Bad device specification mmc 0 Allwinner A13
I compiled
Armbian-unofficial_23.11.0-trunk_Olinux-som-a13_jammy_current_6.1.63_minimal.img
Burn it to sd card, and tried to run it on my old Allwinner A13 laptop, and is got this Error message:
U-Boot 2023.10-armbian (Oct 14 2023 - 01:13:59 +0000) Allwinner Technology
CPU:   Allwinner A13 (SUN5I)
Model: Olimex A13-Olinuxino
DRAM:  512 MiB
Core:  59 devices, 21 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20c90
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... MMC: no card present
** Bad device specification mmc 0 **
Setting up a 1024x768 vga console (overscan 0x0)
In:    serial,usbkbd
Out:   serial,vidconsole
Err:   serial,vidconsole
Allwinner mUSB OTG (Peripheral)
Net:   using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
eth0: usb_ether
Couldn't find partition mmc 0
starting USB...
Bus usb@1c14000: USB EHCI 1.00
Bus usb@1c14400: USB OHCI 1.0
scanning bus usb@1c14000 for devices... 2 USB Device(s) found
scanning bus usb@1c14400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
Device 0: unknown device
The remote end did not respond in time.missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-de-ad-be-ef-00-01
The remote end did not respond in time.Retrieving file: pxelinux.cfg/00000000
The remote end did not respond in time.Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
The remote end did not respond in time.Config file not found
The remote end did not respond in time.The remote end did not respond in time.=>
Please, help me to understand, what I need to do to fix it ?  Please, I novice in u-boot and armbian, if possible, in more detail since I haven’t delved into the details of the launch very much, I’m still learning
Thank you community
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
