Dan Popa Posted April 22, 2017 Posted April 22, 2017 Hi everybody! I'm new on Linux and I have a problem. I burned the Armbian OS on an SD card for a OrangePi PC and I created an User name [dp] and a Password. When I login, instead to see the Desktop image, Armbian seems to wait for a command or something. The OS displays the following text: dp@orangepipc: ~$_ What should I type now to see the Desktop? Anyone want to help me?
martinayotte Posted April 22, 2017 Posted April 22, 2017 ~$ is effectively a command prompt shel, where the ~ means home directory. For Desktop, did you use a Desktop image for your SDCard ? Because Server image are headless by default, no Desktop installed ...
Dan Popa Posted April 22, 2017 Author Posted April 22, 2017 For my SD card I used a Desktop image (Legacy 3.4.113 Ubuntu Xenial). Ubuntu Xenial
Igor Posted April 24, 2017 Posted April 24, 2017 Desktop should start automatically after you create an username - in first root login and if you used desktop image. In some cases it's possible that your monitor is not properly detected at first boot - when using some HDMI2VGA converters ... and one reboot is needed to get a picture on the screen. In case of some SD card detects or if you press "CTRL-C" to break user creation, desktop boot won't be enabled ...
Dan Popa Posted April 25, 2017 Author Posted April 25, 2017 Thanks for your answer, Igor. I changed the SD card and now it's working! But now I have another problem: how to install the driver for the WiFi connexion?
zador.blood.stained Posted April 25, 2017 Posted April 25, 2017 Please provide output of dpkg -l nodm
