Hqnicolas Posted April 12 Author Posted April 12 (edited) On 4/11/2025 at 10:38 AM, Keko said: (ideally something around 10fps, for 1920x1080 frames) on the H96 max M9s. that's really a good performance, congratulations for comparison i do 3fps 320x240 on rk3566 Edited April 12 by Hqnicolas 0 Quote
cmuki Posted April 19 Posted April 19 Seems like I got some progress/regress with the board - I added some extra arguments in the armbianEnv.txt file - verbosity=7 and extraargs debug to try and see what the reason for the freeze might be and these three jobs were stuck, resulting in a kernel panic (end Kernel panic - not syncing: panic_On_set_idle_set) - systemd-udev-trigger.service/start, dev-ttyFIQ0.device/start and systemd-tmpfiles-setup-dev.service/start. Tried disabling the FIQ0 node in the dts (at least I think so), but the UART just stopped and it hanged again (the Armsom Sige 5 also has this in its dt). Managed to get a few times in initramfs, but it wans't helping me in the slightest. When adding init=/bin/bash, I could also avoid the hang, but it wasn't that productive. 0 Quote
cmuki Posted April 25 Posted April 25 Good news and bad news - I found the culprit for the kernel panic, but it's the GPU - once I blacklisted the panfrost module, it booted and completed the initial setup. The rknpu driver is v0.9.8, so it should be usable with the immich ML. Probably will try to investigate the GPU issue, but not anytime soon. 0 Quote
xiaobao80 Posted May 17 Posted May 17 GPU blacklisted the panfrost module Has it been resolved? Thank you 0 Quote
cmuki Posted Monday at 01:29 PM Posted Monday at 01:29 PM Hey, @xiaobao80! Sadly not - but on the upside I was able to build and use the latest kernel. Also want to update and say that I did manage to use the NPU and the VPU successfully with Immich AI facial recognition and Jellyfin transcoding respectively. 0 Quote
darcyg Posted Wednesday at 03:55 AM Posted Wednesday at 03:55 AM @xiaobao80, The official use is the closed source Mali library. Panfrost is an open-source GPU library. It should be that the Panfrost module does not yet support rk3576 1 Quote
darcyg Posted 22 hours ago Posted 22 hours ago hey, @cmuki! Using the dts from the rk3576-evb1-v10 / rk3576-armsom-sige5 / rk3576-rock-4d in the https://github.com/radxa/kernel/arch/arm64/boot/dts/rockchip/ directory After modification, they can all boot the Armbian version h96-m9s Note: The rk3576-linux.dtsi file forcibly specifies the UUID of the rootfs device partition, which may cause system boot failure. Adjustments might be needed. The basic modification method is simple: disable the PCIe and GMAC1 configurations, modify the reset_pin configuration of GMAC0 to gpio2 and PB3 to enter the system. I used rock-4d as the template for modification. Other modifications have not been thoroughly studied yet. 1 Quote
Hqnicolas Posted 15 hours ago Author Posted 15 hours ago 7 hours ago, darcyg said: I used rock-4d as the template for modification. thanks @darcyg if you can, share it with us 0 Quote
