Hello!
I wrote the legacy image to a sd card and put it into the card slot. I can see something like diagnostic message and then "starting kernel". After that there is no video output. Neither over VGA nor over HDMI. Is that wanted? I tried 3 different monitors, but no chance. I can connect via ssh after a few minutes, but using a monitor and a screen would help, when there is no network. What am I doing wrong?
Greetings,
Pille
I should add, that everything worked with the preinstalled android image. And it worked with the main line. While I want to use the nand to boot from, I cannot use the main line.
What kind of monitor do you use?
How do you power the board?
Do you have a network cable attached with DHCP server on the network?
How long did you wait for the screen?
Do you have a blank screen or monitor shut downs because of no signal were detected?
 hello
i have the same problem
i've download every build of armbian for my orangepi lite.
some of them are not loading
some of them shows me starting process - i see "file not found boot/,next", "file not found .next"
then
"starting kernel"
then my HDMI monitor shutting down with sign "no video input". monitor = fullHD philips
orange pi blinking with red and lights green led
i've waited for a long
power via USB from mac or from plug for iphone
no network cable
help pls! :(
It is an older 5:4 VGA monitor with a 1280x1024 resolution.
The board is powered over the power plug next to the ethernet port.
Network cable is attached and a DHCP server is running.
I am still waiting. I just leave the monitor on.
It says that the signal is out of range.
I also tried a 16:9 VGA Monitor with 1920x1080 and a 16:9 HDMI monitor with 1680x900.
Okay, there is light at the end of the tunnel. Had to manually set the output with a10disp. Fortunately that worked over ssh and it remembers the last setting.
i've connected my device to TV
it works!
but when i set h3disp to 1080 it turns black again.
and dont work on TV and monitor
i'll try do not change the resolution with new img on my sd
today I updated my BananaPi, after a reboot, I don't have a video-output.. the BPi is connected via HDMI to a NEC 55" Monitor.. LAN-cable is plugged in and it gets power via a powersupply.. any suggestion how to solve that? X11vnc works fine
thanks!
Linux bananapim2 4.9.12-sunxi #4 SMP Thu Feb 23 19:46:51 CET 2017 armv7l GNU/Linux
hmm i try to use a10disp, but it didnt work:
a10disp info
Error: Failed to open /dev/disp: No such file or directory
Are you root?
I found this in the Xorg log fie maybe it is usefull..
[     9.525] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[     9.525] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[     9.525] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[     9.525] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[     9.525] (II) FBTURBO(0): enabled VFP/NEON optimizations
[     9.526] (==) FBTURBO(0): Backing store enabled
[     9.532] (==) FBTURBO(0): DPMS enabled
[     9.532] (II) FBTURBO(0): failed to enable hardware cursor
[     9.556] (II) FBTURBO(0): can't load 'mali' kernel module
[     9.564] (II) FBTURBO(0): can't load 'mali_drm' kernel module
[     9.572] (II) FBTURBO(0): can't load 'sunxi_cedar_mod' kernel module
[     9.572] (II) Loading sub module "dri2"
[     9.572] (II) LoadModule: "dri2"
[     9.573] (II) Module "dri2" already built-in
[     9.705] SunxiMaliDRI2_Init: drmOpen failed!
[     9.705] (II) FBTURBO(0): failed to enable DRI2 integration for Mali GPU
[     9.706] (==) RandR enabled
[     9.816] (II) SELinux: Disabled on system
[     9.833] (II) AIGLX: Screen 0 is not DRI2 capable
[     9.833] (EE) AIGLX: reverting to software rendering
[     9.979] (II) AIGLX: Loaded and initialized swrast
specialy that the g2d_23 isnt loaded.. can someone help me?
nobody any idea or a hint?
my boot.cmd looks like:
if ext4load mmc 0 0x00000000 /boot/.verbose
then
setenv verbosity 7
else
setenv verbosity 1
fi
# nonstandard monitor settings for A10, A20 and A31 based boards
# screen is initialized before this script -> saving to u-boot environment is mandatory
setenv video-mode sunxi:1920x1080-24@30,monitor=hdmi,hpd=0,edid=0,overscan_x=1,overscan_y=2
# setenv video-mode sunxi:1280x720-24@30,monitor=hdmi,hpd=0,edid=1,overscan_x=1,overscan_y=2
# setenv video-mode sunxi:1024x768-24@60,monitor=dvi,hpd=0,edid=0,overscan_x=1,overscan_y=2
saveenv
setenv bootargs "console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing
=0 loglevel=${verbosity}"
# Boot loader script to boot with different boot methods for old and new kernel
if ext4load mmc 0 0x00000000 /boot/.next || fatload mmc 0 0x00000000 .next || ext4load mmc 0 0x00000000 .next
then
# sunxi mainline kernel
ext4load mmc 0 ${fdt_addr_r} /boot/dtb/${fdtfile} || fatload mmc 0 ${fdt_addr_r} /dtb/${fdtfile} || ext4load mmc 0 ${fdt_addr_r} /dtb/${fdtfile}
ext4load mmc 0 ${ramdisk_addr_r} /boot/uInitrd || fatload mmc 0 ${ramdisk_addr_r} uInitrd || ext4load mmc 0 ${ramdisk_addr_r} uInitrd || setenv ramdisk_addr_r "-"
ext4load mmc 0 ${kernel_addr_r} /boot/zImage || fatload mmc 0 ${kernel_addr_r} zImage || ext4load mmc 0 ${kernel_addr_r} zImage
bootz ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
else
# sunxi android kernel
ext4load mmc 0 ${fdt_addr_r} /boot/script.bin || fatload mmc 0 ${fdt_addr_r} script.bin || ext4load mmc 0 ${fdt_addr_r} script.bin
fi
# Recompile with:
and yes i recompile it and reboot twice
