Hi all
I hava an orange pi 5 plus with a 512GO NVME SSD. I have installed the latest version od Armbian to a SD card it work well,  but for speed reason i would like to install the OS to th SSD drive and boot from this device and no longer from the SD card. Is there a way to do this ? i mean from u-boot point of view?  i can keep a SD card inside it to store u boot but i would like to move usr var and such to SSD
Thanks in advance for your answers comment or ideas
W.
Check armbian-install. It will copy you SD to NVME and you're done.
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-sata-nvme-usb
  • Solution
Make sure to
- write SPI during the mentioned armbian-install process
- that /boot directory has been populated on the NVMe. If not mount and copy files from sd manually there.
Thank you all for your help
using armbian-install was the solution, i just add to adjust my partitioning it seems to work fine, the board id up and running now lets enjoy this new toy and the armbian running on top
cheers
W.
