MICE Posted March 4, 2017 Posted March 4, 2017 Odroid C2 not booting Armbian 5.25 Odroid C2 Debian jessie default 3.14.79 after reboot te system never came up. red solid light. blue blinking light. Please help. uart log added: Spoiler GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 269146 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012d0 Wait bl30...Done Sending bl301.....OK. Run bl301... bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipid: Load bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x00068270 ef be ad de d f0 ad ba ef be ad de not ES chip [0.384199 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Feb 01 2017 - 22:27:26) DRAM: 2 GiB Relocation Offset is: 76f3e000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFCD849 MAC : 00:1e:06:33:24:c9 BID : HKC2211602 ------------------------------------------------- register usb cfg[1][0] = 0000000077f97508 register usb cfg[0][1] = 0000000077f97530 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f36d30 aml_priv->desc_buf = 0x0000000073f38ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 128 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 61024, count 2048 ... 2048 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** reading boot.ini 4386 bytes read in 2 ms (2.1 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: cfgload: setenv cec "cecf" cfgload: setenv m_bpp "24" cfgload: setenv mesontimer "0" cfgload: setenv nographics "0" cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: setenv condev "console=ttyS0,115200n8 console=tty0 consoleblank=0" # on both cfgload: setenv verbosity "9" cfgload: setenv bootargs "root=/dev/mmcblk0p2 rootwait rootflags=data=writeback rw ${c" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: fatload mmc 0:1 ${initrd_loadaddr} uInitrd reading uInitrd 5316219 bytes read in 124 ms (40.9 MiB/s) cfgload: fatload mmc 0:1 ${loadaddr} zImage reading zImage 13038088 bytes read in 302 ms (41.2 MiB/s) cfgload: fatload mmc 0:1 ${dtb_loadaddr} dtb/meson64_odroidc2.dtb reading dtb/meson64_odroidc2.dtb 29264 bytes read in 5 ms (5.6 MiB/s) cfgload: fdt addr ${dtb_loadaddr} cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/ti libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 5316155 Bytes = 5.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a22000, end 73f33e3b ... OK Loading Device Tree to 000000001fff5000, end 000000001ffff24f ... OK Starting kernel ... uboot time: 3704178 us [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.14.79-odroidc2 (root@devel) (gcc version 5.4.0 201606097 [ 0.000000] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000] secmon: share mem setup [ 0.000000] Reserved memory: initialized node linux,secmon, compatible id aml_secmoy [ 0.000000] __reserved_mem_alloc_size: linux,meson-fb [ 0.000000] fb: Reserved memory: created fb at 0x0000000078000000, size 128 MiB [ 0.000000] Reserved memory: initialized node linux,meson-fb, compatible id amlogicy [ 0.000000] __reserved_mem_alloc_size: linux,di [ 0.000000] DI reserved memory: created CMA memory pool at 0x0000000076200000, sizeB [ 0.000000] Reserved memory: initialized node linux,di, compatible id amlogic, di-mm [ 0.000000] __reserved_mem_alloc_size: linux,ion-dev [ 0.000000] linux,ion-dev add multi user:ffffffc001cb6d68 [ 0.000000] ion_dev mem setup [ 0.000000] Reserved memory: initialized node linux,ion-dev, compatible id amlogic,m [ 0.000000] ppmgr share mem setup [ 0.000000] linux,ion-dev add multi user:ffffffc001cbf8f0 [ 0.000000] Reserved memory: initialized node linux,ion-dev, compatible id amlogic,m [ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_cma [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000067c00000, size 18B [ 0.000000] Reserved memory: initialized node linux,codec_mm_cma, compatible id shal [ 0.000000] __reserved_mem_alloc_size: linux,picdec [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000064c00000, size 48B [ 0.000000] Reserved memory: initialized node linux,picdec, compatible id shared-dml [ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_reserved [ 0.000000] codec_mm:vdec: reserved mem setup [ 0.000000] Reserved memory: initialized node linux,codec_mm_reserved, compatible id [ 0.000000] cma: Reserved 8 MiB at 60000000 [ 0.000000] On node 0 totalpages: 486912 [ 0.000000] Normal zone: 8568 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 486912 pages, LIFO batch:31 [ 0.000000] psci: probing function IDs from device-tree [ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc074197000 s19712 r8192 d21248 u492 [ 0.000000] pcpu-alloc: s19712 r8192 d21248 u49152 alloc=12*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 474 [ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rootflags=data=writeb0 [ 0.000000] logo: get hdmimode: 1080p60hz [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Memory: 1503096K/1947648K available (8177K kernel code, 880K rwdata, 27) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffff8040000000 ( 1024 MB) [ 0.000000] vmemmap : 0xffffff8040010000 - 0xffffff80421d0000 ( 33 MB) [ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc078000000 ( 1920 MB) [ 0.000000] .init : 0xffffffc001b34000 - 0xffffffc001c12d00 ( 892 kB) [ 0.000000] .text : 0xffffffc001080000 - 0xffffffc001b33534 ( 10958 kB) [ 0.000000] .data : 0xffffffc001c13000 - 0xffffffc001cef208 ( 881 kB) [ 0.000000] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 28633115197s [ 0.000205] Console: colour dummy device 80x25 [ 0.000682] console [tty0] enabled [ 0.003039] allocated 8388608 bytes of page_cgroup [ 0.003049] please try 'cgroup_disable=memory' option if you don't want memory cgros [ 0.003068] Calibrating delay loop (skipped), value calculated using timer frequenc) [ 0.003086] pid_max: default: 32768 minimum: 301 [ 0.003167] Security Framework initialized [ 0.003195] AppArmor: AppArmor initialized [ 0.003231] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.003244] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.003674] Initializing cgroup subsys debug [ 0.003688] Initializing cgroup subsys memory [ 0.003707] Initializing cgroup subsys devices [ 0.003718] Initializing cgroup subsys freezer [ 0.003729] Initializing cgroup subsys net_cls [ 0.003738] Initializing cgroup subsys blkio [ 0.003747] Initializing cgroup subsys perf_event [ 0.003759] Initializing cgroup subsys net_prio [ 0.003770] Initializing cgroup subsys hugetlb [ 0.003811] ftrace: allocating 29035 entries in 114 pages [ 0.020720] ------------[ cut here ]------------ [ 0.020761] WARNING: CPU: 0 PID: 0 at kernel/trace/ftrace.c:1709 ftrace_bug+0x248/0) [ 0.020774] Modules linked in: [ 0.020787] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.14.79-odroidc2 #32 [ 0.020799] Call trace: [ 0.020811] [<ffffffc001088e40>] dump_backtrace+0x0/0x128 [ 0.020821] [<ffffffc001088f8c>] show_stack+0x24/0x30 [ 0.020833] [<ffffffc001867590>] dump_stack+0x88/0xac [ 0.020846] [<ffffffc0010adf68>] warn_slowpath_common+0x98/0xc0 [ 0.020857] [<ffffffc0010ae0c4>] warn_slowpath_null+0x3c/0x50 [ 0.020867] [<ffffffc00114bf70>] ftrace_bug+0x248/0x258 [ 0.020878] [<ffffffc00114c37c>] ftrace_process_locs+0x3fc/0x630 [ 0.020891] [<ffffffc001b40018>] ftrace_init+0xb8/0x1ac [ 0.020903] [<ffffffc001b34828>] start_kernel+0x368/0x384 [ 0.020930] ---[ end trace 3406ff24bd97382e ]--- [ 0.020939] ftrace failed to modify [<ffffffc001376e6c>] deadline_remove_request.is0 [ 0.020958] actual: 00:00:00:00 [ 0.021238] /cpus/cpu@0: Missing clock-frequency property [ 0.021255] /cpus/cpu@1: Missing clock-frequency property [ 0.021267] /cpus/cpu@2: Missing clock-frequency property [ 0.021280] /cpus/cpu@3: Missing clock-frequency property [ 0.021293] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters avaie [ 0.062859] Meson chip version = RevB (1F:B - 0:0) [ 0.081800] CPU1: Booted secondary processor [ 0.101778] CPU2: Booted secondary processor [ 0.121793] CPU3: Booted secondary processor [ 0.121844] Brought up 4 CPUs [ 0.121874] SMP: Total of 4 processors activated. [ 0.122373] devtmpfs: initialized [ 0.134041] pinctrl core: initialized pinctrl subsystem [ 0.134320] regulator-dummy: no parameters [ 0.135935] device-tree: Duplicate name in efusekey, renamed to "key0#1" [ 0.135963] device-tree: Duplicate name in efusekey, renamed to "key1#1" [ 0.135990] device-tree: Duplicate name in efusekey, renamed to "key2#1" [ 0.136019] device-tree: Duplicate name in efusekey, renamed to "key3#1" [ 0.137837] NET: Registered protocol family 16 [ 0.138489] register canvas platform driver [ 0.138499] codec:ignore bus ops for cpu=25 [ 0.138507] codec:ignore bus ops for cpu=29 [ 0.138515] codec:register amports ops for bus[0] [ 0.138522] codec:register amports ops for bus[4] [ 0.138530] codec:register amports ops for bus[3] [ 0.138537] codec:register amports ops for bus[2] [ 0.138544] codec:register amports ops for bus[1] [ 0.138552] codec:register amports ops for bus[13] [ 0.138560] codec:register amports ops for bus[2] [ 0.138567] codec:register amports ops for bus[14] [ 0.138594] register rdma platform driver [ 0.138914] vdso: 2 pages (1 code, 1 data) at base ffffffc001c1a000 [ 0.138946] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.139479] DMA: preallocated 256 KiB pool for atomic allocations [ 0.140677] software IO TLB [mem 0x5c800000-0x5cc00000] (4MB) mapped at [ffffffc05c] [ 0.140691] Serial: AMBA PL011 UART driver [ 0.140777] hdmitx: system: amhdmitx_init [ 0.140785] hdmitx: system: Ver: 2014May6 [ 0.140817] tv_vout: tv_init_module [ 0.140829] tv_vout: major number 254 for disp [ 0.140837] vout_notify: vout_register_server [ 0.140845] tv_vout: register tv module server ok [ 0.140870] codec_mm:codec_mm_module_init [ 0.140983] gxbb clk HIU base is 0xffffff800004c000 [ 0.140992] gxbb clk ao base is 0xffffff800004e000 [ 0.141031] register mpll_clk_out0 success done [ 0.141042] register mpll_clk_out1 success done [ 0.141053] register mpll_clk_out2 success done [ 0.141302] register sys pll success done [ 0.141346] clkrate [ xtal ] : 24000000Hz [ 0.141355] clkrate [ 32Khz ] : 32000Hz [ 0.141363] clkrate [ clk81 ] : 166666666Hz [ 0.141371] clkrate [ fixed_pll ] : 2000000000Hz [ 0.141379] clkrate [ fclk_div2 ] : 1000000000Hz [ 0.141387] clkrate [ fclk_div3 ] : 666666000Hz [ 0.141395] clkrate [ fclk_div4 ] : 500000000Hz [ 0.141403] clkrate [ fclk_div5 ] : 400000000Hz [ 0.141411] clkrate [ fclk_div7 ] : 285714000Hz [ 0.141439] gxbb clock initialization complete [ 0.141559] msr_clk_reg0=ffffff800005a75c,msr_clk_reg2=ffffff800005c764 [ 0.142479] amlogic iomap probe done [ 0.142740] Init pinux probe! [ 0.143495] pinmux-gxbb c1109880.pinmux: Probed amlogic pinctrl driver [ 0.143756] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb) [ 0.143776] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb) [ 0.143841] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb) [ 0.143860] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb) [ 0.144045] dvfs [scpi_dvfs_get_opps] - new count 6, max_freq 0 [ 0.144484] codec:codec map io source 0x00000000c1100000,size=1048576 to 0xffffff800 [ 0.144504] codec:codec map io source 0x00000000c8820000,size=65536 to 0xffffff80000 [ 0.144523] codec:codec map io source 0x00000000c883c000,size=8192 to 0xffffff800010 [ 0.144554] codec:codec map io source 0x00000000c8100000,size=1048576 to 0xffffff800 [ 0.144574] codec:codec map io source 0x00000000d0100000,size=262144 to 0xffffff8000 [ 0.144592] codec:codec map io source 0x00000000c8838000,size=1024 to 0xffffff800010 [ 0.144651] codec_mm has 2 memory regions [ 0.144667] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma ok [ 0.144682] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c00000 [ 0.144694] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_reservek [ 0.144706] codec_mm:codec_mm_probe mem init done [ 0.144716] codec_mm:add reserve memory 0000000060b00000(aligned 0000000060b00000) ) [ 0.144742] codec_mm has 2 memory regions [ 0.144753] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma ok [ 0.144766] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c00000 [ 0.144778] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_reservek [ 0.144789] codec_mm:codec_mm reserved memory probed done [ 0.144796] codec_mm:codec_mm_probe ok [ 0.145383] VPU driver version: v01 [ 0.145392] vpu driver detect cpu type: gxbaby [ 0.145406] load vpu_clk in dts: 666667000Hz(7) [ 0.145434] vpu_probe OK [ 0.145627] hdmitx: system: amhdmitx_probe [ 0.145841] hdmitx hpd irq = 89 [ 0.146029] hdmitx20: Mapped PHY: 0xc0800000 [ 0.146040] hdmitx20: Mapped PHY: 0xc1104400 [ 0.146061] hdmitx20: Mapped PHY: 0xc8100000 [ 0.146070] hdmitx20: Mapped PHY: 0xc8834000 [ 0.146079] hdmitx20: Mapped PHY: 0xc883a000 [ 0.146087] hdmitx20: Mapped PHY: 0xc883c000 [ 0.146098] hdmitx20: Mapped PHY: 0xd0100000 [ 0.146107] hdmitx20: Mapped PHY: 0xda83a000 [ 0.146121] hdmitx: alread display in uboot 0x10 [ 0.146147] avmute set to 1 [ 0.146480] canvas_probe reg=00000000c8838000,size=400 [ 0.146494] canvas maped reg_base =ffffff8000192000 [ 0.149831] rdma_probe [ 0.180321] bio: create slab <bio-0> at 0 [ 0.180771] SCSI subsystem initialized [ 0.180922] usbcore: registered new interface driver usbfs [ 0.180962] usbcore: registered new interface driver hub [ 0.181021] usbcore: registered new device driver usb [ 0.181083] media: Linux media interface: v0.10 [ 0.181117] Linux video capture interface: v2.00 [ 0.181179] pps_core: LinuxPPS API ver. 1 registered [ 0.181189] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <g> [ 0.181209] PTP clock support registered [ 0.181361] logo: logo_init [ 0.181400] Advanced Linux Sound Architecture Driver Initialized. [ 0.181706] Bluetooth: Core ver 2.18 [ 0.181730] NET: Registered protocol family 31 [ 0.181738] Bluetooth: HCI device and connection manager initialized [ 0.181752] Bluetooth: HCI socket layer initialized [ 0.181764] Bluetooth: L2CAP socket layer initialized [ 0.181786] Bluetooth: SCO socket layer initialized [ 0.181799] NetLabel: Initializing [ 0.181806] NetLabel: domain hash size = 128 [ 0.181813] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.181852] NetLabel: unlabeled traffic allowed by default [ 0.182338] Switched to clocksource arch_sys_counter [ 0.202274] FS-Cache: Loaded [ 0.202446] CacheFiles: Loaded [ 0.202565] AppArmor: AppArmor Filesystem Enabled [ 0.206549] NET: Registered protocol family 2 [ 0.207031] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.207130] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 0.207332] TCP: Hash tables configured (established 16384 bind 16384) [ 0.207406] TCP: reno registered [ 0.207418] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 0.207460] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 0.207632] NET: Registered protocol family 1 [ 0.207808] Unpacking initramfs... [ 0.375996] Freeing initrd memory: 5188K (ffffffc073a22000 - ffffffc073f33000) [ 0.376706] kvm [1]: interrupt-controller@c4304000 IRQ25 [ 0.376893] kvm [1]: timer IRQ27 [ 0.376908] kvm [1]: Hyp mode initialized successfully [ 0.377440] futex hash table entries: 1024 (order: 5, 131072 bytes) [ 0.377517] audit: initializing netlink subsys (disabled) [ 0.377566] audit: type=2000 audit(0.370:1): initialized [ 0.377960] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.381955] VFS: Disk quotas dquot_6.5.2 [ 0.382096] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.383511] msgmni has been set to 3433 [ 0.384339] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.384423] io scheduler noop registered [ 0.384433] io scheduler deadline registered [ 0.384455] io scheduler cfq registered (default) [ 0.406879] meson-rng c8834000.rng: hwrng registered [ 0.407036] [drm] Initialized drm 1.1.0 20060810 [ 0.407073] mali-utgard d00c0000.mali: max pp is 3 [ 0.407084] mali-utgard d00c0000.mali: min pp is 3 [ 0.407094] mali-utgard d00c0000.mali: min clk is 4 [ 0.407110] mali-utgard d00c0000.mali: hiu io source 0xffffff80001bc000 [ 0.407125] mali-utgard d00c0000.mali: hiu io source 0xffffff80001be000 [ 0.407137] mali-utgard d00c0000.mali: num of pp used most of time 3 [ 0.407148] mali-utgard d00c0000.mali: clock dvfs table size is 6 [ 0.407159] mali-utgard d00c0000.mali: max clk set 4 [ 0.407168] mali-utgard d00c0000.mali: max clk is 4 [ 0.407177] mali-utgard d00c0000.mali: turbo clk set to 5 [ 0.407187] mali-utgard d00c0000.mali: turbo clk is 5 [ 0.407196] mali-utgard d00c0000.mali: default clk is 4 [ 0.407256] mali-utgard d00c0000.mali: ====================0==================== [ 0.407256] clk_freq= 125000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, 5 [ 0.407282] mali-utgard d00c0000.mali: ====================1==================== [ 0.407282] clk_freq= 285000000, clk_parent=fclk_div7, voltage=1150, keep_count=5, 5 [ 0.407307] mali-utgard d00c0000.mali: ====================2==================== [ 0.407307] clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=5, 0 [ 0.407332] mali-utgard d00c0000.mali: ====================3==================== [ 0.407332] clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, 0 [ 0.407357] mali-utgard d00c0000.mali: ====================4==================== [ 0.407357] clk_freq= 666000000, clk_parent=fclk_div3, voltage=1150, keep_count=5, 6 [ 0.407382] mali-utgard d00c0000.mali: ====================5==================== [ 0.407382] clk_freq= 792000000, clk_parent= gp0_pll, voltage=1150, keep_count=5, 2 [ 0.408716] gpu cooling register okay with err=0 [ 0.408757] gpu core cooling register okay with err=0 [ 0.408924] Mali: Mali device driver loaded [ 0.409040] UMP: UMP device driver -b22dbcc loaded [ 0.411329] loop: module loaded [ 0.411602] zram: Created 1 device(s) ... [ 0.411931] mtdoops: mtd device (mtddev=name/number) must be supplied [ 0.415315] libphy: stmmac: probed [ 0.415325] eth0: No PHY found [ 0.452358] stmmac_pltfr_probe: main driver probe failed [ 0.452621] usbcore: registered new interface driver cdc_ether [ 0.452675] usbcore: registered new interface driver cdc_ncm [ 0.452747] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.452759] ehci-h20ahb: H20AHB-EHCI Host Controller driver [ 0.452825] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.452880] usbcore: registered new interface driver cdc_acm [ 0.452889] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adaps [ 0.452930] usbcore: registered new interface driver usb-storage [ 0.453013] usbcore: registered new interface driver usbserial [ 0.453041] usbcore: registered new interface driver usbserial_generic [ 0.453069] usbserial: USB Serial support registered for generic [ 0.453282] mousedev: PS/2 mouse device common for all mice [ 0.453543] i2c /dev entries driver [ 0.453821] softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_) [ 0.453855] cpufreq-hotplug: cpufreq_gov_dbs_init: assumes CONFIG_NO_HZ [ 0.454066] ledtrig-cpu: registered to indicate activity on CPUs [ 0.454214] usbcore: registered new interface driver usbhid [ 0.454223] usbhid: USB HID core driver [ 0.454341] ==uart0 reg addr = ffffff80004184c0 [ 0.454367] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 225, base_baud = 15000t [ 2.159652] console [ttyS0] enabled [ 2.163289] ==uart1 reg addr = ffffff800041a4c0 [ 2.167595] c11084c0.serial: ttyS1 at MMIO 0xc11084c0 (irq = 58, base_baud = 150000t [ 2.176934] enter cpufreq [ 2.179407] probe cpufreq okay [ 2.222828] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000020 [ 2.228324] dwc_otg: Core Release: 3.10a [ 2.229570] dwc_otg: Setting default values for core params [ 2.235102] dwc_otg: curmode: 1, host_only: 1 [ 2.241593] dwc_otg: Using Buffer DMA mode [ 2.243461] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 2.248544] dwc_otg: Working on port type = HOST [ 2.253229] dwc_otg dwc2_b: DWC OTG Controller [ 2.257523] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1 [ 2.264260] dwc_otg dwc2_b: irq 63, io mem 0x00000000 [ 2.269244] dwc_otg: -------hcd->flags.d32 = 0 [ 2.273662] dwc_otg: Init: Port Power? op_state=1 [ 2.278299] dwc_otg: Init1: Power Port (0) [ 2.282787] hub 1-0:1.0: USB hub found [ 2.286079] hub 1-0:1.0: 1 port detected [ 2.290099] dwc_otg: usb0: type: 0 speed: 0, config: 0, dma: 0, id: 0, phy: c0000000 [ 2.309984] dwc_otg: Core Release: 3.10a [ 2.310006] dwc_otg: Setting default values for core params [ 2.313804] dwc_otg: curmode: 1, host_only: 0 [ 2.322286] dwc_otg: Using Buffer DMA mode [ 2.322309] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 2.327251] dwc_otg: Working on port type = OTG [ 2.331731] dwc_otg: Current port type: SLAVE [ 2.336106] dwc_otg dwc2_a: DWC OTG Controller [ 2.340450] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2 [ 2.347187] dwc_otg dwc2_a: irq 62, io mem 0x00000000 [ 2.352516] hub 2-0:1.0: USB hub found [ 2.355894] hub 2-0:1.0: 1 port detected [ 2.359864] dwc_otg: Dedicated Tx FIFOs mode [ 2.364167] dwc_otg: using timer detectid change, ffffffc05d9e9800 [ 2.370387] BLASTER Driver Init [ 2.373347] secmon has 1 memory regions [ 2.377029] secmon: share in base: 0xffffff800045a000, share out base: 0xffffff80000 [ 2.385178] secmon secmon: assigned reserved memory node linux,secmon ok [ 2.391760] secmon: probe done [ 2.394878] storage: storage in base: 0xffffff8001700000 [ 2.400041] storage: storage out base: 0xffffff8001780000 [ 2.405393] storage: storage block base: 0xffffff8001800000 [ 2.410907] storage: probe done! [ 2.414156] Error: Driver 'ICPlus IP175C' is already registered, aborting... [ 2.421086] libphy: ICPlus IP175C: Error -16 in registering driver [ 2.427670] aml_sd_emmc_probe: line 2954 [ 2.431092] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused r [ 2.440636] aml_sd_emmc_reg_init 677 [ 2.443925] pdata->caps 60107 [ 2.446790] pdata->caps2 0 [ 2.449463] get property: ocr_avail, value:0x00200080 [ 2.455806] get property: f_min, value:0x00061a80 [ 2.462055] get property: f_max, value:0x0510ff40 [ 2.468357] get property: max_req_size, value:0x00020000 [ 2.474653] get property: irq_in, value:0x00000003 [ 2.480944] get property: irq_out, value:0x00000005 [ 2.487283] dwc_otg: Indeed it is in host mode hprt0 = 00021501 [ 2.502338] get property: power_level, value:0x00000001 [ 2.503047] get property: gpio_cd, str: [ 2.508306] get property: gpio_power, str: [ 2.513567] get property: pinname, str:sd [ 2.518998] get property: jtag_pin, str: [ 2.524274] get property: card_type, value:0x00000005 [ 2.530556] get property: gpio_dat3, str: [ 2.535823] get property: gpio_volsw, str: [ 2.596875] [aml_sd_emmc_irq] sd: resp_timeout,vstat:0x2800,virqc:3fff [ 2.598966] aml_sd_emmc_data_thread 2211 sd: cmd:8 [ 2.602429] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.602453] aml_sd_emmc_probe: line 2954 [ 2.612428] [aml_is_card_insert] card OUT [ 2.612428] [ 2.612428] card out [ 2.622417] [aml_is_card_insert] card OUT [ 2.634346] sd: error -123 whilst initialising MMC card [ 2.647696] aml_sd_emmc_reg_init 677 [ 2.647809] pdata->caps 80000d47 [ 2.648837] pdata->caps2 80a1 [ 2.651763] get property: ocr_avail, value:0x00200080 [ 2.658066] get property: f_min, value:0x00061a80 [ 2.664362] get property: f_max, value:0x05f5e100 [ 2.670651] get property: max_req_size, value:0x00020000 [ 2.676955] get property: pinname, str:emmc [ 2.682558] get property: card_type, value:0x00000001 [ 2.688852] get property: gpio_dat3, str: [ 2.692378] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 2.692633] dwc_otg: Indeed it is in host mode hprt0 = 00001101 [ 2.706365] get property: hw_reset, str: [ 2.762348] aml_emmc_hw_reset 1356 [ 2.762350] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.762527] ion_dev has 1 memory regions [ 2.781934] fb: osd_init_module [ 2.782013] fb: viu vsync irq: 35 [ 2.782741] meson-fb has 1 memory regions [ 2.787812] meson-fb meson-fb: assigned reserved memory node linux,meson-fb ok [ 2.793969] tv_vout: tv_set_current_vmode[696]fps_target_mode=12 [ 2.799865] tv_vout: mode is 12,sync_duration_den=1,sync_duration_num=60 [ 2.806496] switch_vpu_mem_pd: vencp ON [ 2.810300] tv_vout: TV mode 1080p60hz selected. [ 2.814876] tv_vout: new mode =1080p60hz set ok [ 2.819294] vout_serve: vinfo mode is: 1080p60hz [ 2.823872] switch_vpu_mem_pd: viu_osd1 ON [ 2.827929] switch_vpu_mem_pd: viu_osd2 ON [ 2.827933] emmc: BKOPS_EN bit is not set [ 2.835953] switch_vpu_mem_pd: viu_osd_scale ON [ 2.840652] osd_rdma: osd_rdma_init: rmda_table p=0x60049000,op=0x60049000 , v=0xff0 [ 2.849314] hdmitx: video: get current mode: 1080p60hz [ 2.854326] [aml_sd_voltage_switch] switch to 1.8V for a non-uhs device. [ 2.854331] hdmitx: hpd: HPD deassert! [ 2.854334] fb: osd_probe vinfo:ffffffc001cb8048 [ 2.854337] fb: Frame buffer memory assigned at[ 2.854339] fb: phy: 0x780000K [ 2.854342] fb: osd_set_res_bootargs : mode 12 [ 2.854345] fb: fb def : 1920 1080 1920 2160 32 [ 2.854347] fb: init fbdev bpp is:32 [ 2.854348] fb: ---------------clear fb0 memory [ 2.898381] fb: osd[0] canvas.idx =0x40 [ 2.898382] fb: osd[0] canvas.addr=0x78000000 [ 2.898384] fb: osd[0] canvas.width=7680 [ 2.898385] fb: osd[0] canvas.height=2160 [ 2.912488] emmc: clk 100000000 SDR mode tuning start [ 2.912719] rx_tuning_result[0][1] = 10 [ 2.912934] rx_tuning_result[0][2] = 10 [ 2.913140] rx_tuning_result[0][3] = 10 [ 2.913344] rx_tuning_result[0][4] = 10 [ 2.913549] rx_tuning_result[0][5] = 10 [ 2.913753] rx_tuning_result[0][6] = 10 [ 2.913958] rx_tuning_result[0][7] = 10 [ 2.914162] rx_tuning_result[0][8] = 10 [ 2.914185] best_win_start =1, best_win_size =8 [ 2.914188] sd_emmc_regs->gclock =0x100024a, sd_emmc_regs->gadjust =0x42000 [ 2.914190] emmc: gclock =0x100024a, gdelay=0x94837045 [ 2.914191] gadjust=0x42000 [ 2.914305] emmc: try set sd/emmc to DDR mode [ 2.914309] emmc: try set sd/emmc to DDR mode [ 2.914313] emmc: clk 100000000 DDR mode tuning start [ 2.915358] rx_tuning_result[0][0] = 10 [ 2.916343] rx_tuning_result[0][1] = 10 [ 2.917328] rx_tuning_result[0][2] = 10 [ 2.917545] best_win_start =0, best_win_size =3 [ 2.917547] sd_emmc_regs->gclock =0x1000245, sd_emmc_regs->gadjust =0x12000 [ 2.917549] emmc: gclock =0x1000245, gdelay=0x94837045 [ 2.917550] gadjust=0x12000 [ 2.917617] emmc: new HS400 MMC card at address 0001 [ 2.917619] emmc: clock 100000000, 8-bit-bus-width [ 2.917619] [ 2.917943] mmcblk0: emmc:0001 DJNB4R 116 GiB [ 2.918364] mmcblk0: p1 p2 [ 2.933545] Console: switching to colour frame buffer device 240x67 [ 3.063318] hub 1-1:1.0: USB hub found [ 3.074287] hub 1-1:1.0: 4 ports detected [ 3.096185] fb: Frame buffer memory assigned at [ 3.099617] fb: phy: 0x7e000000, vir:0xffffff8001980000, size=1024K [ 3.112775] fb: osd probe OK [ 3.112942] vout_serve: vout_init_module [ 3.114017] vout_serve: meson_vout_probe [ 3.117849] vout_serve: create vout attribute OK [ 3.122456] ge2d: ge2d_init_module [ 3.125770] ge2d: ge2d_dev major:242 [ 3.129536] ge2d: ge2d clock is 400 MHZ [ 3.133104] ge2d: ge2d: pdev=ffffffc05dad8a00, irq=182, rstc=0xffffffc05b30a080, cl0 [ 3.142269] ge2d: mapped phy: 0xd0160000 [ 3.146129] ge2d: ge2d start monitor [ 3.149879] codec:Amlogic A/V streaming port init [ 3.154908] codec:get gate demux control ok ffffffc05b2c1980 [ 3.159924] codec:get gate parser_top control ok ffffffc05b2c1a80 [ 3.162344] ge2d: ge2d workqueue monitor start [ 3.170367] codec:get gate vpu_intr control ok ffffffc05b2c1b80 [ 3.176233] codec:get gate vdec control ok ffffffc05b2c1c80 [ 3.181913] codec:[tsync_pcr_init]init success. [ 3.186267] codec:regist mpeg12 codec profile [ 3.190574] codec:regist mpeg4 codec profile [ 3.194771] codec:amvdec_vc1 module init [ 3.198679] codec:regist vc1 codec profile [ 3.202705] codec:amvdec_h264 module init [ 3.206720] codec:regist h264 codec profile [ 3.210808] codec:amvdec_h264mvc module init [ 3.215076] codec:regist hmvc codec profile [ 3.219174] codec:amvdec_h264_4k2k module init [ 3.223610] codec:regist h264_4k2k codec profile [ 3.228144] codec:amvdec_h265 module init [ 3.232143] codec:regist hevc codec profile [ 3.236289] codec:regist mjpeg codec profile [ 3.240478] codec:amvdec_real module init [ 3.244483] codec:regist real codec profile [ 3.248585] codec:amvdec_avs module init [ 3.252507] codec:regist avs codec profile [ 3.256563] amvenc_avc_probe -- reserved memory config fail. [ 3.262128] amvenc_avc - cma memory pool size: 40 MB [ 3.267061] encode_wq_init. [ 3.270412] encode start monitor. [ 3.273981] jpegenc module init [ 3.277480] codec:picdec_driver_probe called. [ 3.280942] picdec has 1 memory regions [ 3.284445] encode workqueue monitor start. [ 3.288472] picdec picdec: assigned reserved memory node linux,picdec ok [ 3.295101] codec:picdec_driver_probe done. [ 3.299214] codec:reserved memory config fail , use CMA . [ 3.306582] codec:cma memory is 64c00000 , size is 3000000 [ 3.310465] codec:0 addr is 64c00000################ [ 3.315110] codec:1 addr is 64efd000################ [ 3.320102] switch_vpu_mem_pd: vpu_arb ON [ 3.324172] codec:create_ge2d_work_queue video task ok [ 3.329287] codec:register clk_set_setting cpu[31] [ 3.334003] di_module_init ok. [ 3.337674] di_module_init: major 238 [ 3.341463] di_probe [ 3.345207] deinterlace has 1 memory regions [ 3.348852] di reveser memory 0x76200000, size 30MB. [ 3.352476] deinterlace deinterlace: assigned reserved memory node linux,di ok [ 3.359622] rdma_register, rdma_table_addr ffffff8000472000 rdma_table_addr_phy 6000 [ 3.369704] rdma_register success, handle 1 table_size 8192 [ 3.375228] di_probe allocate rdma channel 1. [ 3.379533] DI hw version 2. [ 3.383288] 0x000000c3:Y=c3,U=0,V=0 [ 3.387007] 0x000000c4:Y=c4,U=0,V=0 [ 3.390660] 0x000000c5:Y=c5,U=0,V=0 [ 3.394302] 0x000000c6:Y=c6,U=0,V=0 [ 3.397900] 0x000000c7:Y=c7,U=0,V=0 [ 3.401431] 0x000000c8:Y=c8,U=0,V=0 [ 3.404905] 0x000000c9:Y=c9,U=0,V=0 [ 3.408346] 0x000000ca:Y=ca,U=0,V=0 [ 3.411770] 0x000000cb:Y=cb,U=0,V=0 [ 3.415176] 0x000000cc:Y=cc,U=0,V=0 [ 3.418533] 0x000000cd:Y=cd,U=0,V=0 [ 3.421876] 0x000000ce:Y=ce,U=0,V=0 [ 3.425207] 0x000000cf:Y=cf,U=0,V=0 [ 3.428555] di_probe here. [ 3.431712] switch_vpu_mem_pd: di_pre OFF [ 3.435071] efusekeynum: 4 [ 3.438224] efusekeyname: mac offset: 0 size: 6 [ 3.442774] efusekeyname: mac_bt offset: 6 size: 6 [ 3.448967] efusekeyname: mac_wifi offset: 12 size: 6 [ 3.455191] efusekeyname: usid offset: 18 size: 16 [ 3.461489] efuse efuse: probe OK! [ 3.464915] 6aml_unifykeys_init done! [ 3.468454] ppmgr module init func called [ 3.472480] ppmgr_driver_probe called [ 3.476045] ppmgr has 1 memory regions [ 3.479760] init ppmgr memsource 74200000->761fffff [ 3.484726] ppmgr_probe done [ 3.487955] ionvideo-000: V4L2 device registered as video13 [ 3.492977] [dsp]register dsp to char divece(257) [ 3.497849] amaudio: driver amaudio succuess! [ 3.501920] amlvideo_init called [ 3.504953] amlvideo_create_instance called [ 3.511146] v4l2_dev.name=:amlvideo-000 [ 3.514349] amlvideo-000: V4L2 device registered as video10 [ 3.518989] [ 3.518989] [ 3.518989] VECM init [ 3.518989] [ 3.532787] saradc c1108680.saradc: initialized by BL30 [ 3.537663] saradc c1108680.saradc: calibration start: [ 3.542817] saradc c1108680.saradc: nominal=0, value=12 [ 3.547970] saradc c1108680.saradc: nominal=256, value=260 [ 3.553418] saradc c1108680.saradc: nominal=512, value=510 [ 3.558837] saradc c1108680.saradc: nominal=768, value=764 [ 3.564285] saradc c1108680.saradc: nominal=1023, value=1017 [ 3.569834] saradc c1108680.saradc: calibration end: coef=4161 [ 3.575673] remote: Driver init [ 3.579068] aml-thermal aml-sensor@0: min state:500000 400 1 2 [ 3.584696] aml-thermal aml-sensor@0: not found gpucore node [ 3.590110] aml-thermal aml-sensor@0: gpu coef:437, pp:3 [ 3.600416] aml-thermal aml-sensor@0: cdev1 set upper to 3 [ 3.603385] aml-thermal aml-sensor@0: cdev2 set upper to 3 [ 3.608625] aml-thermal aml-sensor@0: cdev0 set upper to 3 [ 3.617138] input: cec_input as /devices/virtual/input/input0 [ 3.620312] cectx c810023c.aocec: aml_cec_probe(): can't find hdmirx [ 3.627292] 6-------------------------------------------------------- [ 3.632920] 6odroid_sysfs_init(321) : Sleep Enable !! [ 3.637987] 6-------------------------------------------------------- [ 3.644623] input: vt-input as /devices/virtual/input/input1 [ 3.650124] 6Virtual-Key input driver registered!! [ 3.655325] adbattery: android dummy battery driver loaded [ 3.660687] enter aml_soc_platform_pcm2bt_probe [ 3.665087] divider=16,frac=33920000,SDMval=4523 [ 3.669484] enter aml_pcm_dai_probe [ 3.672893] [aml-spdif-dai]enter aml_dai_spdif_init [ 3.677711] aml_spdif_probe [ 3.680712] enter spdif_dit_probe [ 3.684290] odroid_hdmi_snd odroid_hdmi: dit-hifi <-> I2S mapping ok [ 3.690479] GACT probability on [ 3.693551] Mirror/redirect action on [ 3.696723] u32 classifier [ 3.699794] Performance counters on [ 3.703209] input device check on [ 3.706814] Actions configured [ 3.710255] TCP: cubic registered [ 3.713813] NET: Registered protocol family 10 [ 3.718384] mip6: Mobile IPv6 [ 3.721643] sit: IPv6 over IPv4 tunneling driver [ 3.726002] NET: Registered protocol family 17 [ 3.729773] NET: Registered protocol family 15 [ 3.734218] Bridge firewalling registered [ 3.738211] Bluetooth: RFCOMM TTY layer initialized [ 3.742981] Bluetooth: RFCOMM socket layer initialized [ 3.748060] Bluetooth: RFCOMM ver 1.11 [ 3.751755] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.757030] Bluetooth: BNEP filters: protocol multicast [ 3.762193] Bluetooth: BNEP socket layer initialized [ 3.767120] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.772989] Bluetooth: HIDP socket layer initialized [ 3.777899] NET: Registered protocol family 35 [ 3.782436] Key type dns_resolver registered [ 3.786872] Registering SWP/SWPB emulation handler [ 3.791487] registered taskstats version 1 [ 3.795379] AppArmor: AppArmor sha1 policy hashing enabled [ 3.800762] regulator-dummy: disabling [ 3.804732] Mali DRM initialize, driver name: mali_drm, version 2.1 [ 3.810811] [drm] Initialized mali_drm 2.1.1 20140306 on minor 0 [ 3.816652] Mali DRM initialize, driver name: mali_drm, version 2.1 [ 3.822955] [drm] Initialized mali_drm 2.1.1 20140306 on minor 1 [ 3.828897] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) [ 3.835875] 6enter meson_pm_probe! [ 3.839494] meson_pm_probe done [ 3.843292] ALSA device list: [ 3.846900] #0: ODROID-HDMI [ 3.850952] Freeing unused kernel memory: 888K (ffffffc001b34000 - ffffffc001c12000) [ 3.881602] systemd-udevd[99]: starting version 215 [ 3.886530] random: systemd-udevd: uninitialized urandom read (16 bytes read, 97 bi) [ 4.063539] random: nonblocking pool is initialized [ 4.262446] raid6: int64x1 450 MB/s [ 4.432382] raid6: int64x2 762 MB/s [ 4.602381] raid6: int64x4 1296 MB/s [ 4.772368] raid6: int64x8 1379 MB/s [ 4.942364] raid6: neonx1 831 MB/s [ 5.112372] raid6: neonx2 1426 MB/s [ 5.129440] switch_vpu_mem_pd: viu_vd1 OFF [ 5.133586] switch_vpu_mem_pd: afbc_dec OFF [ 5.137682] switch_vpu_mem_pd: di_post OFF [ 5.141720] switch_vpu_mem_pd: viu_vd2 OFF [ 5.282366] raid6: neonx4 1887 MB/s [ 5.452351] raid6: neonx8 1932 MB/s [ 5.456225] raid6: using algorithm neonx8 (1932 MB/s) [ 5.460090] raid6: using intx1 recovery algorithm [ 5.464583] xor: measuring software checksum speed [ 5.562340] 8regs : 2844.800 MB/sec [ 5.662336] 8regs_prefetch: 2610.800 MB/sec [ 5.762335] 32regs : 3465.200 MB/sec [ 5.862335] 32regs_prefetch: 2939.600 MB/sec [ 5.866115] xor: using function: 32regs (3465.200 MB/sec) [ 5.879281] bio: create slab <bio-1> at 1 [ 5.883817] Btrfs loaded [ 5.887710] BTRFS: selftest: Running btrfs free space cache tests [ 5.891951] BTRFS: selftest: Running extent only tests [ 5.897120] BTRFS: selftest: Running bitmap only tests [ 5.902143] BTRFS: selftest: Running bitmap and extent tests [ 5.907771] BTRFS: selftest: Free space cache tests finished [ 5.913357] BTRFS: selftest: Running extent buffer operation tests [ 5.919291] BTRFS: selftest: Running btrfs_split_item tests [ 5.926835] BTRFS: selftest: Running find delalloc tests [ 6.175443] BTRFS: selftest: Running btrfs_get_extent tests [ 6.179475] BTRFS: selftest: Running hole first btrfs_get_extent test [ 6.611175] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts:k [ 6.750065] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +) [ 6.762416] systemd[1]: Detected architecture 'arm64'. [ 6.792280] systemd[1]: Inserted module 'autofs4' [ 6.797670] systemd[1]: Set hostname to <gen>. [ 6.997952] systemd[1]: Cannot add dependency job for unit display-manager.service,. [ 7.013209] systemd[1]: Expecting device dev-ttyS0.device... [ 7.023046] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 7.029738] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.037197] systemd[1]: Starting Remote File Systems (Pre). [ 7.047662] systemd[1]: Reached target Remote File Systems (Pre). [ 7.052916] systemd[1]: Starting Arbitrary Executable File Formats File System Auto. [ 7.066746] systemd[1]: Set up automount Arbitrary Executable File Formats File Sys. [ 7.075275] systemd[1]: Starting Encrypted Volumes. [ 7.085053] systemd[1]: Reached target Encrypted Volumes. [ 7.089817] systemd[1]: Starting Dispatch Password Requests to Console Directory Wa. [ 7.097591] systemd[1]: Started Dispatch Password Requests to Console Directory Wat. [ 7.105332] systemd[1]: Starting Paths. [ 7.115012] systemd[1]: Reached target Paths. [ 7.119803] systemd[1]: Expecting device dev-mmcblk0p1.device... [ 7.130132] systemd[1]: Expecting device dev-disk-by\x2duuid-8d3f45cf\x2dd673\x2d41. [ 7.145764] systemd[1]: Starting Root Slice. [ 7.156546] systemd[1]: Created slice Root Slice. [ 7.161820] systemd[1]: Starting Delayed Shutdown Socket. [ 7.172882] systemd[1]: Listening on Delayed Shutdown Socket. [ 7.178346] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 7.190709] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 7.197527] systemd[1]: Starting Journal Socket (/dev/log). [ 7.208944] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.214811] systemd[1]: Starting User and Session Slice. [ 7.226342] systemd[1]: Created slice User and Session Slice. [ 7.232044] systemd[1]: Starting udev Control Socket. [ 7.243687] systemd[1]: Listening on udev Control Socket. [ 7.249417] systemd[1]: Starting udev Kernel Socket. [ 7.261170] systemd[1]: Listening on udev Kernel Socket. [ 7.266984] systemd[1]: Starting Journal Socket. [ 7.278882] systemd[1]: Listening on Journal Socket. [ 7.284829] systemd[1]: Starting System Slice. [ 7.296779] systemd[1]: Created slice System Slice. [ 7.302594] systemd[1]: Starting system-systemd\x2dfsck.slice. [ 7.314694] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 7.321141] systemd[1]: Starting Increase datagram queue length... [ 7.334928] systemd[1]: Starting Restore / save the current clock... [ 7.353015] systemd[1]: Mounting Huge Pages File System... [ 7.366631] systemd[1]: Mounting POSIX Message Queue File System... [ 7.381027] systemd[1]: Starting Create list of required static device nodes for th. [ 7.398625] systemd[1]: Starting udev Coldplug all Devices... [ 7.412708] systemd[1]: Mounting Debug File System... [ 7.427197] systemd[1]: Started Set Up Additional Binary Formats. [ 7.433574] systemd[1]: Starting system-openvpn.slice. [ 7.445608] systemd[1]: Created slice system-openvpn.slice. [ 7.451243] systemd[1]: Starting system-getty.slice. [ 7.462915] systemd[1]: Created slice system-getty.slice. [ 7.468456] systemd[1]: Starting system-serial\x2dgetty.slice. [ 7.480102] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 7.487661] systemd[1]: Starting Load Kernel Modules... [ 7.500184] systemd[1]: Started File System Check on Root Device. [ 7.506218] systemd[1]: Starting LSB: Set keymap... [ 7.517303] fuse init (API version 7.22) [ 7.524314] systemd[1]: Starting Slices. [ 7.535717] systemd[1]: Reached target Slices. [ 7.536153] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 7.554746] systemd[1]: Mounted Debug File System. [ 7.565392] systemd[1]: Mounted POSIX Message Queue File System. [ 7.576304] systemd[1]: Mounted Huge Pages File System. [ 7.587592] systemd[1]: Started Increase datagram queue length. [ 7.599550] systemd[1]: Started Restore / save the current clock. [ 7.611949] systemd[1]: Started Create list of required static device nodes for the. [ 7.628837] systemd[1]: Started Load Kernel Modules. [ 7.641051] systemd[1]: Started LSB: Set keymap. [ 7.648021] systemd[1]: Time has been changed [ 7.682102] systemd[1]: Started udev Coldplug all Devices. [ 7.698041] systemd[1]: Mounting Configuration File System... [ 7.710722] systemd[1]: Starting Apply Kernel Variables... [ 7.723351] systemd[1]: Mounting FUSE Control File System... [ 7.736112] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.749682] systemd[1]: Starting Syslog Socket. [ 7.761268] systemd[1]: Listening on Syslog Socket. [ 7.766769] systemd[1]: Starting Journal Service... [ 7.785494] systemd[1]: Started Journal Service. [ 7.844782] systemd-udevd[207]: starting version 215 [ 7.970296] Driver for 1-wire Dallas network protocol. [ 7.986090] gpiomem-meson c8834000.gpiomem: Initialised: Registers at 0xc8834000 [ 8.205829] ionvideo open [ 8.402365] ionvideo_stop_generating!!!! [ 8.402388] ionvideo release [ 8.405378] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro [ 8.459199] Adding 131068k swap on /var/swap. Priority:-1 extents:2 across:139260kS
Igor Posted March 4, 2017 Posted March 4, 2017 Probably related to this, experimental patch was added 21h ago ... try if latest beta builds solves this problem. It affect only some eMMC types. I can't reproduce with mine.
MICE Posted March 4, 2017 Author Posted March 4, 2017 Thanks for the quick reply! Would it help to buy new 32GiB eMMC instead of the 128GiB eMMC ? Thanks for the great work! love the product!
Igor Posted March 4, 2017 Posted March 4, 2017 37 minutes ago, MICE said: Would it help to buy new 32GiB eMMC instead of the 128GiB eMMC ? We don't know exactly how and which eMMC are having this problem and which don't ... we asked Hardkernel folks for helping with this - they made adjustment to the eMMC driver. We wait for info ATM.
MICE Posted March 7, 2017 Author Posted March 7, 2017 I noticed something: last night i did a clean install of https://dl.armbian.com/odroidc2/Debian_jessie_default.7z when i did: lsblk: mmcblk0 179:0 0 116,5G 0 disk └─mmcblk0p1 179:1 0 114,2G 0 part / the boot partition was the same as root before i was using the image: Armbian_5.21_Odroidc2_Debian_jessie_3.14.79.img and upgraded to 5.25 via apt-get upgrade. and than there was a boot partion lsblk mmcblk0 179:0 0 116,5G 0 disk └─mmcblk0p1 179:1 0 114,2G 0 part / ─mmcblk0p1 179:1 0 60M 0 part /boot Could this be the problem? related to this?
