tkaiser Posted February 23, 2017 Posted February 23, 2017 (edited) For anyone stumbling accross CVE-2017-6074 and thinking about whether Armbian installations are affected or not: we're most probably not since CONFIG_IP_DCCP is enabled as module only on some kernels: root@armbian:/var/git/Armbian/lib/config/kernel # grep 'CONFIG_IP_DCCP=' * linux-cubox-default.config:CONFIG_IP_DCCP=m linux-cubox-dev.config:CONFIG_IP_DCCP=m linux-mvebu-default.config:CONFIG_IP_DCCP=m linux-mvebu-next.config:CONFIG_IP_DCCP=m linux-sun8i-dev.config:CONFIG_IP_DCCP=m linux-sunxi-dev.config:CONFIG_IP_DCCP=m linux-sunxi-next.config:CONFIG_IP_DCCP=m root@armbian:/var/git/Armbian/lib/config/kernel # Details about this local root exploit: http://seclists.org/oss-sec/2017/q1/471 Edited February 23, 2017 by tkaiser Searched in the wrong location in the first place
Igor Posted February 23, 2017 Posted February 23, 2017 Sources are fixed and I don't mind if we push and update even it's not that critical. I did patch / compile test only on sunxi-next so far. 1
Igor Posted February 23, 2017 Posted February 23, 2017 Main repository was updated - all kernels were fixed and updated to latest versions. 1
