RetroVice Posted April 13, 2017 Posted April 13, 2017 Hi, I'm a noob with this mini Pc's, but I think that I don't have doing anything wrong. My Orange Pi Zero no boot, no led power, only leds of ethernet, but the power leds (green and red) don't work, I tried with 2 microsd, and 2 systems too, but same problem, no reaction. Any solution please? Thanks.
Igor Posted April 13, 2017 Posted April 13, 2017 For proper debugging, you need to get a serial console. Most likely everything is fine. For a typical setup, just make sure you have a wired connection to your router when you power the board. Than check IP on the router and connect via SSH. The other way is serial console, since this board is headless by default. Well, the board also has some composite video out, but that's another story. I am not sure if it's enabled at this board.
tkaiser Posted April 13, 2017 Posted April 13, 2017 7 hours ago, RetroVice said: Any solution please? Simply follow the 'Getting started' guide exactly: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity If Ethernet led is on the board gets at least some power, if the other two leds remain off you failed burning the OS image to SD card or you suffer from insufficient powering.
RetroVice Posted April 15, 2017 Author Posted April 15, 2017 Thanks, I changed the SD card and now works good.
