technik007_cz Posted April 3, 2017 Posted April 3, 2017 Hi guys, do you have idea why boot stopped? Check log below please. It was build about 25minutes ago but about 1 week younger build was working. U-Boot SPL 2017.03-armbian (Apr 03 2017 - 19:48:42) DRAM: 256 MiB Trying to boot from MMC1 U-Boot 2017.03-armbian (Apr 03 2017 - 19:48:42 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment Setting up a 720x576i composite-pal console (overscan 32x20) Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga Net: phy interface0 eth0: ethernet@1c30000 Hit any key to stop autoboot: 0 ** File not found /boot/boot.bmp ** 38518 bytes read in 114 ms (329.1 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot.scr 1879 bytes read in 153 ms (11.7 KiB/s) ## Executing script at 43100000 ** File not found .next ** ** Unrecognized filesystem type ** 35384 bytes read in 453 ms (76.2 KiB/s) 4771976 bytes read in 824 ms (5.5 MiB/s) 3548294 bytes read in 658 ms (5.1 MiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3548230 Bytes = 3.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Ramdisk to 49bd2000, end 49f34446 ... OK Starting kernel ... [sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 256MB ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1 ion_reserve_select: ion chipid [0x2c00042! ion_reserve_common: ion reserve: [0x47e00000, 0x50000000]!
technik007_cz Posted April 4, 2017 Author Posted April 4, 2017 Another question which can help me to build working system. What should I change to build previous release of system? For example latest release is 5.27 and I want 5.26...
kinav Posted April 14, 2017 Posted April 14, 2017 I have the same problem :(. And can't find solution.
sle118 Posted April 28, 2017 Posted April 28, 2017 I have to report that I am getting the same after doing apt-get upgrade The SD card was reused from a OpiPC that got fried by 12V supply. It was working good until I did the update.
technik007_cz Posted April 29, 2017 Author Posted April 29, 2017 I have sorted out nfs booting problem differently using older image couple of weeks ago. But I had same screen on my Orange Pi 2 mini when I watched booting on serial console. I changed settings in /boot/boot.cmd to "console=ttyS0,115200" (without quotes) from "console=tty1" and it solved problem when booting stopped on "ion_reserve_common ... Probably booting did not stopped like I thought. Probably just only output of serial console was silent.
martinayotte Posted April 29, 2017 Posted April 29, 2017 Which version has that "console=tty1" ? I think it was always been "console=ttyS0,115200" ...
technik007_cz Posted April 30, 2017 Author Posted April 30, 2017 Version ? 5.27 build from sources on about 3rd of April.
martinayotte Posted April 30, 2017 Posted April 30, 2017 That is a bit strange since this line shows that it there since months : https://github.com/armbian/build/blob/master/scripts/nfs-boot.cmd.template#L14
zador.blood.stained Posted May 9, 2017 Posted May 9, 2017 U-boot update broke boot with the legacy kernel on Zero with 256MB: Should be fixed soon.
