Swietowid Posted June 15, 2024 Posted June 15, 2024 Hello, The latest build Armbian_24.5.1_Bigtreetech-cb1_bookworm_current_6.6.31_minimal.img.xz does not seem to boot on BTT Pi v1.2 (blank screen, no signs of anything happening, no ethernet) I checked archival version Armbian_24.2.3_Bigtreetech-cb1_bookworm_legacy_6.1.79_minimal.img.xz and it works just fine. Any ideas? 0 Quote
Dais Posted June 17, 2024 Posted June 17, 2024 Same with Armbian_community_24.8.0-trunk.104_Orangepipc2_noble_current_6.6.31... minimal and Gnome desktop. Booting just stops at point when it finds tty0, I don't remember precise line. 0 Quote
Narwhal Posted June 28, 2024 Posted June 28, 2024 Hello, it does boot (for me), but Ethernet and HDMI are not working. I can access it via UART. 0 Quote
rpq399 Posted July 6, 2024 Posted July 6, 2024 The July 3, 2024 Trixie minimal does not boot, or at least the Ethernet connection does not work. 0 Quote
Igor Posted July 6, 2024 Posted July 6, 2024 16 minutes ago, rpq399 said: The July 3, 2024 Trixie minimal does not boot, or at least the Ethernet connection does not work. Fixing is WIP https://github.com/armbian/build/pull/6656 https://armbian.atlassian.net/browse/AR-2312 0 Quote
t-bob Posted July 9, 2024 Posted July 9, 2024 I just built a Trixie 6.6.36 for an OPi Zero 2W and that now boots (the 6.6.3x seem to be suspect) so I suspect the fix is in !!! If you can build your own and see 0 Quote
rpq399 Posted July 16, 2024 Posted July 16, 2024 Still no Ethernet with July 13, 3024 Trixie minimal. 0 Quote
rpq399 Posted July 21, 2024 Posted July 21, 2024 No boot, or no ethernet on the July 20,2024 Trixie build. 0 Quote
JohnTheCoolingFan Posted August 14, 2024 Posted August 14, 2024 Could you try the new images? They are built with new enhancements for BTT CB1, and I managed to boot with it. https://www.armbian.com/bigtreetech-cb1/ 0 Quote
Solution Swietowid Posted December 21, 2024 Author Solution Posted December 21, 2024 Works just fine with Armbian_24.11.1_Bigtreetech-cb1_bookworm_current_6.6.60_minimal 0 Quote
Ash Doi Posted December 28, 2024 Posted December 28, 2024 Orange pi one H3 also doesn't boot, can't find any recent bootable images older than 1 version ago. I tried to install minimal versions Armbian_community_25.2.0-trunk.86_Orangepipc_bookworm_current_6.6.62_minimal and also Armbian_24.8.1_Orangepione_bookworm_current_6.6.44_minimal.img and also other versions with kernel 6.6.62 and 6.6.44. 0 Quote
