My Orange Pi Lite + octoprint often freeze during a print.
I noticed that when it happens I can not access either the web panel nor in ssh.
I believe that it detaches from wifi and go into freeze.
I have already ruled out power supply problems and overheating.
Someone can help me?My image is: Armbian_5.25_Orangepilite_Ubuntu_xenial.
Here is a screenshot of the statistics:
Thanks!
Hello! Thank you @tkaiser for the answer.
I run the "armbianmonitor -c "$HOME" but it takes long time to write files..
With verbose = 7 (already set) and "sudo armbianmonitor -u", It has generated this log:
http://sprunge.us/gLgW
The problem appeared on Sat 11 March.
I hope this is helpful.
Please let it continue and then again provide the output from 'sudo armbianmonitor -u'. Anyway, your SD card already looks suspicious:
               oemid: 0x0000
              manfid: 0x000000
What is printed on the card?
Ok, I will provide a new log when it is done.
"What is printed on the card?"
What do you mean exactly?
Ooooh...yes, maybe my Sd card have a bad brand.
Result from tests told me that the card haven't errors, but is slow in random write. Do you need screenshot of messages?
Anyway, here is my new log:
http://sprunge.us/YQKP
Thank you so much.
Well, not entirely true. The test just confirmed that the card doesn't show a fake capacity (not common with 8GB cards but with larger ones). Since almost half the capacity is already used this hasn't been tested. And since you experienced some freezes/crashes in the past maybe you experienced some sort of filesystem corruption already. Hmm... it seems to force a fsck at reboot one needs to add 'fsck.mode=force' to kernel cmdline ( @zador.blood.stainedplease stop/correct me if I'm telling BS!)
Anyway, the card isn't that slow but since card metadata looks strange and performance is rather low in case you're able to get a genuine Samsung EVO+ with 32 or 64GB this would be a try even if it doesn't resolve the freezes (still hard to tell what's the culprit, maybe you would need a serial console attached with kernel messages redirected to this to get a clue)
Should work on new images.
Also output of "sudo tune2fs -l /dev/mmcblk0p1" may be helpful to check if FS was checked and/or needs repairing.
Thanks @tkaiser and @zador.blood.stained
Meanwhile I test the microSD card to verify if is bad and fake (microSD in Orange Pi), I have a real samsung Evo U1 (the same showed on User-Guide_Getting-Started). I will use it to reinstall OS.
Can I create an image of the system from the old microSD card and burn it on new microSD? Or best way is to reinstall all from 0? Beacuse I've a lot of things to backup..
EDIT: Anyway, this is a screen of informations about test
Sure. But the new card has to be at least 'of same size' otherwise partitioning will throw errors. You can search the forum for 'backup sd card emmc' or 'mmcblk0 dd lz4' to get a lot of valuable stuff regarding creation of device images. But as zador already mentioned take care that filesystem isn't corrupted and try at least to repair it if that's true.
In case new card is significantly larger you might want to expand rootfs again. With all updates applied running off new card it should be as simple as
sudo systemctl enable resize2fs && sudo reboot
Yes, the Samsung Evo microSD is of 16GB, indeed the old microSD is 8GB (or less, for the fact that it is fake).
Can I use this script?
Or maybe the best way is this?
Sorry, the advices before were wrong. In the meantime I switched my brain on again:
All you need is a device backup from a probably failing SD card and not a script doing fancy stuff. So better use ddrescue and maybe pipe it through any of these compressors mentioned here: https://forum.armbian.com/index.php?/topic/2096-backup-script-for-block-devices/&do=findComment&comment=16056
In case you do the device backup on a PC or Mac I wouldn't use any compression just to be able to use Etcher in the next step to burn the image to the Samsung card (but compression is always nice if you want to keep 'block device' backups)
2 minutes ago, danybr said:
the core command is " sudo dd if=/dev/disk1 of=~/SDCardBackup.dmg "
Nope, better use ddrescue instead. It's just a 'brew install ddrescue' away:
macbookpro-tk:~ tk$ brew search ddrescue
ddrescue
macbookpro-tk:~ tk$ brew info ddrescue
ddrescue: stable 1.21 (bottled)
GNU data recovery tool
https://www.gnu.org/software/ddrescue/ddrescue.html
/usr/local/Cellar/ddrescue/1.20 (11 files, 271.9K) *
  Poured from bottle on 2015-09-20 at 15:17:46
From: https://github.com/Homebrew/homebrew-core/blob/master/Formula/ddrescue.rb
==> Dependencies
Build: lzip
And here is the result. It is the backup of the old microSD card.
I was right to set the size of 4M?
Doesn't really matter. Results look good so now let Etcher do the job and please report back within a few days if exchange of the SD card really did the job or not.
BTW: In OS X (or macOS as it's now called) I wouldn't name 'foreign' OS images with .dmg extension since there are a few tools included that make a lot of assumptions based on filename suffix. Better use .img instead -- just in case. Names/suffixes shouldn't matter but unfortunately there exists some hardcoded garbage here and there (or maybe I'm just too old and these problems have been resolved within the last decade. An easy way is to check with 'hdiutil imageinfo')
I tried this command, because system read only 7.1 GB. After reboot, I have the same size. Do you know why?
This is the output and the command take around 3 second to complete..
Synchronizing state of resize2fs.service with SysV init with /lib/systemd/systemd-sysv-install...
Executing /lib/systemd/systemd-sysv-install enable resize2fs
EDIT: I tried another time and now it works. I'm sorry.
How can I check the file system?
Dear @tkaiser and @zador.blood.stained
Today I had 2 freezes in the same day (in real, in 4 hours of work).
I generate new log, and is here:
http://sprunge.us/RDEU
I hope you can help me!
Thanks
EDIT: other informations
octoprint@orangepilite:~$ sudo tune2fs -l /dev/mmcblk0p1
tune2fs 1.42.13 (17-May-2015)
Filesystem volume name:   <none>
Last mounted on:          /
Filesystem UUID:          869936a4-c08b-41a3-8bef-a42ddd71700c
Filesystem magic number:  0xEF53
Filesystem revision #:    1 (dynamic)
Filesystem features:      has_journal ext_attr resize_inode dir_index filetype needs_recovery extent flex_bg sparse_super large_file huge_file uninit_bg dir_nlink extra_isize
Filesystem flags:         signed_directory_hash
Default mount options:    journal_data_writeback user_xattr acl
Filesystem state:         clean
Errors behavior:          Continue
Filesystem OS type:       Linux
Inode count:              923680
Block count:              3760936
Reserved block count:     44258
Free blocks:              2879609
Free inodes:              754664
First block:              0
Block size:               4096
Fragment size:            4096
Reserved GDT blocks:      172
Blocks per group:         32768
Fragments per group:      32768
Inodes per group:         8032
Inode blocks per group:   502
Flex block group size:    16
Filesystem created:       Sun Feb  5 12:44:58 2017
Last mount time:          Tue Mar 14 13:17:02 2017
Last write time:          Thu Jan  1 00:00:06 1970
Mount count:              61
Maximum mount count:      -1
Last checked:             Sun Feb  5 12:44:58 2017
Check interval:           0 (<none>)
Lifetime writes:          18 GB
Reserved blocks uid:      0 (user root)
Reserved blocks gid:      0 (group root)
First inode:              11
Inode size:               256
Required extra isize:     28
Desired extra isize:      28
Journal inode:            8
Default directory hash:   half_md4
Directory Hash Seed:      afb4d02d-24fd-4dbd-932d-278e4c40115a
Journal backup:           inode blocks
Well, ultra cheap hardware like $12 computers might break... since we had so many reports of 'no power problems ... 1 week later ... it turned out my PSU...' a quick check whether you run in undervoltage situations (execute with the same peripherals connected at the time the freezes happen):
cd /tmp
git clone https://github.com/ssvb/cpuburn-arm
gcc cpuburn-a7.S
./a.out
cd /tmp
gcc cpuburn-a7.S
./a.out
Sorry, is not very clear for me what I should do.. My english is bad :(
Anyway I run the script for 4 minutes for a test and statistics are here:
No freeze during the test nor after.
Still hard to tell but at least it looks not related to underpowering or SD card. Serial console output needed with highest verbosity set in armbianEnv.txt
how can I do it?  Thanks
Follow the instructions in linux-sunxi wiki please: http://linux-sunxi.org/Orange_Pi_Lite#Locating_the_UART
Then you increase verbosity as outlined in the docs https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-toogle-verbose-boot reboot and wait until the next freeze happens. And then maybe on the second machine connected to the serial console some interesting messages can be collected. 'Second machine' can be as small as another Lite or an OPi Zero (which you might want to order anyway to probably replace the Lite if it's a hardware issue?)
I don't have another OPi to use for this scope.. Buy another one means that I will "solve" my problem in 2 months (shipping problems).
Can I use an Arduino for this scope?
