Hi
I want to build armbian for nanopi neo with a different mainline.  What I have done is
1. added lib.config file in userpatches with statement ARMBIAN_MAINLINE_KERNEL_VERSION='4.9'
that didn't work, I still get a 4.10.1 kernel build
2. then changed configration.sh ARMBIAN_MAINLINE_KERNEL_VERSION='4.9'
that didn't work either, I got 4.10.1 kernel build
Any other tricks?
-jerry
There is no MAINLINE kernel for H3 board, we are attached to some development branch.
This way:
KERNELBRANCH='branch:orange-pi-4.9'
thanks, the line worked, I see the compile now pulling orange-pi-4.9.
Unfortunately, the compiled failed.  Have anyone tried to 4.9?
  │   LD      drivers/staging/built-in.o                                   │
  │ Makefile:988: recipe for target 'drivers' failed                       │
  │ make: *** [drivers] Error 2
Problem is here, any quick thoughts how to proceed?  Is this just me, or the current branch shouldn't compile with 4.9?
result [-Wunused-result]
  devm_request_irq(dev, irq, sdio_irq_handler, 0, "xradio", func);
  CC [M]  drivers/media/usb/stkwebcam/stk-webcam.o
  CC [M]  drivers/net/wireless/realtek/rtl8189fs/core/rtw_recv.o
  CC [M]  drivers/scsi/iscsi_tcp.o
  CC [M]  drivers/net/wireless/realtek/rtl8189fs/core/rtw_sta_mgt.o
drivers/spi/spi-sun6i.c: In function ‘sun6i_spi_fill_fifo’:
drivers/spi/spi-sun6i.c:160:12: error: ‘struct sun6i_spi’ has no member named ‘fifo_depth’
  cnt = sspi->fifo_depth - sun6i_spi_get_tx_fifo_count(sspi);
drivers/spi/spi-sun6i.c: In function ‘sun6i_spi_transfer_one’:
drivers/spi/spi-sun6i.c:304:19: error: ‘struct sun6i_spi’ has no member named ‘fifo_depth’
  if (tx_len > sspi->fifo_depth)
drivers/spi/spi-sun6i.c: In function ‘sun6i_spi_handler’:
drivers/spi/spi-sun6i.c:345:34: error: ‘struct sun6i_spi’ has no member named ‘fifo_depth’
   sun6i_spi_drain_fifo(sspi, sspi->fifo_depth);
drivers/spi/spi-sun6i.c:352:34: error: ‘struct sun6i_spi’ has no member named ‘fifo_depth’
drivers/spi/spi-sun6i.c:360:33: error: ‘struct sun6i_spi’ has no member named ‘fifo_depth’
   sun6i_spi_fill_fifo(sspi, sspi->fifo_depth);
  LD [M]  drivers/media/usb/gspca/gspca_sq905c.o
When you go back with version, patches might break. You will need to deal with that ... check output/debug/patching.log for details and fix patches. In case patches are not important for you, disable them.
No other way.
