(I am running Ubuntu Core QT-Embedded on a nanoPi Neo using this network adapter)
The first time I used the network adapter it worked perfectly. I saw the adapter when I typed ifconfig -a and it connected to my network when I typed the following commands:
ifdown wlan0
ifup wlan0
Then I unplugged the power supply and plugged it back in and now it doesn't work or show up on ifconfig -a.
I tested it out on my Windows machine and the adapter works fine, and when I type lsusb I can see a network adapter so I'm very confused.
How can I resolve this issue?
    3.757937] Bluetooth: HCIATH3K protocol initialized
[    3.767830] Bluetooth: MSM Sleep Mode Driver Ver 1.2
[    3.777724] Bluetooth: init no bt used in configuration
[    3.794034] calibrat: max_cpufreq 1200Mhz Type 0!
[    3.803767] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    3.817974] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Jan 20 2017 at 15:19:15
[    3.834286] [mmc]: get mmc0's sdc_power is null!
[    3.844265] [mmc]: MMC host used card: 0x1, boot card: 0x1, io_card 0
[    3.858438] no red_led, ignore it!
[    3.859876] [mmc]: sdc0 power_supply is null
[    3.876872] Registered led device: green_led
[    3.885730] Registered led device: blue_led
[    3.895844] usbcore: registered new interface driver usbhid
[    3.906104] usbhid: USB HID core driver
[    3.915195] pcm5102a_probe
[    3.925663] asoc: pcm5102a-hifi <-> pri_dai mapping ok
[    3.940254] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    3.951516] oprofile: using arm/armv7-ca7
[    3.960263] u32 classifier
[    3.967287]     Actions configured
[    3.975072] Netfilter messages via NETLINK v0.30.
[    3.978570] mmc0: new high speed SDHC card at address aaaa
[    3.979139] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    3.980465]  mmcblk0: p1 p2
[    4.010489] nf_conntrack version 0.5.0 (7907 buckets, 31628 max)
[    4.021646] ctnetlink v0.93: registering with nfnetlink.
[    4.031653] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    4.043509] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    4.054492] xt_time: kernel timezone is -0000
[    4.063686] IPv4 over IPv4 tunneling driver
[    4.072938] gre: GRE over IPv4 demultiplexor driver
[    4.082527] ip_gre: GRE over IPv4 tunneling driver
[    4.092570] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.102719] arp_tables: (C) 2002 David S. Miller
[    4.111895] TCP: cubic registered
[    4.119487] Initializing XFRM netlink socket
[    4.128391] NET: Registered protocol family 10
[    4.138413] Mobile IPv6
[    4.145008] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    4.155019] IPv6 over IPv4 tunneling driver
[    4.164472] NET: Registered protocol family 17
[    4.173232] NET: Registered protocol family 15
[    4.182175] Bluetooth: RFCOMM TTY layer initialized
[    4.191380] Bluetooth: RFCOMM socket layer initialized
[    4.200851] Bluetooth: RFCOMM ver 1.11
[    4.208717] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.218358] Bluetooth: BNEP filters: protocol multicast
[    4.227886] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.238346] L2TP core driver, V2.0
[    4.245820] PPPoL2TP kernel driver, V2.0
[    4.253720] L2TP IP encapsulation support (L2TPv3)
[    4.262566] L2TP netlink interface
[    4.269775] L2TP ethernet pseudowire support (L2TPv3)
[    4.279353] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    4.291439] ThumbEE CPU extension supported.
[    4.299701] Registering SWP/SWPB emulation handler
[    4.310259] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 17:30:24 UTC (63024)
[    4.322993] ths_fetch_sysconfig_para: type err  device_used = 1.
[    4.334907] CPU Budget:Register notifier
[    4.343013] CPU Budget:register Success
[    4.350924] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    4.367790] [rf_pm]: module power0 name vcc-wifi-33
[    4.377094] [rf_pm]: Did not config module_power1 in sys_config
[    4.387528] [rf_pm]: Did not config module_power2 in sys_config
[    4.397915] [rf_pm]: Did not config module_power3 in sys_config
[    4.408240] [rf_pm]: mod has no chip_en gpio
[    4.416693] [rf_pm]: failed to fetch lpo_use_apclk
[    4.425714] [rf_pm]: regulator on.
[    4.433213] [wifi_pm]: no wifi used in configuration
[    4.442421] [rfkill]: init no bt used in configuration
[    4.451795] ALSA device list:
[    4.458666]   #0: Pcm5102a
[    4.465201]   #1: sndhdmi
[    4.471965] Freeing init memory: 324K
[    5.417952] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.441862] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[    5.889998] systemd[1]: System time before build time, advancing clock.
[    6.490383] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    6.532611] systemd[1]: Detected architecture arm.
[    6.587753] systemd[1]: Set hostname to <FriendlyARM>.
[    6.998103] systemd[1]: Created slice User and Session Slice.
[    7.014151] systemd[1]: Reached target Swap.
[    7.027866] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.046108] systemd[1]: Listening on Journal Audit Socket.
[    7.061599] systemd[1]: Created slice System Slice.
[    7.076010] systemd[1]: Reached target Slices.
[    7.090259] systemd[1]: Listening on udev Control Socket.
[    7.105663] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.123324] systemd[1]: Created slice system-getty.slice.
[    7.139053] systemd[1]: Listening on udev Kernel Socket.
[    7.155019] systemd[1]: Reached target Encrypted Volumes.
[    7.171047] systemd[1]: Reached target Remote File Systems (Pre).
[    7.188235] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.207071] systemd[1]: Reached target Paths.
[    7.222533] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.239892] systemd[1]: Reached target Remote File Systems.
[    7.256635] systemd[1]: Listening on Journal Socket.
[    7.380980] systemd[1]: Starting Load Kernel Modules...
[    7.540614] systemd[1]: Mounting Debug File System...
[    7.701000] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.743519] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.860669] systemd[1]: Starting Journal Service...
[    8.000727] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    8.123428] systemd[1]: Mounted Debug File System.
[    8.142025] systemd[1]: Started Journal Service.
[   10.675318] systemd-journald[171]: Received request to flush runtime journal from PID 1
[   11.050916] Loading modules backported from Linux version v4.4.2-0-g1cb8570
[   11.050942] Backport generated by backports.git v4.4.2-1-0-gbec4037
[   11.310081] usb 4-1: reset high-speed USB device number 2 using sunxi-ehci
[   11.464750] mt7601u 4-1:1.0: ASIC revision: 76010001 MAC revision: 76010500
[   11.464940] gmac0: probed
[   11.465277] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   11.512630] mt7601u 4-1:1.0: Warning: unsupported EEPROM version 0d
[   11.512650] mt7601u 4-1:1.0: EEPROM ver:0d fae:00
[   11.727310] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   11.728522] usbcore: registered new interface driver mt7601u
[   14.460238] PHY: gmac0-0:00 - Link is Up - 100/Full
[   22.200162] eth0: no IPv6 routers present
[   27.978760] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   27.988606] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   27.998480] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.008355] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.018229] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.028105] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.037981] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.043740] ehci_irq: highspeed device disconnect
[   28.043824] ehci_irq: highspeed device connect
[   28.043906] usb 4-1: USB disconnect, device number 2
[   28.047733] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.057605] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.067353] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.077102] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.086853] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.096603] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.106363] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.116232] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.125980] mt7601u 4-1:1.0: Error: RX urb failed:-71
[   28.530071] ehci_irq: highspeed device disconnect
[   28.530110] ohci_irq: fullspeed or lowspeed device connect
[   29.160182] hub 8-0:1.0: unable to enumerate USB device on port 1
[   32.025184] ehci_irq: highspeed device connect
[   32.230129] ehci_irq: highspeed device disconnect
[   32.230184] ohci_irq: fullspeed or lowspeed device connect
[   36.880077] hub 8-0:1.0: Cannot enable port 1.  Maybe the USB cable is bad?
[   41.290171] hub 8-0:1.0: Cannot enable port 1.  Maybe the USB cable is bad?
[   45.700142] hub 8-0:1.0: Cannot enable port 1.  Maybe the USB cable is bad?
[   50.110154] hub 8-0:1.0: Cannot enable port 1.  Maybe the USB cable is bad?
[   50.118051] hub 8-0:1.0: unable to enumerate USB device on port 1
If nothing was changed on the system I would try using different cables / PSU. I assume you are powering thee board via micro USB connector, which is problematic by default.
  On 3/6/2017 at 6:08 PM, elias.bothell said:
How do you suggest I power it?
Expand
If you have an option to power via micro USB or via GPIO pins, than GPIO is suggested method.
