krisz Posted May 29 Posted May 29 Hi, I have Armbian_community_24.8.0-trunk.6_Orangepizero2w_bookworm_current_6.6.31_minimal on my Orange Pi Zero 2W. It has an expansion board but the ethernet port does not work on it. ip a show eth0 >> Device "eth0" does not exist. Only the Wi-Fi works. 0 Quote
Werner Posted May 29 Posted May 29 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
krisz Posted May 29 Author Posted May 29 https://paste.armbian.com/tuzocufiza this line could be interesting but i dont know what does it mean exactly (or why is it happening): dwmac-sun8i 5020000.ethernet eth0: stmmac_dvr_remove: removing driver so I looked it up and found a similar problem where this question came up: Quote This didn't happen during a thunderstorm did it? the first time the "extension board" was connected the other way around .. could this have caused a hardware problem? at startup, the LED of the ethernet port lights up for a moment, but then it doesn't light up even once. unfortunately, I don't have another device, so I can't find out if it's really a hardware error. I hope it's just some kind of bad system configuration 0 Quote
going Posted May 29 Posted May 29 26 минут назад, krisz сказал: I don't have another device, so I can't find out if it's really a hardware error. [ 2.136147] dwmac-sun8i 5020000.ethernet eth0: stmmac_dvr_remove: removing driver [ 2.152769] dwmac-sun8i: probe of 5020000.ethernet failed with error -110 I think this indicates a hardware error. 0 Quote
