s-l1600-2.jpg.e7a03b7363f462f8660a9761808a7179.jpg.de096bc684ca5794fadf435cf63332d3.jpg
CPU :           RK3566 / Mali-G52 GPU
RAM :           2GB/4GB LPDDR4
ROM :           eMMC 16G/32G/64G
Bluetooth :     BT 5.0
DC In :         DC 5V/2A
USB Host :      2 High speed USB 2.0, 1 USB 3.0
Card Reader :   TF Card reader
Lan :           RJ45 Ethernet port 1GiB
Wifi :          Built-in Wifi, 802.1.1b/g/n/ac ; 2.4G/5G
SPDIF :         Coaxial(Optical)
DTB:
rk3566-slzn.dtb
Can anyone tell me how to repair the Ethernet port? The error log is as follows:
[   26.619270] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[   26.621884] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   26.624545] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Hw setup failed
[   26.769290] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   26.774068] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [Generic PHY] (irq=POLL)
[   26.777878] dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state
[   26.780446] dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state
[   26.784638] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode.
[   26.788899] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller.
[   26.791572] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a
[   26.796881] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo
[   26.880900] platform mtd_vendor_storage: deferred probe pending
[   26.881880] dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state
[   26.886026] dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state
[   26.888690] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode.
[   26.891380] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller.
[   26.893932] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a
[   26.896371] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo
[   27.776978] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[   27.779377] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   27.781771] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Hw setup failed
4 hours ago, gen ha said:
USB2.0: ✔(only one)
Find the USB port list and change 1 port USB from OTG to HOST
&usbdrd_dwc3 {
	dr_mode = "otg";
	extcon = <&usb2phy0>;
	status = "okay";
&usbdrd_dwc3 {
	dr_mode = "host";
	status = "okay";
Edited by Hqnicolas
2 hours ago, maka said:
You have to change the mdio ethernet phy from 0 to 1 in your DTB.
@gen ha
it's happnd because you're using a RK3568 DTS to build an RK3566 DTS
and it will mess with Mdio
this is your solution:
&mdio1 {
	rgmii_phy1: phy@0 {
		compatible = "ethernet-phy-ieee802.3-c22";
		reg = <0x0>;
&gmac1 {
	phy-mode = "rgmii";
	clock_in_out = "input";
	snps,reset-gpio = <&gpio2 RK_PD1 GPIO_ACTIVE_LOW>;
	snps,reset-active-low;
	/* Reset time is 20ms, 100ms for rtl8211f */
	snps,reset-delays-us = <0 20000 100000>;
	assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
	assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>;
	pinctrl-names = "default";
	pinctrl-0 = <&gmac1m1_miim
		     &gmac1m1_tx_bus2
		     &gmac1m1_rx_bus2
		     &gmac1m1_rgmii_clk
		     &gmac1m1_rgmii_bus
		     &gmac1m1_clkinout>;
	tx_delay = <0x4f>;
	rx_delay = <0x26>;
	phy-handle = <&rgmii_phy1>;
	status = "okay";
Edited by Hqnicolas
Hqnicolas
@Hqnicolas
HDMI:✔
USB2.0 X 2: ✔
USB3.0:✔
Card Reader:✔
Thanks! Effective, all three USB ports can be used now.
Edited by gen ha
to use RK3568 DTS on RK3566 chip
you will need to add these lines on the botom of dts
&gpu_opp_table {
	/delete-node/ opp-800000000;
&dmc_opp_table {
	opp-324000000 {
		opp-hz = /bits/ 64 <324000000>;
		opp-microvolt = <875000>;
	opp-528000000 {
		opp-hz = /bits/ 64 <528000000>;
&cpu0_opp_table {
	/delete-node/ opp-1992000000;
	opp-216000000 {
		opp-hz = /bits/ 64 <216000000>;
		opp-microvolt = <825000 825000 1150000>;
		clock-latency-ns = <40000>;
	opp-312000000 {
		opp-hz = /bits/ 64 <312000000>;
/delete-node/ &combphy0_us;
/delete-node/ &gmac0_clkin;
/delete-node/ &gmac0_xpcsclk;
/delete-node/ &gmac0;
/delete-node/ &gmac_uio0;
/delete-node/ &pcie30_phy_grf;
/delete-node/ &pcie30phy;
/delete-node/ &pcie3x1;
/delete-node/ &pcie3x2;
/delete-node/ &qos_pcie3x1;
/delete-node/ &qos_pcie3x2;
/delete-node/ &qos_sata0;
/delete-node/ &sata0;
@ Hqnicolas
The network card is still unable to receive data, and the reason is unclear. In the past, connecting the network port was a simple task, but now it seems very difficult😂
[   25.313329] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   25.318206] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [Generic PHY] (irq=POLL)
[   25.321898] dwmac4: Master AXI performs any burst length
[   25.324480] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   25.327033] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   25.329956] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   25.333601] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rmii link mode
how to use this dtb file?I only find a guide for amlogic, 1: burn the image to an SD card 2: modify /boot/extlinux/extlinux.conf to set dtb 3: copy the correct uboot for your box 4: enable multiboot on the box
I don't konw if this same to Rockchip CPU, for step1 I cannot find the image named "Linux 6.1.43 Rk35xx..." in the capture.
Then step 2, I see some modify in DTB, such as "Find the USB port list and change 1 port USB from OTG to HOST", but I open the .dtb file, it seems raw binary file, how can I read and save this file,some tools or rules?
And no idea for uboot and how to enable multiboot for this Tanix Tx66 TVbox.
Thank you so much for any clarification you can provide!
I will build one image to test, but still doubt with how to enable multiboot.
you don´t need to do nothing, it will boot from sd if all is right in sd.
Cannot work.
I use panther-x2 image and change /boot/armbianEnv.txt, "fdtfile=rockchip/rk3566-panther-x2.dtb" to "fdtfile=rockchip/rk3566-slzn.dtb".
also paste rk3566-slzn.dtb to dtb folder, but black screen when power on.
I try to build new image, but I cannot understand boot.cmd and boot.scr.
@lucksufe Are you using Armbian or ophub images?  If the later then you need to ask your build question in the ophub pages as they are an unrelated fork of Armbian.
Given what you have said above, you are following instructions for Amlogic TV boxes which have nothing to do with your rockchip based box.  Do not follow those instructions.
Why are you expecting the panther-x2 image to work on your box?  Each box is different and generally needs an image specific to that hardware.
If you are using an Armbian image, then @maka stated you should be able to write the image to an SD card, put that card into a linux machine, edit the files you are talking about and then move that SD card to your box and boot.
That means the box is trying to boot. I would try the h96 or jp rk3566 image ang the box-demo DTB file.
@SteeMan
I'm using ophub images, I thought both armbian images, I will try Armbian image.
panther-x2 is also RK3566, in my opinion same CPU share same image just different DTBs.
Thank you for giving me some initial understanding.
Edited by lucksufe
@ a wrong name
By the way. Is there any convenient way to modify file in SD card?
After I burn image to SD card, my computer(Windows 11) cannot recognize it, I use another armbian machine modify the SD card currently. Can I use my Windows computer modify the file? I searched in search engine not find useful infomation.
You can use any method that will recognize an ext4 linux file system.  Windows does not by default.  But if you installed WSL then I think you can, but I don't use windows.
@maka I just install wsl2 to compile image, I use ./compile.sh EXPERT="yes" find some rk3566 borad such as H96-tvbox-3566, the output image file is "Armbian-unofficial_24.8.0-trunk_H96-tvbox-3566_bookworm_current_6.6.44.img", seems kernel is 6.6.44. Anyway, I will try this image first.
Hi all, was able to run with https://github.com/bigtreetech/CB2/releases and access the network with USB-Ethernet adapter (RTL8153).
1. Download https://github.com/bigtreetech/CB2/releases/download/V1.0.5/CB2_Debian11_Klipper_kernel4.19_20240716.img.xz
2. Flash it to MicroSD with Raspberry Pi Imager.
3. Replace dtb/rockchips/rk3566-bigtreetech-pi2.dtb to rk3566-slzn.dtb from start-topic.
4. In boot/scripts/btt_init.sh add in end sting: sudo service KlipperScreen stop
5. Run it. Login credentials: biqu/biqu
I have installed XFCE  - HDMI & audio works!
But Wifi/bt (BCM4358) and native Ethernet not works.
I'd really appreciate some help with wifi/ethernet.
