Hi
I installed a nvme SSD to my rockpro64 (with a generic PCIe adapter card). Somehow it only uses a x1 link instead of x4. I also observed the same behaviour with a x2 SATA card (only x1 link established).
Output of lspci:
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (downgraded)
To rule out hardware issues, I also tried the same setup with Manjaro-ARM which correctly negotiates a x4 link.
LnkSta: Speed 2.5GT/s (downgraded), Width x4
dmesg for Armbian
[    2.221206] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.221296] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    2.221334] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    2.222953] rockchip-pcie f8000000.pcie: supply vpcie1v8 not found, using dummy regulator
[    2.223187] rockchip-pcie f8000000.pcie: supply vpcie0v9 not found, using dummy regulator
[    2.286376] rockchip-pcie f8000000.pcie: wait 1000 ms (from device tree) before bus scan
[    3.298661] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.309542] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.310052] pcieport 0000:00:00.0: PME: Signaling with IRQ 58
[    3.310984] pcieport 0000:00:00.0: AER: enabled with IRQ 58
virtually identical for Manjaro-ARM
[    1.114557] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    1.114626] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    1.114655] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    1.115937] rockchip-pcie f8000000.pcie: supply vpcie1v8 not found, using dummy regulator
[    1.116100] rockchip-pcie f8000000.pcie: supply vpcie0v9 not found, using dummy regulator
[    1.176874] rockchip-pcie f8000000.pcie: wait 1000 ms (from device tree) before bus scan
[    2.234398] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    2.274272] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    2.274780] pcieport 0000:00:00.0: PME: Signaling with IRQ 58
[    2.275722] pcieport 0000:00:00.0: AER: enabled with IRQ 58
I also compared the device trees for Armbian and Manjaro. There are no differences as well.
Has anyone a hint for me what I could try to get the x4 link established?
Narrowed the issue down by testing older Armbian builds
- Armbian 23.02 with 5.15.96 Kernel -> x4 link working
- Armbian 23.8 with 6.1.50 Kernel -> x4 link working
Comparing the patches between 6.1 and 6.6 shows a new patch related to PCIe: https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.6/rk3399-fix-pci-phy.patch
Building an image without this patch indeed fixes the issue:
Linux rockpro64 6.6.30-current-rockchip64
LnkSta:	Speed 2.5GT/s (downgraded), Width x4 (ok)
So this patch does not work as expected but simply removing it is probably not an acceptable solution.
Can anyone with more understanding of PCI have a look into it?
Edit: I also commented on the pull request that introduced the patch: https://github.com/armbian/build/pull/6057
Edited by Nino
Yes! I get a degraded x1 link, too, with a Samsung 980 Pro.
I assumed it had never worked at x4, so it's interesting to hear that it is a regression.
That is O.K., but Armbian build framework does not accept HW related tickets. Forum is right place where you can bring this up and discuss what to do. Then open a PR if solution emerges ...
Without this patch, PCI probing will randomly fail. Which is worse then 100% going up in 1x. This is my 2c.
I understand that you would like to have a perfect functioning PCI system on this hardware platform and if you cover someone several weeks of R&D, this can probably be done. Since this will not happen, we have partial solution/workaround in place, this forum and we have each other.
Hi Igor
Thanks for stepping in.
I followed the path out of curiosity. My RockPro64 usually runs 2.5" SMR SATA disks, so pcie x1 is not a real bottleneck :D
I tried tinkering some more, but I cannot reproduce the original pcie probing failure (the patch is of course disabled). I rebooted many times, then set bus scan delay to 0ms (same as in andrewz1 PR) rebooted some more. But never got the training timeout error.
Do I need a specific configuration or a specific hardware to reproduce the issue?
