Hello everyone !
I'm facing a hard issue that I still cannot solve. On my Raspberry, on Raspberry Os, to be able to use Rustdesk (https://github.com/rustdesk/rustdesk, an open source Teamviewer ) I needed to add some tweaks to the /boot/config.txt file:
hdmi_force_hotplug=1 (See doc)
hdmi_group=2 (See doc)
Now, I'm trying to replicate these behaviours on Armbian for Opi zero 3 (but it could probably work for all Allwinner cpus if a solution is found)
When looking on the Armbian documentation for Sunxi, I've found this (See doc) :
For example to always use the hdmi connector, even if no cable is inserted, using edid info when available and otherwise initalizing it at 1024x768@60Hz, use:
setenv video-mode sunxi:1024x768-24@60,monitor=dvi,hpd=0,edid=0
That really looks like what I want to achieve, but when adding this line to the /boot/boot.cmd file, re-building it using:
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
and after rebooting, I still can't connect to my distant Opi.
Am I missing something? Did someone has faced something similar?
Thanks for any help !
