zador.blood.stained Posted April 2, 2017 Posted April 2, 2017 Symptoms: Board does not boot Armbian from inserted SD card, but may boot other distributions (based on old/legacy u-boot). Following or similar output can be grabbed from the serial console: U-Boot SPL 2017.01-armbian (Feb 02 2017 - 03:04:04) DRAM: 2048 MiB Trying to boot from MMC1MMC: no card present spl: mmc init failed with error: -123 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### The key message here is "MMC: no card present" Most likely cause: Malfunctioning microSD slot card detect switch. It can be verified either visually (with a magnifying glass) or electronically (with a multimeter) - at least in the slots used on Orange Pi boards and on Pine64 the pin near the switch should be shorted to the ground (i.e. SD slot casing) when card is inserted. Illustration (example) of a working switch: Verification (with a multimeter): Probe 1 - slot pin near the switch (may be different for different slot types, but at least true for Oranges and Pine64) Probe 2 - microSD slot casing or other parts connected to GND (not shown on the photo) No card - circuit is open Card inserted - circuit is shorted Photos - card is not inseted on the left and is fully inserted on the right: Orange Pi Pine64 (switch is more visible) Can it be fixed? Yes if the switch is not broken completely, by carefully adjusting (bending) the stationary contact (left on the pictures and photos, it usually is a part of the SD slot casing) i.e using a needle so it touches the moving contact (mostly hidden inside the slot on the photos) when card is inserted and not touching it when it is not inserted. 5 Quote
Slackstick Posted April 2, 2017 Posted April 2, 2017 Thanks for the information. My recently received WLAN router also does not detect its µSD card. Could this be a batch fault of the socket manufacturer? 0 Quote
zador.blood.stained Posted April 2, 2017 Author Posted April 2, 2017 Just now, Slackstick said: Could this be a batch fault of the socket manufacturer? It could be just that the parts of the switch bend too much when you either push too hard when inserting/removing cards or just leave the card constantly inside. But it also could be a batch fault or issues when grabbing/soldering the slot during board manufacturing. In either case this fault can be easily and reliably checked if there are any doubts (I still need to edit the explanation about the "pin near the switch") 0 Quote
StuxNet Posted June 28, 2017 Posted June 28, 2017 Important, small bit of info. Cheers for any frustration this might save others. "...at least in the slots used on Orange Pi board"... is an important detail too because I don't think this is necessarily the case with (at least) NanoPi NeoAir boards. I ordered a batch a while back and two had a faulty switch upon arrival. The fault prevented one SD card from fully engaging and prevented another from even ejecting. I absolutely didn't like the idea of potentially not being able to remove 32GB Micro SD cards (not to mention SD/NAND swapping was crucial to project) so I went ahead and removed the spring action arm, which in both cases were visibly defective and nand-sata-install still works like a charm. They just don't 'shoot' out like they used to 0 Quote
ozhvankov Posted November 11, 2017 Posted November 11, 2017 Hi! does anyone know how to disable a card detection switch check function in the u-boot My custom board based on (nano pi m1+) contains a 8-pin SD-card connector and does not have a PIN for card validation my sd-card connector is : thanx for any info's 0 Quote
zador.blood.stained Posted November 11, 2017 Author Posted November 11, 2017 3 minutes ago, ozhvankov said: how to disable a card detection switch check function in the u-boot By adding this to the u-boot defconfig for your device (or making a patch for an existing one that you use) CONFIG_MMC0_CD_PIN="" 0 Quote
ozhvankov Posted November 11, 2017 Posted November 11, 2017 30 minutes ago, zador.blood.stained said: By adding this to the u-boot defconfig for your device (or making a patch for an existing one that you use) CONFIG_MMC0_CD_PIN="" thanx 0 Quote
ozhvankov Posted November 12, 2017 Posted November 12, 2017 21 hours ago, zador.blood.stained said: By adding this to the u-boot defconfig for your device (or making a patch for an existing one that you use) CONFIG_MMC0_CD_PIN="" Hello again I tried to make changes in different ways 1) directly to the "cache" - it is unsuccessful, it is updated every time right on build process. 2) try to used ".gitignore" , unsuccessful . ".gitignore" updated every time right on build process too. 3) disconnected the Internet for a virtual machine so that it does not update the cache - as a result, the build process does not go well at all read several sections https://docs.armbian.com/Developer-Guide_Build-Process/ and thought that the best way would be to use -"userpatches/u-boot" put your u-boot patches here. maybe I'm wrong ... ok, but how to make it , there are I can to read about format armbian patch for special board ? I have experience in applying patches to the linux kernel But I do not know how the armbian build system works in detail. with respect to the u-boot of a specific board. My question is: How to make userpatches/u-boot for special board? There are I can to read about it or see example thanks 0 Quote
zador.blood.stained Posted November 12, 2017 Author Posted November 12, 2017 Assuming you are using NanoPi M1+ build target without changes you need to create a patch to nanopi_m1_plus_defconfig and put it to userpatches/u-boot/u-boot-sunxi You may need to adjust it if it conflicts with other build system patches that adjust default cpu or dram frequency 0 Quote
ozhvankov Posted November 19, 2017 Posted November 19, 2017 On 12.11.2017 at 6:55 PM, zador.blood.stained said: Assuming you are using NanoPi M1+ build target without changes you need to create a patch to nanopi_m1_plus_defconfig and put it to userpatches/u-boot/u-boot-sunxi You may need to adjust it if it conflicts with other build system patches that adjust default cpu or dram frequency good afternoon again and so I did everything as recommended several times (more than 10 attempts) step by step cp cache/sources/u-boot/v2017.09/.config userpatches/u-boot/u-boot-sunxi/.config cp cache/sources/u-boot/v2017.09/u-boot.cfg userpatches/u-boot/u-boot-sunxi/u-boot.cfg copy to different places too nano (vi) userpatches/u-boot/u-boot-sunxi/.config and remove PF6 from next string nano (vi) cache/sources/u-boot/v2017.09/u-boot.cfg and remove PF6 from next string CONFIG_MMC0_CD_PIN="PF6" > CONFIG_MMC0_CD_PIN="" then need to make patch (diff -u) actualy I'm used diff -Naur diff -Naur cache/sources/u-boot/v2017.09/.config userpatches/u-boot/u-boot-sunxi/.config > .config.patch diff -Naur cache/sources/u-boot/v2017.09/u-boot.cfg userpatches/u-boot/u-boot-sunxi/u-boot.cfg > u-boot-cfg.patch ok .config.patch and u-boot-cfg.patch --- cache/sources/u-boot/v2017.09/.config 2017-11-19 20:19:49.108251112 +0300 +++ userpatches/u-boot/u-boot-sunxi/.config 2017-11-19 20:29:33.164122999 +0300 @@ -184,7 +184,7 @@ # CONFIG_UART0_PORT_F is not set CONFIG_OLD_SUNXI_KERNEL_COMPAT=y CONFIG_MACPWR="" -CONFIG_MMC0_CD_PIN="PF6" +CONFIG_MMC0_CD_PIN="" CONFIG_MMC1_CD_PIN="" CONFIG_MMC2_CD_PIN="" CONFIG_MMC3_CD_PIN="" --- cache/sources/u-boot/v2017.09/u-boot.cfg 2017-11-19 20:19:50.268831070 +0300 +++ userpatches/u-boot/u-boot-sunxi/u-boot.cfg 2017-11-19 20:29:44.505791000 +0300 @@ -5,7 +5,7 @@ #define CONFIG_SYS_CLK_FREQ 1008000000 #define CONFIG_SUNXI_GEN_SUN6I 1 #define CONFIG_CMD_ITEST 1 -#define CONFIG_MMC0_CD_PIN "PF6" +#define CONFIG_MMC0_CD_PIN "" #define CONFIG_BOOTM_VXWORKS 1 #define CONFIG_MACH_SUN8I_H3 1 #define CONFIG_MMC_SUNXI_SLOT 0 and finaly ./compile.sh chose any board like nano pi ... banana pi ... but then start to compile logs [ o.k. ] Started patching process for [ u-boot sunxi-nanopim1-next ] [ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-sunxi ] [ warn ] * [c] .config.patch [ failed ] ... [ o.k. ] * [l][c] sun8i-set-machid.patch [ o.k. ] * [l][c] sunxi-boot-splash.patch [ warn ] * [c] u-boot-cfg.patch [ failed ] what am I doing wrong ??? thanx 0 Quote
zador.blood.stained Posted November 19, 2017 Author Posted November 19, 2017 7 minutes ago, ozhvankov said: what am I doing wrong ??? You need to patch the defconfig (nanopi_m1_plus_defconfig), not autogenerated config files 0 Quote
ozhvankov Posted November 19, 2017 Posted November 19, 2017 On 12.11.2017 at 6:55 PM, zador.blood.stained said: Assuming you are using NanoPi M1+ build target without changes you need to create a patch to nanopi_m1_plus_defconfig and put it to userpatches/u-boot/u-boot-sunxi You may need to adjust it if it conflicts with other build system patches that adjust default cpu or dram frequency thank U for correct but --- cache/sources/u-boot/v2017.09/configs/nanopi_m1_plus_defconfig 2017-11-19 21:37:45.569125867 +0300 +++ nanopi_m1_plus_defconfig 2017-11-19 22:04:59.961912277 +0300 @@ -4,7 +4,7 @@ CONFIG_DRAM_CLK=576 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y -CONFIG_MMC0_CD_PIN="PH13" +CONFIG_MMC0_CD_PIN="" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set [ o.k. ] Started patching process for [ u-boot sunxi-nanopim1plus-next ] [ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-sunxi ] [ warn ] * [c] nanopi_m1_plus_defconfig.orig.patch [ failed ] [ warn ] * [c] nanopi_m1_plus_defconfig.patch [ failed ] 0 Quote
zador.blood.stained Posted November 19, 2017 Author Posted November 19, 2017 3 minutes ago, ozhvankov said: --- cache/sources/u-boot/v2017.09/configs/nanopi_m1_plus_defconfig 2017-11-19 21:37:45.569125867 +0300 +++ nanopi_m1_plus_defconfig 2017-11-19 22:04:59.961912277 +0300 You have wrong file paths in this patch, it needs to be done relative to the u-boot repository root, so file paths should be "a/configs/nanopi_m1_plus_defconfig" and "b/configs/nanopi_m1_plus_defconfig" - check existing patches in the repository for examples: https://github.com/armbian/build/tree/master/patch/u-boot/u-boot-sunxi 0 Quote
ozhvankov Posted December 11, 2017 Posted December 11, 2017 thanx all good - right patch like this --- a/configs/nanopi_m1_plus_defconfig 2017-11-19 21:37:45.569125867 +0300 +++b/configs/nanopi_m1_plus_defconfig 2017-11-19 22:04:59.961912277 +0300 @@ -4,7 +4,7 @@ CONFIG_DRAM_CLK=576 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y -CONFIG_MMC0_CD_PIN="PH13" +CONFIG_MMC0_CD_PIN="" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set 0 Quote
Mario Ernesto Villarreal Posted December 12, 2017 Posted December 12, 2017 Mine has 470 ohms open and closed is short-circuit, but still has the same message. Do you think I need to patch uboot? 0 Quote
Bongho Lee Posted June 27, 2019 Posted June 27, 2019 On power plug on, there's no problem. But after boot up and reset, sometimes error occurred in some specific sd card. Boot error message is like this. U-Boot SPL 2018.11-armbian (Feb 08 2019 - 11:33:45 +0100) DRAM: 512 MiB Trying to boot from MMC1 spl: mmc init failed with error: -110 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### It looks like same problem as this. https://github.com/RobertCNelson/armv7-multiplatform/issues/25 How can I increase mmc power up time for sd card? My environment is kernel 4.19.38 on Orange Pi Zero. 0 Quote
spikerguy Posted June 21, 2020 Posted June 21, 2020 I have getting something similar ``` U-Boot SPL 2020.04-armbian (Jun 15 2020 - 04:07:06 +0200) DRAM: 1024 MiB Trying to boot from MMC1 MMC: no card present spl: mmc init failed with error: -123 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### ``` Now I cannot even boot into other os. Only the one on the emmc and I was just testing. Can anyone advice what is causing this ? I think it must be hardware issue. Thanks for the information above. Looks like my pin isn't working patching the uboot with the given config fixed the boot process but still it is not able to read the card further. ``` U-Boot 2020.04-2 (Jun 21 2020 - 22:22:21 +0000) Manjaro ARM CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO Plus2 DRAM: 1 GiB MMC: Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... Unable to use mmc 1:0... In: serial Out: serial Err: serial Net: phy interface7 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1d000: USB EHCI 1.00 Bus usb@1c1d400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1d000 for devices... 1 USB Device(s) found scanning bus usb@1c1d400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 MMC: no card present switch to partitions #0, OK mmc1(part 0) is current device ** No partition table - mmc 1 ** Device 0: unknown device ethernet@1c30000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-02-01-45-1c-d4-60 ethernet@1c30000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 ethernet@1c30000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 ethernet@1c30000 Waiting for PHY auto negotiation to complete....... ``` So mmc was not initiating Then I pressed the metal casing against the pin to make it touch the base pic and not the moving pin and now It can read the sd card fine. Hope this wont break again. This thread was so helpful without it user might have been thinking that is some hardware issue with the boards sd card slot. Thanks Again. 0 Quote
