boot_mode=sec
rootdev=UUID=74434014-190f-406c-9b73-2c99c49383ba
rootfstype=ext4
Hmm.. tryed but still get only one serial
cmd : cd '/home/projekt/NetBeansProjects//TestCom'; '/usr/bin/java'  -Dfile.encoding=UTF-8   -jar /home/projekt/NetBeansProjects//TestCom/dist/TestCom.jar
1.7.0_121
Linux
/dev/ttyS0 - Serial
Are you sure you are using latest Mainline ?
Please, provide output of "uname -a" and "ls -l /boot/dtb/overlay" and "dmesg | grep serial" and "cat /proc/device-tree/soc/serial@01c28400/status"
Thank you for your help!
here is
for: ls -l /boot/dtb/overlay
I don't have subdirectory dtb
dmesg | grep serial
cat /proc/device-..... (I don't have this folder)
thank you for your help. I don't have much experience in linux but must do a project for thesis ;) ;(
Hi
Does this means that it could be possible to change the use of the GPIO pins "on the fly"
I mean without rebooting.
Hi
Sure.  Just write a driver module that manipulates the proper bits in the setup registers, read the data sheet for your CPU and the kernel source code.  The "confidential" H3 data sheet is on the sunxi web site.  Apparently the H2 used on the opi zero is very close, but I have not found it's data sheet.  This is not something I would recommend for beginner programmers.
