Uart2 Banana PI M3
Go to solution Solved by going,
Hi
I'm trying to understand how to enable Uart 2 for serial communication with a mcu on the banana pi (trying to connect a board running klipper to it).
I connected the Uart of the board to CON1-P08 and CON1-P10 of the Banana PI M3 according to all i can find those pins are tx/rx for UART2.
So far i figured out that the UART should be one of the /dev/ttyS* ones if i'm not mistaken, I can see /dev/ttyS to /dev/ttyS7 but am missing the /dev/ttyS1
user@bananapim3:~$ ls /dev/tty*
/dev/tty    /dev/tty11  /dev/tty15  /dev/tty19  /dev/tty22  /dev/tty26  /dev/tty3   /dev/tty33  /dev/tty37  /dev/tty40  /dev/tty44  /dev/tty48  /dev/tty51  /dev/tty55  /dev/tty59  /dev/tty62  /dev/tty9     /dev/ttyS2  /dev/ttyS6
/dev/tty0   /dev/tty12  /dev/tty16  /dev/tty2   /dev/tty23  /dev/tty27  /dev/tty30  /dev/tty34  /dev/tty38  /dev/tty41  /dev/tty45  /dev/tty49  /dev/tty52  /dev/tty56  /dev/tty6   /dev/tty63  /dev/ttyACM0  /dev/ttyS3  /dev/ttyS7
/dev/tty1   /dev/tty13  /dev/tty17  /dev/tty20  /dev/tty24  /dev/tty28  /dev/tty31  /dev/tty35  /dev/tty39  /dev/tty42  /dev/tty46  /dev/tty5   /dev/tty53  /dev/tty57  /dev/tty60  /dev/tty7   /dev/ttyACM1  /dev/ttyS4  /dev/ttyUSB0
/dev/tty10  /dev/tty14  /dev/tty18  /dev/tty21  /dev/tty25  /dev/tty29  /dev/tty32  /dev/tty36  /dev/tty4   /dev/tty43  /dev/tty47  /dev/tty50  /dev/tty54  /dev/tty58  /dev/tty61  /dev/tty8   /dev/ttyS0    /dev/ttyS5
I'm glad for anyhelp and any idea
13.06.2024 в 23:13, O to the o сказал:
In this file for UART2:
allwinner/sun8i-a83t.dtsi
		/omit-if-no-ref/
			uart2_pb_pins: uart2-pb-pins {
				pins = "PB0", "PB1";
				function = "uart2";
	uart2: serial@1c28800 {
			compatible = "snps,dw-apb-uart";
			reg = <0x01c28800 0x400>;
			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
			clocks = <&ccu CLK_BUS_UART2>;
			resets = <&ccu RST_BUS_UART2>;
			status = "disabled";
By analogy with uart0 here:
dts/allwinner/sun8i-a83t-bananapi-m3.dts#L383
you can write an additional node:
&uart2 {
	pinctrl-names = "default";
	pinctrl-0 = <&uart2_pb_pins>;
	status = "okay";
But it will work if you build the DTB directly when compiling the kernel.
Because without adding this node, the contact description node for uart2 will be omitted.
That is, it is not in the standard DTB.
You can write an overlay in which you need to specify both nodes:
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun8i-a83t";
	fragment@0 {
		target-path = "/aliases";
		__overlay__ {
			serial2 = "/soc/serial@1c28800";
	fragment@1 {
		target = <&pio>;
		__overlay__ {
				function = "uart2";
	fragment@2 {
		target = <&uart2>;
		 __overlay__ {
			status = "okay";
Regards
  • Solution
28 минут назад, O to the o сказал:
can the overlay be added into a running kernal
Save the overlay file to sun8i-a83t-uart2.dts name.
Compile the overlay:
dtc -I dts -O dtb -o sun8i-a83t-uart2.dtbo sun8i-a83t-uart2.dts
copy sun8i-a83t-uart2.dtbo file to /boot/dtb-**-sunxi/overlay/
Add to /boot/armbianEnv.txt file line:
overlays=uart2
after the line overlay_prefix=sun8i-a83t
sudo nano /boot/armbianEnv.txt
Thanks
Did that and the dtc command shows UART2 being present in the devicetree, any idea how to identify it in all the /dev/tty* options ? New appeared
Also if i wanna use 1-wire do i also need to add an overlay ?
2 часа назад, O to the o сказал:
I think you need to try to do the overlay yourself.
Do it by analogy with this:
https://github.com/armbian/sunxi-DT-overlays/blob/master/sun8i-h3/sun8i-h3-w1-gpio.dts
https://github.com/armbian/sunxi-DT-overlays/blob/master/sun50i-h5/sun50i-h5-w1-gpio.dts
8 часов назад, going сказал:
fragment@0 {
		__overlay__ {
May be /dev/ttyS2
This can be described using aliases:
sun8i-a83t-bananapi-m3.dts#L54
