Orange pi lite - HDMI output
maxic62
Hello guys,
I read a lot but did not find the answer
I'm trying to Turn ON / Turn OFF my Orange pi lite HDMI output like with my raspberry pi (with the help of /opt/vc/bin/tvservice -o ... etc)
But I'm not able to find a similar command to do it. I only found some tips to do it at start-up only
My goal is, after some times, turn OFF HDMI output (via python script) to force my monitor to switch into sleep mode.
Do you have any ideas ?
Thanks in advance ;)
Max
Link to post
Share on other sites
Hello Taurus,
thanks for the tip but this tool seems to patch script.bin. So a fix state.
We cannot do it dynamicaly
I want to be able to turn ON / OFF HMDI without rebooting the system
By the way, the tool return
This tool requires legacy kernel on H3 devices. Exiting
OS version I'm using on my Orange Pi Lite
root@orangepilite:/usr/local/bin# uname -a
Linux orangepilite 4.10.3-sun8i #6 SMP Sat Mar 25 02:54:20 CET 2017 armv7l armv7l armv7l GNU/Linux
regards
Link to post
Yes, all things should be supported by legacy, although switching hdmi on/off at runtime is a bit tricky. IIRC, "blank" sysfs property also doesn't work, but there are debugfs entries which enables to do that. I already described this method on this forum, although description was about switching modes, but turning off is also part of that. I will try to find it.
Link to post
Ok, I found what needs to be done. If you do:
sudo su
cd /sys/kernel/debug/dispdbg/
echo "blank" > command
echo "disp" > name
echo "0" > param
echo "1" > start
Then you will blank the screen. If you change 0 to 1, then you will "unblank" it.
Please note that I didn't test this on board, but it should work. Let me know if it works for you or not. Root access is unfortunately needed due to writing to debugfs.
Link to post
Thanks Jernej,
We approaching the solution may be
I switched to legacy 4.3.113 and tried your commands
Actually it works but only something like 2seconds.
Right after the
echo "1" > start
the screen goes blank, then blue but is turning ON right after that.
Link to post
That is unfortunate. The only other solution I know is this:
sudo su
echo "switch" > command
echo "disp" > name
echo "0 5" > param
echo "1" > start
Actually, second number for "param" could be anything. If you want to reenable, then you should write "4 5" to param, where 4 means HDMI output and 5 is wanted resolution, the same number as it is used in script.bin and with h3disp utility (most commonly 10 for 1080p60 and 5 for 720p60) .
Link to post
