PHYO ZIN KHANT Posted May 31, 2024 Posted May 31, 2024 New Rock 5C work everything fine on Armbian 24 - bookworm stable release but only issue is that Wifi is not working on all stable release except Daily / Rolling releases. It seemed like something is misconfigure about wifi driver. You can see that I tested on both kernel 6.1.43 (stable) and latest edge and it's not working. But this daily release work like charm. 0 Quote
Redferne Posted July 18, 2024 Posted July 18, 2024 Hi, Same problem here. I tried all flavours, vendor, current & edge. No Wifi or BT. Manually installed aic8800-firmware_3.0+git20240327.3561b08f-2_all.deb and aic8800-usb-dkms_3.0+git20240327.3561b08f-2_all.deb from here: https://github.com/radxa-pkg/aic8800/releases Got Wifi and BT working, but it is far from stable. BT works a few minutes and then craps out. Did not test Wifi since I have no use for it. Spoiler [Thu Jul 18 23:18:11 2024] usb 8-1.3: new high-speed USB device number 9 using ehci-platform [Thu Jul 18 23:18:11 2024] usb 8-1.3: New USB device found, idVendor=a69c, idProduct=8d80, bcdDevice= 1.00 [Thu Jul 18 23:18:11 2024] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [Thu Jul 18 23:18:11 2024] usb 8-1.3: Product: AIC Wlan [Thu Jul 18 23:18:11 2024] usb 8-1.3: Manufacturer: aicsemi [Thu Jul 18 23:18:11 2024] usb 8-1.3: SerialNumber: 20220103 [Thu Jul 18 23:18:11 2024] AICWFDBG(LOGINFO) aicwf_usb_probe vid:0xA69C pid:0x8D80 icl:0x0 isc:0x0 ipr:0x0 [Thu Jul 18 23:18:11 2024] AICWFDBG(LOGINFO) aicloadfw_chipmatch USE AIC8800D80 [Thu Jul 18 23:18:11 2024] Aic high speed USB device detected [Thu Jul 18 23:18:11 2024] chip_id=fb07, chip_mcu_id = 0 [Thu Jul 18 23:18:11 2024] aic_load_firmware :firmware path = /lib/firmware/aic8800_fw/USB/aic8800D80/fw_patch_table_8800d80_u02.bin [Thu Jul 18 23:18:11 2024] file md5:0c9bf9c9c10f7a90a22a4c35fa58c967 [Thu Jul 18 23:18:11 2024] ### Upload fw_patch_table_8800d80_u02.bin fw_patch_table, size=1048 [Thu Jul 18 23:18:11 2024] ------------[ cut here ]------------ [Thu Jul 18 23:18:11 2024] memcpy: detected field-spanning write (size 32) of single field "&patch_info->adid_addrinf" at /var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/build/USB/driver_fw/drivers/aic8800/aic_load_fw/aicbluetooth.c:1230 (size 4) [Thu Jul 18 23:18:11 2024] WARNING: CPU: 7 PID: 101114 at /var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/build/USB/driver_fw/drivers/aic8800/aic_load_fw/aicbluetooth.c:1230 aicbt_patch_info_unpack+0x8c/0x94 [aic_load_fw] [Thu Jul 18 23:18:11 2024] Modules linked in: aic_load_fw(O) nls_utf8 nls_cp936 tls rfcomm xt_nat xt_tcpudp veth xt_conntrack nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack_netlink nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xfrm_user xfrm_algo xt_addrtype nft_compat nf_tables nfnetlink br_netfilter bridge algif_hash algif_skcipher af_alg bnep sunrpc btusb btrtl btintel btbcm btmtk bluetooth ecdh_generic rfkill ecc lz4hc lz4 zram binfmt_misc crct10dif_ce pwm_fan snd_soc_es8316 rk805_pwrkey snd_soc_audio_graph_card at24 snd_soc_rockchip_i2s_tdm snd_soc_simple_card_utils nvmem_rockchip_otp hantro_vpu rockchip_vdec2(C) v4l2_vp9 rockchip_rga v4l2_h264 rk_crypto2 snd_soc_core v4l2_mem2mem sm3_generic videobuf2_dma_sg videobuf2_dma_contig snd_compress videobuf2_memops rockchip_rng crypto_engine ac97_bus sm3 videobuf2_v4l2 snd_pcm_dmaengine snd_pcm videodev videobuf2_common mc snd_timer snd soundcore panthor drm_gpuvm gpu_sched drm_shmem_helper drm_exec dm_mod ip_tables x_tables autofs4 rk808_regulator phy_rockchip_samsung_hdptx rk8xx_spi [Thu Jul 18 23:18:11 2024] rk8xx_core uas rockchipdrm drm_dma_helper dw_hdmi cec dw_hdmi_qp dw_mipi_dsi analogix_dp drm_display_helper drm_kms_helper drm [last unloaded: cfg80211] [Thu Jul 18 23:18:11 2024] CPU: 7 PID: 101114 Comm: kworker/7:1 Tainted: G WC O 6.10.0-rc7-edge-rockchip-rk3588 #1 [Thu Jul 18 23:18:11 2024] Hardware name: Radxa ROCK 5 Model C (DT) [Thu Jul 18 23:18:11 2024] Workqueue: usb_hub_wq hub_event [Thu Jul 18 23:18:11 2024] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [Thu Jul 18 23:18:11 2024] pc : aicbt_patch_info_unpack+0x8c/0x94 [aic_load_fw] [Thu Jul 18 23:18:11 2024] lr : aicbt_patch_info_unpack+0x8c/0x94 [aic_load_fw] [Thu Jul 18 23:18:11 2024] sp : ffff800087e83480 [Thu Jul 18 23:18:11 2024] x29: ffff800087e83480 x28: ffff000003c66000 x27: ffff000003c677d8 [Thu Jul 18 23:18:11 2024] x26: ffff00003ad12c50 x25: ffff80007a25cb00 x24: ffff0000779178a8 [Thu Jul 18 23:18:11 2024] x23: ffff000077917800 x22: ffff00001adbc600 x21: 0000000000000020 [Thu Jul 18 23:18:11 2024] x20: ffff800087e834f8 x19: ffff800082231000 x18: ffffffffffffffff [Thu Jul 18 23:18:11 2024] x17: 0000000000201fdc x16: 0000000000201fe4 x15: 2f73726576697264 [Thu Jul 18 23:18:11 2024] x14: 2f77665f72657669 x13: 00000000000008de x12: 00000000ffffffea [Thu Jul 18 23:18:11 2024] x11: 0000000000000001 x10: 0000000000000001 x9 : ffff800081d5e5d8 [Thu Jul 18 23:18:11 2024] x8 : 000000000002ffe8 x7 : c0000000ffffdfff x6 : 00000000000affa8 [Thu Jul 18 23:18:11 2024] x5 : ffff0000ef783f88 x4 : 0000000000000000 x3 : ffff80006dea1000 [Thu Jul 18 23:18:11 2024] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff000020f0b480 [Thu Jul 18 23:18:11 2024] Call trace: [Thu Jul 18 23:18:11 2024] aicbt_patch_info_unpack+0x8c/0x94 [aic_load_fw] [Thu Jul 18 23:18:11 2024] aicfw_download_fw_8800d80+0x7c/0x4e8 [aic_load_fw] [Thu Jul 18 23:18:11 2024] aicwf_usb_probe+0x72c/0xb60 [aic_load_fw] [Thu Jul 18 23:18:11 2024] usb_probe_interface+0xdc/0x31c [Thu Jul 18 23:18:11 2024] really_probe+0xc0/0x38c [Thu Jul 18 23:18:11 2024] __driver_probe_device+0x7c/0x15c [Thu Jul 18 23:18:11 2024] driver_probe_device+0x3c/0x110 [Thu Jul 18 23:18:11 2024] __device_attach_driver+0xbc/0x158 [Thu Jul 18 23:18:11 2024] bus_for_each_drv+0x80/0xdc [Thu Jul 18 23:18:11 2024] __device_attach+0xa8/0x1d4 [Thu Jul 18 23:18:11 2024] device_initial_probe+0x14/0x20 [Thu Jul 18 23:18:11 2024] bus_probe_device+0xac/0xb0 [Thu Jul 18 23:18:11 2024] device_add+0x5cc/0x7c8 [Thu Jul 18 23:18:11 2024] usb_set_configuration+0x4f4/0x940 [Thu Jul 18 23:18:11 2024] usb_generic_driver_probe+0x60/0x88 [Thu Jul 18 23:18:11 2024] usb_probe_device+0x44/0x14c [Thu Jul 18 23:18:11 2024] really_probe+0xc0/0x38c [Thu Jul 18 23:18:11 2024] __driver_probe_device+0x7c/0x15c [Thu Jul 18 23:18:11 2024] driver_probe_device+0x3c/0x110 [Thu Jul 18 23:18:11 2024] __device_attach_driver+0xbc/0x158 [Thu Jul 18 23:18:11 2024] bus_for_each_drv+0x80/0xdc [Thu Jul 18 23:18:11 2024] __device_attach+0xa8/0x1d4 [Thu Jul 18 23:18:11 2024] device_initial_probe+0x14/0x20 [Thu Jul 18 23:18:11 2024] bus_probe_device+0xac/0xb0 [Thu Jul 18 23:18:11 2024] device_add+0x5cc/0x7c8 [Thu Jul 18 23:18:11 2024] usb_new_device+0x274/0x684 [Thu Jul 18 23:18:11 2024] hub_event+0x10ac/0x18c4 [Thu Jul 18 23:18:11 2024] process_one_work+0x174/0x3f0 [Thu Jul 18 23:18:11 2024] worker_thread+0x2f0/0x3f8 [Thu Jul 18 23:18:11 2024] kthread+0x118/0x11c [Thu Jul 18 23:18:11 2024] ret_from_fork+0x10/0x20 [Thu Jul 18 23:18:11 2024] ---[ end trace 0000000000000000 ]--- [Thu Jul 18 23:18:11 2024] addr_adid 0x201940, addr_patch 0x1e0000 [Thu Jul 18 23:18:11 2024] aic_load_firmware :firmware path = /lib/firmware/aic8800_fw/USB/aic8800D80/fw_adid_8800d80_u02.bin [Thu Jul 18 23:18:11 2024] file md5:f546881a81b960d89a672578eb45a809 [Thu Jul 18 23:18:11 2024] ### Upload fw_adid_8800d80_u02.bin firmware, @ = 201940 size=1708 [Thu Jul 18 23:18:11 2024] fw download complete [Thu Jul 18 23:18:11 2024] aic_load_firmware :firmware path = /lib/firmware/aic8800_fw/USB/aic8800D80/fw_patch_8800d80_u02.bin [Thu Jul 18 23:18:11 2024] file md5:35d137b8a76daaeb4f5034df8e15bcde [Thu Jul 18 23:18:11 2024] ### Upload fw_patch_8800d80_u02.bin firmware, @ = 1e0000 size=30040 [Thu Jul 18 23:18:11 2024] fw download complete [Thu Jul 18 23:18:11 2024] aicbt_patch_table_load bt btmode[4]:5 [Thu Jul 18 23:18:11 2024] aicbt_patch_table_load bt uart_baud[4]:1500000 [Thu Jul 18 23:18:11 2024] aicbt_patch_table_load bt uart_flowctrl[4]:1 [Thu Jul 18 23:18:11 2024] aicbt_patch_table_load bt lpm_enable[4]:0 [Thu Jul 18 23:18:11 2024] aicbt_patch_table_load bt tx_pwr[4]:28463 [Thu Jul 18 23:18:11 2024] patch version - Mar 07 2024 14:29:05 - git f94a3e4 [Thu Jul 18 23:18:11 2024] aic_load_firmware :firmware path = /lib/firmware/aic8800_fw/USB/aic8800D80/fmacfw_8800d80_u02.bin [Thu Jul 18 23:18:11 2024] file md5:331d2692faa065f9ec1f80e06cdbfc06 [Thu Jul 18 23:18:11 2024] ### Upload fmacfw_8800d80_u02.bin firmware, @ = 120000 size=341456 [Thu Jul 18 23:18:11 2024] fw download complete [Thu Jul 18 23:18:11 2024] AICWFDBG(LOGERROR) Read FW mem: 00120198 [Thu Jul 18 23:18:11 2024] AICWFDBG(LOGERROR) 120198=173078 [Thu Jul 18 23:18:11 2024] AICWFDBG(LOGERROR) 1201a0=174000 [Thu Jul 18 23:18:11 2024] AICWFDBG(LOGINFO) rd_version_val=06090101 [Thu Jul 18 23:18:11 2024] AICWFDBG(LOGINFO) 1201a4=17cb7c [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:11 2024] app_cmp [Thu Jul 18 23:18:12 2024] usb 8-1.3: USB disconnect, device number 9 [Thu Jul 18 23:18:12 2024] aicwf_usb_disconnect enter [Thu Jul 18 23:18:12 2024] aicwf_bus_deinit [Thu Jul 18 23:18:12 2024] q_sz/max: 0 / 8 - next tkn: 483 [Thu Jul 18 23:18:12 2024] q_sz/max: 0 / 8 - next tkn: 483 [Thu Jul 18 23:18:12 2024] usb bustx thread will to stop [Thu Jul 18 23:18:12 2024] usb bustx thread stop [Thu Jul 18 23:18:12 2024] exit aicwf_bus_deinit [Thu Jul 18 23:18:12 2024] usb busrx thread will to stop [Thu Jul 18 23:18:12 2024] usb busrx thread stop [Thu Jul 18 23:18:12 2024] usb 8-1.3: new high-speed USB device number 10 using ehci-platform [Thu Jul 18 23:18:13 2024] usb 8-1.3: New USB device found, idVendor=a69c, idProduct=8d81, bcdDevice= 1.00 [Thu Jul 18 23:18:13 2024] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [Thu Jul 18 23:18:13 2024] usb 8-1.3: Product: AIC 8800D80 [Thu Jul 18 23:18:13 2024] usb 8-1.3: Manufacturer: AICSemi [Thu Jul 18 23:18:13 2024] usb 8-1.3: SerialNumber: 20220103 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_usb_probe vid:0xA69C pid:0x8D81 icl:0x0 isc:0x0 ipr:0x0 [Thu Jul 18 23:18:13 2024] aic_load_fw 8-1.3:1.2: probe with driver aic_load_fw failed with error -1 [Thu Jul 18 23:18:13 2024] aic_btusb: AICBT_RELEASE_NAME: 202012_ANDROID [Thu Jul 18 23:18:13 2024] aic_btusb: AicSemi Bluetooth USB driver module init, version 2.1.0 [Thu Jul 18 23:18:13 2024] aic_btusb: RELEASE DATE: 2023_1211_1958 [Thu Jul 18 23:18:13 2024] aic_btusb: Register usb char device interface for BT driver [Thu Jul 18 23:18:13 2024] usbcore: registered new interface driver aic_btusb [Thu Jul 18 23:18:13 2024] cfg80211: Loading compiled-in X.509 certificates for regulatory database [Thu Jul 18 23:18:13 2024] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [Thu Jul 18 23:18:13 2024] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [Thu Jul 18 23:18:13 2024] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [Thu Jul 18 23:18:13 2024] cfg80211: failed to load regulatory.db [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx v6.4.3.0 - 1a4b0054d2M (master) [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) RELEASE DATE:2024_0327_3561b08f [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_usb_chipmatch USE AIC8800D81 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_parse_usb endpoints = 4 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) Aic high speed USB device detected [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_usb_alloc_rx_urb AICWF_USB_RX_URBS:20 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_usb_alloc_tx_urb AICWF_USB_TX_URBS:200 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_usb_alloc_msg_rx_urb AICWF_USB_MSG_RX_URBS:100 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_busrx_thread the cpu is:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_busrx_thread set_cpu_ret is:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_bus_init waiting for rx/tx thread init finish [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_bustx_thread the cpu is:5 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_busrx_thread change cpu to:2 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_busrx_thread the policy of current thread is:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_busrx_thread the rt_priority of current thread is:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_busrx_thread the current pid is:102528 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_bustx_thread set_cpu_ret is:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_bustx_thread change cpu to:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_bustx_thread the policy of current thread is:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_bustx_thread the rt_priority of current thread is:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_bustx_thread the current pid is:102529 [Thu Jul 18 23:18:13 2024] Bluetooth: MGMT ver 1.22 [Thu Jul 18 23:18:13 2024] rk2-crypto fe370000.crypto: Fallback for ecb-aes-rk2 is ecb-aes-ce [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_msg_busrx_thread the policy of current thread is:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_msg_busrx_thread the rt_priority of current thread is:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) usb_msg_busrx_thread the current pid is:102530 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_platform_init rwnx_cfg80211_init enter [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_cfg80211_init sizeof(struct rwnx_hw):13928 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_prealloc_txq_alloc size is diff will to be kzalloc [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_prealloc_txq_alloc txq kzalloc successful [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) userconfig file path:aic_userconfig_8800d80.txt [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) ### Load file aic_userconfig_8800d80.txt [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/USB/aic8800D80/aic_userconfig_8800d80.txt [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) file md5:35c8e99f3edd34d2a39bc9920e1da494 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) ### Load file done: aic_userconfig_8800d80.txt, size=2683 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_userconfig_parsing: AIC USERCONFIG 2022/0803/1707 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_userconfig_parsing: txpwr_lvl [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=enable value=1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_1m_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_2m_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_5m5_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_11m_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_6m_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_9m_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_12m_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_18m_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_24m_2g4 value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_36m_2g4 value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_48m_2g4 value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11b_11ag_54m_2g4 value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs0_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs1_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs2_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs3_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs4_2g4 value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs5_2g4 value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs6_2g4 value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs7_2g4 value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs8_2g4 value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs9_2g4 value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs0_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs1_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs2_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs3_2g4 value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs4_2g4 value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs5_2g4 value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs6_2g4 value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs7_2g4 value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs8_2g4 value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs9_2g4 value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs10_2g4 value=13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs11_2g4 value=13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_6m_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_9m_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_12m_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_18m_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_24m_5g value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_36m_5g value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_48m_5g value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11a_54m_5g value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs0_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs1_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs2_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs3_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs4_5g value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs5_5g value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs6_5g value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs7_5g value=15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs8_5g value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11n_11ac_mcs9_5g value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs0_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs1_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs2_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs3_5g value=18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs4_5g value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs5_5g value=16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs6_5g value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs7_5g value=14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs8_5g value=13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs9_5g value=13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs10_5g value=12 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_11ax_mcs11_5g value=12 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_userconfig_parsing: txpwr_lvl_adj [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_enable value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_2g4_chan_1_4 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_2g4_chan_5_9 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_2g4_chan_10_13 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_5g_chan_42 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGERROR) invalid cmd: lvl_adj_5g_chan_42 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_5g_chan_58 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGERROR) invalid cmd: lvl_adj_5g_chan_58 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_5g_chan_106 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGERROR) invalid cmd: lvl_adj_5g_chan_106 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_5g_chan_122 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGERROR) invalid cmd: lvl_adj_5g_chan_122 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_5g_chan_138 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGERROR) invalid cmd: lvl_adj_5g_chan_138 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=lvl_adj_5g_chan_155 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGERROR) invalid cmd: lvl_adj_5g_chan_155 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_userconfig_parsing: txpwr_loss [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=loss_enable value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=loss_value value=2 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_userconfig_parsing: txpwr_ofst [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_enable value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_11b_chan_1_4 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_11b_chan_5_9 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_11b_chan_10_13 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_ofdm_highrate_chan_1_4 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_ofdm_highrate_chan_5_9 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_ofdm_highrate_chan_10_13 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_ofdm_lowrate_chan_1_4 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_ofdm_lowrate_chan_5_9 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_2g4_ofdm_lowrate_chan_10_13 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_lowrate_chan_42 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_lowrate_chan_58 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_lowrate_chan_106 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_lowrate_chan_122 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_lowrate_chan_138 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_lowrate_chan_155 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_highrate_chan_42 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_highrate_chan_58 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_highrate_chan_106 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_highrate_chan_122 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_highrate_chan_138 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_highrate_chan_155 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_midrate_chan_42 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_midrate_chan_58 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_midrate_chan_106 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_midrate_chan_122 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_midrate_chan_138 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=ofst_5g_ofdm_midrate_chan_155 value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_userconfig_parsing: xtal cap [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=xtal_enable value=0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=xtal_cap value=24 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_plat_nvram_set_value:command=xtal_cap_fine value=31 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) userconfig download complete [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) is 5g support = 1, vendor_info = 0x00 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) Firmware Version: li Jun 18 2024 12:31:29 - g792f243 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:enable:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_1m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_2m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_5m5_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_11m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_6m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_9m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_12m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_18m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_24m_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_36m_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_48m_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_54m_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs0_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs1_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs2_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs3_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs4_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs5_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs6_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs7_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs8_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs9_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs0_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs1_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs2_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs3_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs4_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs5_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs6_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs7_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs8_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs9_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs10_2g4:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs11_2g4:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_1m_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_2m_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_5m5_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_11m_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_6m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_9m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_12m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_18m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_24m_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_36m_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_48m_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_54m_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs0_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs1_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs2_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs3_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs4_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs5_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs6_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs7_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs8_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs9_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs0_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs1_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs2_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs3_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs4_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs5_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs6_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs7_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs8_5g:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs9_5g:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs10_5g:12 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs11_5g:12 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_loss:loss_enable:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_loss:loss_value:2 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:enable:1 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_1m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_2m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_5m5_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_11m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_6m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_9m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_12m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_18m_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_24m_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_36m_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_48m_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_54m_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs0_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs1_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs2_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs3_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs4_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs5_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs6_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs7_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs8_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs9_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs0_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs1_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs2_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs3_2g4:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs4_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs5_2g4:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs6_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs7_2g4:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs8_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs9_2g4:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs10_2g4:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs11_2g4:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_1m_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_2m_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_5m5_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_11m_5g:-128 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_6m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_9m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_12m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_18m_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_24m_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_36m_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_48m_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11a_54m_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs0_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs1_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs2_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs3_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs4_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs5_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs6_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs7_5g:15 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs8_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs9_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs0_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs1_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs2_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs3_5g:18 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs4_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs5_5g:16 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs6_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs7_5g:14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs8_5g:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs9_5g:13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs10_5g:12 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs11_5g:12 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:enable:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_1_4:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_5_9:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_10_13:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_42:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_58:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_106:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_122:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_138:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_155:0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_txpwr_ofst2x_in_fdrv:enable :0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) pwrofst2x 2.4g: [0]:11b, [1]:ofdm_highrate, [2]:ofdm_lowrate chan= 1-4 5-9 10-13 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) [0] = [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) [1] = [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) [2] = [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) pwrofst2x 5g: [0]:ofdm_lowrate, [1]:ofdm_highrate, [2]:ofdm_midrate chan= 36-50 51-64 98-114 115-130 131-146 147-166 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) [0] = [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) [1] = [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) [2] = [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) 0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_send_txpwr_ofst2x_req:Do not use txpwr_ofst2x [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_xtal_cap:enable :0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_xtal_cap:xtal_cap :24 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get_userconfig_xtal_cap:xtal_cap_fine:31 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGERROR) no mac address in efuse! [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) get macaddr:0,0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) HT supp 1, VHT supp 1, HE supp 1 [Thu Jul 18 23:18:13 2024] rwnx_reg_notifier Enter [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) getRegdomainFromRwnxDB set ccode:00 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_get_countrycode_channels support channel:1 2 3 4 5 6 7 8 9 10 11 12 13 14 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165 [Thu Jul 18 23:18:13 2024] ieee80211 phy0: ******************************************************* ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES ** ******************************************************* [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_interface_add: wlan%d, 2, 10 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) interface add:88 0 33 77 43 14 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) aicwf_set_wireless_ext Enter [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) New interface create wlan0 [Thu Jul 18 23:18:13 2024] AICWFDBG(LOGINFO) rwnx_platform_init rwnx_cfg80211_init exit [Thu Jul 18 23:18:13 2024] usbcore: registered new interface driver aic8800_fdrv 0 Quote
ajvuik Posted July 31, 2025 Posted July 31, 2025 I have the same problem. I just downloaded the latest IOT-Armbian. No Wifi and no BT. 0 Quote
