fensoft Posted April 11, 2024 Posted April 11, 2024 (edited) What you need: - A DQ08 (got mine from aliexpress) - An sdcard (4g if you want to use external usb3 ssd or 32g if not) If you're lazy and trust my image (you shouln't, as I can bundle malwares inside): - flash this using this - usb2serial included - put in DQ08 and plug it in ethernet - scan for the ip using this - in windows terminal, using password=1234: ssh root@BOXIP To build the sd card, i've used this tutorial: - install wsl on your windows - apply this patch Spoiler sudo wget --output-document=/usr/share/keyrings/armbian-next.gpg https://apt-test.next.armbian.com/armbian-next.gpg cat << EOD | sudo tee /etc/apt/sources.list.d/armbian-next.list deb [signed-by=/usr/share/keyrings/armbian-next.gpg] http://apt-test.next.armbian.com armbian main deb [signed-by=/usr/share/keyrings/armbian-next.gpg] http://apt-test.next.armbian.com armbian-$(lsb_release -cs) main EOD sudo apt update && sudo apt list --upgradable | grep -i armbian - open wsl shell - install docker on wsl: curl -fsSL get.docker.com | sh - run docker: sudo /etc/init.d/docker start - permit to use docker: sudo usermod -aG docker $USER - open a new shell (important) - follow this Spoiler git clone https://github.com/ilyakurdyukov/rk3528-tvbox.git cd rk3528-tvbox git clone --depth=1 https://github.com/armbian/build armbian-build cp -R armbian-patch/* armbian-build/ cd armbian-build ./compile.sh build BOARD=rk3528-tvbox BRANCH=legacy BUILD_DESKTOP=no BUILD_MINIMAL=yes EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm cd ../.. cat <<EOF > rk3528-tvbox/build.sh #!/bin/bash cd /build IMAGE=\`ls /build/armbian-build/output/images/*.img\` losetup -D losetup --partscan /dev/loop0 \$IMAGE mount /dev/loop0p1 /mnt cd devicetree cp orig/*.dtsi . patch -p1 -i rk3528-tvbox.patch make NAME=rk3528-vontar-dq08 PRESET=LINUX cp rk3528-vontar-dq08.dtb /mnt/dtb/rockchip sed "s#fdtfile=.*#fdtfile=rockchip/rk3528-vontar-dq08.dtb#" -i /mnt/armbianEnv.txt losetup -D cat \$IMAGE | gzip > /build/\`basename \$IMAGE\`.gz EOF chmod a+x rk3528-tvbox/build.sh docker run -it -v /dev:/dev --privileged=true -v `pwd`/rk3528-tvbox:/build --rm armbian.local.only/armbian-build:initial /build/build.sh - flash the img file found in Linux/Ubuntu/home/XXX/armbian-build/output/image using this - put in DQ08 and plug it in ethernet - scan for the ip using this - in windows terminal, using password=1234: ssh root@BOXIP If, like me, you want to use an USB3 SSD: - flash the usb3 drive with the same image - plug to the box - e2label /dev/sda2 ssd - change /boot/armbianEnv.txt: rootdev=LABEL=ssd - reboot - check free size with: df -h / - optional: remove unused boot partition: fdisk /dev/sda + d + 1 + w + q - optional: remove unused data partition: fdisk /dev/mmcblk0 + d + 2 + w + q If, like me, you have usb2serial adapters: - follow this but remove all parameters at the end of ./compile.sh build and during kernel configuration, enable this: Device Drivers -> USB Support -> USB Serial Converter Support -> FTDI and PL230x Edited April 11, 2024 by fensoft 1 Quote
SteeMan Posted April 11, 2024 Posted April 11, 2024 Please do not promote forks of Armbian on these forums. If you what to help Armbian, please submit PRs and contribute code that makes Armbian better. It doesn't help to have yet another fork of stuff out there that never gets contributed back. Your warning about using external builds applies equally well to external git sources. No one should trust this unless they inspect all the changes you have made from genuine Armbian. User be warned. 0 Quote
fensoft Posted April 11, 2024 Author Posted April 11, 2024 (edited) do you want me to remove all binaries ? about tvbox in the genuine armbian, i'm pretty sure that i've read somewhere armbian would not support them Edited April 11, 2024 by fensoft 0 Quote
SteeMan Posted April 11, 2024 Posted April 11, 2024 They aren't officially supported, but there are many TV boxes that are Community Maintained and available on the Armbian download page. No need to remove the binaries, your warnings are good enough. 2 Quote
Hqnicolas Posted April 12, 2024 Posted April 12, 2024 (edited) @fensoft congratulations for your work, please stop acting like you dont live in society. Just do it in a PR. Or Compile 30x backdoor images to US. Edited April 12, 2024 by Hqnicolas 0 Quote
Shinjin Posted April 13, 2024 Posted April 13, 2024 Is it possible to install Armbian into internal memory without jumping though hoops? 0 Quote
fensoft Posted April 13, 2024 Author Posted April 13, 2024 On 4/12/2024 at 7:02 AM, Hqnicolas said: please stop acting like you dont live in society. Just do it in a PR. Or Compile 30x backdoor images to US. Toxicity level over 9000, you better keep it for yourself next time. About PR, I can't and dont want. It's not my patch. Feel free to do it yourself if it's so important. 0 Quote
fensoft Posted April 13, 2024 Author Posted April 13, 2024 22 minutes ago, Shinjin said: Is it possible to install Armbian into internal memory If I understand well, boot loader is at the begining of the emmc. Doing armbian-install will probably ends with system not booting anymore. 0 Quote
Shinjin Posted April 13, 2024 Posted April 13, 2024 Yes, but AFAIK on other TV boxes an internal install shouldn't touch vital portions of the emmc. And Rockchip devices should still boot from SDCARD? 0 Quote
fensoft Posted April 13, 2024 Author Posted April 13, 2024 I have the original software from vendor if needed. But, as I dont trust internal emmc, I never tried. 0 Quote
Hqnicolas Posted April 13, 2024 Posted April 13, 2024 (edited) 57 minutes ago, fensoft said: I dont trust internal emmc I have done the internal EMMC armbian and I dont trust this EMMC too... Edited April 13, 2024 by Hqnicolas 0 Quote
fensoft Posted Sunday at 11:48 PM Author Posted Sunday at 11:48 PM (edited) I have uploaded an updated version here. Also, for thoses who want to use internal emmc (boot without sdcard), you can run this script: Spoiler #!/bin/bash set -e set -x TARGET=/dev/mmcblk2 IMAGE=Armbian-unofficial_25.05.0-trunk_Rk3528-tvbox_bookworm_legacy_5.10.160_minimal.img sed -e 's/\s*\([\+0-9a-zA-Z]*\).*/\1/' << EOF | fdisk $TARGET d # delete 3 d # delete 4 d # delete 5 d # delete 6 d # delete 7 d # delete 8 d # delete 9 d # delete 10 d # delete 11 d # delete 12 d # delete 13 d # delete 14 d # delete 2 n # new partition 2 16384 +16384 n # new partition 3 +524288 n # new partition 4 61071295 n # new partition 5 61071296 61071325 x # expert mode n # set name 2 uboot n # set name 3 boot n # set name 4 rootfs p # print r # return w # save q # quit EOF sed -e 's/\s*\([\+0-9a-zA-Z]*\).*/\1/' << EOF | gdisk $TARGET x # expert mode a # set attribute 3 2 w Y EOF LO=`losetup -f` losetup --partscan $LO $IMAGE dd bs=512 if=$LO of=${TARGET}p2 count=16384 skip=16384 dd if=/dev/loop0p1 of=${TARGET}p3 bs=1M status=progress dd if=/dev/loop0p2 of=${TARGET}p4 bs=1M status=progress You can reinstall android using this, connecting DQ08's usb2 port (using a male-male usb cable) to the computer while pushing the button in the AV connector. Then, in the app (extracted to c:\), choose firmware / firmware.bin / restore / run. Edited Sunday at 11:53 PM by fensoft 0 Quote
micron Posted Tuesday at 01:17 PM Posted Tuesday at 01:17 PM Hello I was able to build image (both debian and ubuntu) according to this instructions: https://gist.github.com/fensoft/1ff3ef81ab2bd9ed9364a564aa2cbcd5?permalink_comment_id=5576642#file-build-sh image is flashed to microsd card. However tvbox does not boot from sdcard - I see that it boots up regulary to android. Also I have found that in AV jacker on board there is button, so if hold it during boot - you are into Android recovery with options (reboot system/ reboot to bootloader/ fastboot /udpates ADB /updates from SD card/ factory reset /wipe / power off) The question is how to make TV box boot from sdcard? I was setting up armbian to orange pi - and it by default boots from sdcard. But with tv box according to posts and videos also should.... I'm trying to flash: Transpeed ATV Android 13 TV BOX RK3528 With Voice Assistant TV Apps Dual Wifi Quad Core Cortex A53 Support 8K 4K Video BT5.0 with 4G ram: https://www.aliexpress.com/item/1005007785484949.html 0 Quote
fensoft Posted Tuesday at 01:45 PM Author Posted Tuesday at 01:45 PM you don't have to. it's already trying to boot by default to sd. you can either try to install the same android as me, change the sdcard or plug an usb2serial cable @ 1.5Mbauds to check uboot logs. 0 Quote
micron Posted Tuesday at 02:03 PM Posted Tuesday at 02:03 PM I thought there should be any console output to hdmi, ok will try with uart. By the way @fensoft are you using armbian on it? is it stable? 0 Quote
