hello
i have problem with installation hostapd on jessie udoo
( Linux udoo 4.2.3-udoo #1 SMP Sun Oct 11 21:56:52 CEST 2015 armv7l GNU/Linux )
i should enable mode ip_tables_nat but its require recompile kernel
(as i think because its not in modules list <= modprobe iptable_nat says 'module ...  not found'),
is there other easier way?
or can someone post new version of kerne img ^_^
thank you
Strange! you mention "Linux udoo 4.2.3-udoo"
the iptables modules are enabled in vanilla but not in the legacy kernel for udoo
legacy:
https://github.com/igorpecovnik/lib/blob/second/config/linux-udoo-neo.config
vanilla:
https://github.com/igorpecovnik/lib/blob/second/config/linux-udoo-next.config
waiting for a better piece of advice
in the meantime... what do you have in the folders
ls -l /lib/modules/4.2.3-sunxi/kernel/net/netfilter/
ls -l /lib/modules/4.2.3-sunxi/kernel/net/ipv4/netfilter/
Alter sunxi to udoo:
ls -l /lib/modules/4.2.3-udoo/kernel/net/netfilter/
ls -l /lib/modules/4.2.3-udoo/kernel/net/ipv4/netfilter/
I should add a note that Udoo kernel is not exactly Vanilla. It's an unofficial build so it could be (it is) a little different.
