fmini Posted February 19, 2017 Posted February 19, 2017 Hello, after update to the new kernel it shows me still the 3.4.112. I could not understand this output: it seem to be installed? http://sprunge.us/DLAL ### Installed packages:ii linux-base 3.5 all Linux image base packageii linux-firmware-image-sun7i 5.25 armhf Linux kernel firmware, version 3.4.113-sun7iii linux-headers-sun7i 5.25 armhf Linux kernel headers for 3.4.113-sun7i on armhfrc linux-image-3.4.107-cubietruck 3.7 armhf Linux kernel, version 3.4.107-cubietruckii linux-image-sun7i 5.25 armhf Linux kernel, version 3.4.113-sun7irc linux-image-sunxi 4.4 armhf Linux kernel, version 3.4.109-sunxirc linux-jessie-root-cubietruck 5.25 armhf Armbian tweaks for jessie on cubietruck (default branch)ii linux-jessie-root-next-cubietruck 5.25 armhf Armbian tweaks for jessie on cubietruck (next branch)ii linux-libc-dev:armhf 4.9.2-2~bpo8+1 armhf Linux support headers for userspace developmentii linux-u-boot-cubietruck 5.00 armhf Uboot loader 2016.01
Igor Posted February 19, 2017 Posted February 19, 2017 You are upgrading from very old image and we change some package names in between. You will need to uninstall some and install new one. Check this page for relevant info: https://www.armbian.com/kernel/
fmini Posted February 20, 2017 Author Posted February 20, 2017 Thank you for the quick answer. I tried tu uninstall the old kernel. root@cubie:/var/log# apt-get remove linux-firmware-image-cubietruck linux-headers-cubietruck linux-image-cubietruckReading package lists... DoneBuilding dependency treeReading state information... DoneE: Unable to locate package linux-firmware-image-cubietruckE: Unable to locate package linux-headers-cubietruckE: Unable to locate package linux-image-cubietruck After I tried to install the new one - linux-image-sun7i So it seem all was reloaded. Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun7iSystem load: 4.24 Up time: 46 secMemory usage: 6 % of 1998Mb IP: 192.168.2.30CPU temp: 57°C HDD temp: 48°CUsage of /: 5% of 917G Do I need to load anything else? Messages on the Protocol seems do be the same. http://sprunge.us/ihJW ### Installed packages:ii linux-base 3.5 all Linux image base packageii linux-firmware-image-sun7i 5.25 armhf Linux kernel firmware, version 3.4.113-sun7iii linux-headers-sun7i 5.25 armhf Linux kernel headers for 3.4.113-sun7i on armhfrc linux-image-3.4.107-cubietruck 3.7 armhf Linux kernel, version 3.4.107-cubietruckii linux-image-sun7i 5.25 armhf Linux kernel, version 3.4.113-sun7irc linux-image-sunxi 4.4 armhf Linux kernel, version 3.4.109-sunxiii linux-jessie-root-cubietruck 5.25 armhf Armbian tweaks for jessie on cubietruck (default branch)rc linux-jessie-root-next-cubietruck 5.25 armhf Armbian tweaks for jessie on cubietruck (next branch)ii linux-libc-dev:armhf 4.9.2-2~bpo8+1 armhf Linux support headers for userspace development
Igor Posted February 20, 2017 Posted February 20, 2017 It's O.K. now ... you could further uninstall those packages, linux-image-sunxi linux-image-3.4.107-cubietruck linux-jessie-root-next-cubietruck but it's also harmless if you just leave as is.
fmini Posted February 20, 2017 Author Posted February 20, 2017 Hello, thank you again. I intendet to uninstall them. Here the output messages: root@cubie:~# apt-get remove linux-image-sunxi linux-image-3.4.107-cubietruck linux-jessie-root-next-cubietruckReading package lists... DoneBuilding dependency treeReading state information... DonePackage 'linux-jessie-root-next-cubietruck' is not installed, so not removedPackage 'linux-image-sunxi' is not installed, so not removedPackage 'linux-image-3.4.107-cubietruck' is not installed, so not removed0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. It seems not be install. I have still one question to the different kernels on the following link. https://www.armbian.com/kernel/ When do I have to install which Kernel? (for cubietruck Allwinner A20 is clear) Firmware? Board support packages Latest mainline for all Allwinner devices U-boots
Igor Posted February 20, 2017 Posted February 20, 2017 When do I have to install which Kernel? (for cubietruck Allwinner A20 is clear) Firmware? Board support packages Latest mainline for all Allwinner devices U-boots This page is more like a table with all kernels that we build. You don't need to install anything since images comes with all those packages ... but in case you do some damage or in your case, you can fix the system by installing a proper one. Next, some boards have more kernels and you can switch between them. So this table has naming and if you go for "DEV" ... you need usually to change to DEV u-boot to ... so it's better to change all packages if you want to do so. In any case, all this is recommended for experienced users who know how to fix things if something goes wrong.
