AlexK Posted April 29, 2024 Posted April 29, 2024 Hi! Currently try to figure out how to run my freshly builded Armbian using QEMU arm64. According to this tutorial: https://docs.armbian.com/Developer-Guide_Build-Preparation/ I prepare clean Jammy VM. Build using this CMD: ./compile.sh BOARD=qemu-uboot-arm64 BRANCH=current RELEASE=bookworm Build process was going smoothly i pick up two files from output folder: 1) Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.img.qcow2 2) Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.u-boot.bin Currently boot up process stucked, i can run U-boot and mount qcow2 image using this CMD: qemu-system-aarch64 \ -machine virt -cpu cortex-a57 \ -netdev user,id=net0 -device e1000,netdev=net0 \ -serial stdio \ -bios Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.u-boot.bin \ -drive if=none,file=Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.img.qcow2,id=mydisk \ -device ich9-ahci,id=ahci \ -device ide-hd,drive=mydisk,bus=ahci.0 U-boot see the drive with rootfs, but during boot process i had this error: Failed to load '/boot/uInitrd' Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid Boot failed (err=-14) Full boot process log: U-Boot 2023.10-armbian (Mar 14 2024 - 01:18:23 +0000) DRAM: 128 MiB Core: 51 devices, 14 uclasses, devicetree: board Flash: 64 MiB Loading Environment from Flash... *** Warning - bad CRC, using default environment In: pl011@9000000 Out: pl011@9000000 Err: pl011@9000000 Net: e1000: 52:54:00:12:34:56 eth0: e1000#0 Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': Scanning bootdev 'fw-cfg@9020000.bootdev': fatal: no kernel available No working controllers found scanning bus for devices... Target spinup took 0 ms. SATA link 1 timeout. SATA link 2 timeout. SATA link 3 timeout. SATA link 4 timeout. SATA link 5 timeout. AHCI 0001.0000 32 slots 6 ports 1.5 Gbps 0x3f impl SATA mode flags: 64bit ncq only Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 54564.0 MB = 53.2 GB (111747072 x 512) Scanning bootdev 'ahci_scsi.id0lun0.bootdev': 0 script ready scsi 1 ahci_scsi.id0lun0.bootdev /boot/boot.scr ** Booting bootflow 'ahci_scsi.id0lun0.bootdev.part_1' with script scanning bus for devices... Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 54564.0 MB = 53.2 GB (111747072 x 512) Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 54564.0 MB = 53.2 GB (111747072 x 512) <DIR> 4096 . <DIR> 4096 .. <SYM> 28 Image <SYM> 24 dtb <DIR> 4096 dtb-6.6.29-current-arm64 38518 boot.bmp 0 .next <SYM> 28 uInitrd 906 boot.cmd 6040046 System.map-6.6.29-current-arm64 978 boot.scr 49178863 uInitrd-6.6.29-current-arm64 318778 config-6.6.29-current-arm64 38134272 vmlinuz-6.6.29-current-arm64 49178799 initrd.img-6.6.29-current-arm64 KERNEL LOAD ADDRESS: kernel_addr_r : 0x40400000 INITRD LOAD ADDRESS: ramdisk_addr_r: 0x44000000 FDT LOAD ADDRESS : fdt_addr : 0x40000000 38134272 bytes read in 853 ms (42.6 MiB/s) ** Reading file would overwrite reserved memory ** Failed to load '/boot/uInitrd' Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid Boot failed (err=-14) --- ----------- ------ -------- ---- ------------------------ ---------------- (1 bootflow, 1 valid) Any ideas what i'm doing wrong? 0 Quote
Solution AlexK Posted April 29, 2024 Author Solution Posted April 29, 2024 The problem was with -m flag, i forget to allocate enough memory for VM to start, so working CMD: qemu-system-aarch64 \ -machine virt -cpu cortex-a57 -m 512 \ -netdev user,id=net0 -device e1000,netdev=net0 \ -serial stdio \ -bios Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.u-boot.bin \ -drive if=none,file=Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.img.qcow2,id=mydisk \ -device ich9-ahci,id=ahci \ -device ide-hd,drive=mydisk,bus=ahci.0 1 Quote
Igor Posted January 16, 2025 Posted January 16, 2025 On 4/29/2024 at 9:50 AM, AlexK said: The problem was with -m flag, i forget to allocate enough memory for VM to start, so working CMD: I am trying to integrate this into the armbian-config to make this easier. Anyone gut lucky with this method? 0 Quote
eselarm Posted January 16, 2025 Posted January 16, 2025 A quick look at the shell code makes me think that it is a different purpose compared to how I use virtualization. I use only HW accelerated based virtualization, so -enable-kvm flag is missing, but might be added by virt-install. Also mostly Arm on Arm although I also use x86 on x86 as well. I do not use qcow2, but just flat images or a physical SD-card or NBD or LVM. Before I got my Rock3A, I downloaded the Armbian Noble image for it (was 6.6.62) but put a 6.12 *rk3588 kernel on it as well. With the default Armbian U-Boot for QEMU I could then prepare everything and already 'run' my Rock3A as a VM on NanoPi-R6C like this: taskset --cpu-list 0-3 qemu-system-aarch64 \ -M virt -cpu host -enable-kvm -m 2048 -smp 4 \ -bios u-boot.bin \ -drive if=none,file=rock3a.img,format=raw,id=hd0 \ -device virtio-blk-device,drive=hd0 \ -netdev bridge,id=hn1 -device virtio-net,netdev=hn1,mac=xx:xx:xx:xx:xx:xx \ -nographic The taskset is needed if host runs 6.1.x vendor kernel and also makes it more realistic w.r.t. speed as then the VM gets 4x Cortex-A55, same as real Rock3A. The 6.12/rk3588 kernel (inside the VM) was needed as that one has all included w.r.t. machine virt (same as vanilla Debian Bookworm kernel). A note is that I later on added Btrfs support to a custom build u-boot for QEMU and converted Ext4 in rock3a.img into Btrfs, but principle is the same. Btrfs offers online shrink and differential snapshots that I use for remote backups. And with a MAC-address equal to the real Rock3A, it is easy flipping between real and VM. Also note is that the following file needs to be created on the host, assuming it uses br0 as base for network I/O: # cat /etc/qemu/bridge.conf allow br0 To use full graphics in VM and for multi-year running VM on my RPi4B, I also use virsh and UEFI. But usually only CLI is needed. 1 Quote
