I have Armbian_community_24.8.0-trunk.6_Orangepizero2w_bookworm_current_6.6.31_minimal on my Orange Pi Zero 2W. It has an expansion board but the ethernet port does not work on it.
ip a show eth0
>> Device "eth0" does not exist.
Only the Wi-Fi works.
https://paste.armbian.com/tuzocufiza
this line could be interesting but i dont know what does it mean exactly (or why is it happening):
dwmac-sun8i 5020000.ethernet eth0: stmmac_dvr_remove: removing driver
so I looked it up and found a similar problem where this question came up:
This didn't happen during a thunderstorm did it?
the first time the "extension board" was connected the other way around .. could this have caused a hardware problem? at startup, the LED of the ethernet port lights up for a moment, but then it doesn't light up even once. unfortunately, I don't have another device, so I can't find out if it's really a hardware error. I hope it's just some kind of bad system configuration
26 минут назад, krisz сказал:
[    2.136147] dwmac-sun8i 5020000.ethernet eth0: stmmac_dvr_remove: removing driver
[    2.152769] dwmac-sun8i: probe of 5020000.ethernet failed with error -110
I think this indicates a hardware error.
hi i was trying to use wakeonlan from my orange pi one armbian to wake my laptop thinkpad but theres an error and there is no eth0 found i need it to configure the network of armbian and able to send packets to my turn off laptop
thank you in advance help
below is my output from command "armbianmonitor -U"
myserver.txt
Edited by Arturojj
