THT Posted May 14, 2024 Posted May 14, 2024 Armbianmonitor: https://paste.armbian.com/culalejeya Homeassistant fails to install logs.txt 0 Quote
djurny Posted August 13, 2024 Posted August 13, 2024 Hi there, Seems that you are trying to download an incorrect image for HASS: 2024-05-14 11:38:38.835 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/odroid-n2-homeassistant:2024.5.3: 404 Client Error for http+docker://localhost/v1.45/images/ghcr.io/home-assistant/odroid-n2-homeassistant:2024.5.3/json: Not Found ("No such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2024.5.3") 2024-05-14 11:38:38.837 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec Looks like the HASS supervised installation is trying to install a docker image for an Odroid N2 instead of the Libre Renegade? According to Odroid, the N2 is based on an Amlogic SoC and not on a Rockchip SoC (like the Libre Renegade). Apart from that, it appears it cannot locate the docker image either. Perhaps contact the HASS community? You can also try to install Armbian on your SBC and use the regular Docker image for HASS. Hope that helps, Groetjes, 0 Quote
Igor Posted August 13, 2024 Posted August 13, 2024 22 minutes ago, djurny said: You can also try to install Armbian on your SBC and use the regular Docker image for HASS. Or latest image from download section: https://dl.armbian.com/renegade/Bookworm_current_minimal-homeassistant Then we try to resolve. I don't have this hardware to be able to test. I tested on some other devices. 0 Quote
Marco Zberg Posted March 18, 2025 Posted March 18, 2025 Any details on this? I got the same problem with the lastest release Armbian_25.2.3_Orangepi5_bookworm_current_6.12.17-homeassistant_minimal. What is the best workaround? 0 Quote
