I have tried all known possible combos to hide the grub menu on boot but no luck
I tested on the
/etc/default/grub
and
 /etc/default/grub.d/98-armbian.cfg
Is there another config file Im missing that ignores above, especially later?
Tried also with custom override config at boot.
Any advise is welcome
Dear @Werner yes I did. Something overrides it?
i set to 0 the timeout(s), hidden instead menu etc
For example below works ok and stated when I run the update-grub
GRUB_DISABLE_OS_PROBER=true
Grub shows with armbian background, no menu options and boots to first entry of the default too (original options)
