maxic62 Posted April 2, 2017 Share Posted April 2, 2017 Hello guys, I read a lot but did not find the answer I'm trying to Turn ON / Turn OFF my Orange pi lite HDMI output like with my raspberry pi (with the help of /opt/vc/bin/tvservice -o ... etc) But I'm not able to find a similar command to do it. I only found some tips to do it at start-up only My goal is, after some times, turn OFF HDMI output (via python script) to force my monitor to switch into sleep mode. Do you have any ideas ? Thanks in advance Max Link to comment Share on other sites More sharing options...
arox Posted April 3, 2017 Share Posted April 3, 2017 I have the same question (I use 2 computers on the same screen with multiple inputs). Link to comment Share on other sites More sharing options...
Taurus Posted April 3, 2017 Share Posted April 3, 2017 Try using h3consumption -g on|off option (disabling GPU/HDMI). More info can be found here. Link to comment Share on other sites More sharing options...
maxic62 Posted April 4, 2017 Author Share Posted April 4, 2017 Hello Taurus, thanks for the tip but this tool seems to patch script.bin. So a fix state. We cannot do it dynamicaly I want to be able to turn ON / OFF HMDI without rebooting the system By the way, the tool return This tool requires legacy kernel on H3 devices. Exiting OS version I'm using on my Orange Pi Lite root@orangepilite:/usr/local/bin# uname -a Linux orangepilite 4.10.3-sun8i #6 SMP Sat Mar 25 02:54:20 CET 2017 armv7l armv7l armv7l GNU/Linux regards Link to comment Share on other sites More sharing options...
maxic62 Posted April 4, 2017 Author Share Posted April 4, 2017 I tried usual command in Linux but without success echo 1 > /sys/class/graphics/fb0/blank -bash: echo: write error: Invalid argument Link to comment Share on other sites More sharing options...
jernej Posted April 4, 2017 Share Posted April 4, 2017 Which kernel do you have? If it is not legacy 3.4.113, then you are out of luck, because on mainline kernel video output support is in early state and it is not possible to change any setting in runtime. Link to comment Share on other sites More sharing options...
maxic62 Posted April 4, 2017 Author Share Posted April 4, 2017 Yes I'm using mainline : Nightly 4.10.1 Ubuntu Xenial So I have to use the Legacy and I will be able to HDMI ON/OFF in runtime and all other stuff like Wifi / Microphone will work correctly ? Thanks for this information Jernej ! Link to comment Share on other sites More sharing options...
jernej Posted April 4, 2017 Share Posted April 4, 2017 Yes, all things should be supported by legacy, although switching hdmi on/off at runtime is a bit tricky. IIRC, "blank" sysfs property also doesn't work, but there are debugfs entries which enables to do that. I already described this method on this forum, although description was about switching modes, but turning off is also part of that. I will try to find it. Link to comment Share on other sites More sharing options...
jernej Posted April 5, 2017 Share Posted April 5, 2017 Ok, I found what needs to be done. If you do: sudo su cd /sys/kernel/debug/dispdbg/ echo "blank" > command echo "disp" > name echo "0" > param echo "1" > start Then you will blank the screen. If you change 0 to 1, then you will "unblank" it. Please note that I didn't test this on board, but it should work. Let me know if it works for you or not. Root access is unfortunately needed due to writing to debugfs. Link to comment Share on other sites More sharing options...
maxic62 Posted April 5, 2017 Author Share Posted April 5, 2017 Thanks Jernej, We approaching the solution may be I switched to legacy 4.3.113 and tried your commands Actually it works but only something like 2seconds. Right after the echo "1" > start the screen goes blank, then blue but is turning ON right after that. Link to comment Share on other sites More sharing options...
jernej Posted April 6, 2017 Share Posted April 6, 2017 That is unfortunate. The only other solution I know is this: sudo su cd /sys/kernel/debug/dispdbg/ echo "switch" > command echo "disp" > name echo "0 5" > param echo "1" > start Actually, second number for "param" could be anything. If you want to reenable, then you should write "4 5" to param, where 4 means HDMI output and 5 is wanted resolution, the same number as it is used in script.bin and with h3disp utility (most commonly 10 for 1080p60 and 5 for 720p60) . 1 Link to comment Share on other sites More sharing options...
maxic62 Posted April 10, 2017 Author Share Posted April 10, 2017 Thank you Jernej !!!!! It works very well ! But I'm curious, where did you find these informations ? Link to comment Share on other sites More sharing options...
jernej Posted April 11, 2017 Share Posted April 11, 2017 I'm glad that it works for you. I found them in kernel source code when I was working on OpenELEC fork and I needed to know as much as possible about display driver in order to optimize video rendering. Link to comment Share on other sites More sharing options...
