PmProd379 Posted March 28, 2024 Posted March 28, 2024 Hello, I'm new to this forum. I would like to know which recent version of ARMBIAN I can install on my X96 Max+ TV box (2GB ram and 16GB version). I've tried to install several recent 24.5 versions but it won't start. Here is the link to the versions I tried to install(Armbian_community_24.5.0-trunk.250_Aml-s9xx-box) I simply renamed the file corresponding to my S905X3.............. box to u-boot.ext https://github.com/armbian/community/releases/tag/24.5.0-trunk.250 The only version I managed to install is Armbian_20.10_Arm-64_focal_current_5.9.0_desktop. So I'd like to know which version is best suited to my box. The CPU in the box is an Amlogic S905X3 only, I followed a procedure that made me use an S905X2 with Armbian_20.10_Arm-64_focal_current_5.9.0_desktop. Here is the link https://www.youtube.com/watch?v=nETXagKHYGI Is it possible to have your help if possible by telling me the procedure for a perfect installation. Thank you in advance. 0 Quote
maka Posted March 29, 2024 Posted March 29, 2024 There are some x96 max+ that only boot from usb. Have you tried? 0 Quote
PmProd379 Posted April 2, 2024 Author Posted April 2, 2024 Hello Maka, Thanks for your help, I managed to install a version of Armbian that seems to work fine. Armbian_24.5.0_amlogic_s905x3_bullseye_5.15.152_server_2024.03.16.img.gz with the file dtb meson-sm1-x96-max-plus-2101.dtb. The installation is on a sd card as I was unable to install from the USB key. If anyone can tell me how to install from the USB key, I'd love to hear from you. I was able to install KLIPPER to control my printers as well as KLIPPERSCREEN via an old smartphone to have a control screen. And frankly, I'm very happy with it. Thanks again for responding to my request. 0 Quote
SteeMan Posted April 2, 2024 Posted April 2, 2024 @PmProd379Armbian_24.5.0_amlogic_s905x3_bullseye_5.15.152_server_2024.03.16.img.gz That is not an Armbian build. No Armbian builds have that name. Where did you download that from? 0 Quote
PmProd379 Posted April 2, 2024 Author Posted April 2, 2024 Hello Steeman, On github.com. I'm not an expert on Armbian versions but it works for my use. If you have a link to an official Armbian version that works with my box. Best regards, 0 Quote
SteeMan Posted April 2, 2024 Posted April 2, 2024 35 minutes ago, PmProd379 said: On github.com. What link on github? There are alot of non-armbian builds out there that are named armbian. 0 Quote
maka Posted April 2, 2024 Posted April 2, 2024 Usb booting should work the same as sd card. Maybe you are using the second usb while booting and tries to boot from it. You can try with the second usb empty and plugging after booting. Perhaps your dtb is not good enough and the kernel cannot find the file system. 0 Quote
SteeMan Posted April 28 Posted April 28 @iTux Your posts are not appropriate for Armbian forums. You are using non Armbian code. You should post your information in the channels that they provide. Ophub is a fork of Armbian. They do not contribute to Armbian development, nor do they contribute to these forums. They use the Armbian name without permission and cause significant confusion as a result. (Like in your case where you think you are using Armbian and you are not). 0 Quote
