bedna Posted June 16 Share Posted June 16 (edited) I ran an update on my orangpi PC2. Setting up armbian-zsh (24.5.1) ... cp: cannot create directory '/home/unifi/.oh-my-zsh': No such file or directory cp: cannot create regular file '/home/unifi/.zshrc': No such file or directory chown: cannot access '/home/unifi/.oh-my-zsh': No such file or directory chown: cannot access '/home/unifi/.zshrc': No such file or directory Witch is to be expected to fail, because that is a system user I accedentally gave an above 1000 UID Unifi is UID 1003, my regular user bedna (1000) is the owner of /home/bedna I don't mind, I don't use zsh anyway, but figured you would want to know about this. Edit I spoke to early, the update actually breaks the system. Seems to be network related because it gets stuck at that if I connect a display to the device. I have restored a backup and retried 2 times, same thing, so there is presumably something wrong on your side here. This is what the terminal gave during the update, and as you can see, it looks like it all goes smooth, something in the firmware or kernel? Spoiler Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages have been kept back: armbian-bsp-cli-orangepipc2 The following packages will be upgraded: armbian-config armbian-firmware armbian-plymouth-theme armbian-zsh containerd.io docker-ce docker-ce-cli docker-ce-rootless-extras docker-compose-plugin linux-dtb-current-sunxi64 linux-image-current-sunxi64 linux-u-boot-orangepipc2-current 12 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. Need to get 204 MB of archives. After this operation, 54.3 MB of additional disk space will be used. Do you want to continue? [Y/n] y Get:2 https://download.docker.com/linux/debian bullseye/stable arm64 containerd.io arm64 1.6.33-1 [21.6 MB] Get:1 http://fi.mirror.armbian.de/apt bullseye/main arm64 armbian-config all 24.5.1 [136 kB] Get:5 http://fi.mirror.armbian.de/apt bullseye/main arm64 armbian-zsh all 24.5.1 [11.8 MB] Get:3 http://armbian.hosthatch.com/apt bullseye/main arm64 armbian-firmware all 24.5.1 [90.4 MB] Get:9 https://download.docker.com/linux/debian bullseye/stable arm64 docker-ce-cli arm64 5:26.1.4-1~debian.11~bullseye [13.2 MB] Get:10 https://download.docker.com/linux/debian bullseye/stable arm64 docker-ce arm64 5:26.1.4-1~debian.11~bullseye [15.4 MB] Get:11 https://download.docker.com/linux/debian bullseye/stable arm64 docker-ce-rootless-extras arm64 5:26.1.4-1~debian.11~bullseye [8390 kB] Get:12 https://download.docker.com/linux/debian bullseye/stable arm64 docker-compose-plugin arm64 2.27.1-1~debian.11~bullseye [10.8 MB] Get:4 http://armbian.hosthatch.com/apt bullseye/main arm64 armbian-plymouth-theme all 24.5.1 [108 kB] Get:6 http://fi.mirror.armbian.de/apt bullseye/main arm64 linux-dtb-current-sunxi64 arm64 24.5.1 [113 kB] Get:7 http://fi.mirror.armbian.de/apt bullseye/main arm64 linux-image-current-sunxi64 arm64 24.5.1 [31.3 MB] Get:8 http://fi.mirror.armbian.de/apt bullseye/main arm64 linux-u-boot-orangepipc2-current arm64 24.5.1 [336 kB] Fetched 204 MB in 23s (8926 kB/s) (Reading database ... 49264 files and directories currently installed.) Preparing to unpack .../00-armbian-config_24.5.1_all.deb ... Unpacking armbian-config (24.5.1) over (23.11.1) ... Preparing to unpack .../01-armbian-firmware_24.5.1_all.deb ... Unpacking armbian-firmware (24.5.1) over (23.11.1) ... Preparing to unpack .../02-armbian-plymouth-theme_24.5.1_all.deb ... Unpacking armbian-plymouth-theme (24.5.1) over (23.11.1) ... Preparing to unpack .../03-armbian-zsh_24.5.1_all.deb ... Unpacking armbian-zsh (24.5.1) over (23.11.1) ... Preparing to unpack .../04-containerd.io_1.6.33-1_arm64.deb ... Unpacking containerd.io (1.6.33-1) over (1.6.31-1) ... Preparing to unpack .../05-docker-ce-cli_5%3a26.1.4-1~debian.11~bullseye_arm64.deb ... Unpacking docker-ce-cli (5:26.1.4-1~debian.11~bullseye) over (5:26.1.3-1~debian.11~bullseye) ... Preparing to unpack .../06-docker-ce_5%3a26.1.4-1~debian.11~bullseye_arm64.deb ... Unpacking docker-ce (5:26.1.4-1~debian.11~bullseye) over (5:26.1.3-1~debian.11~bullseye) ... Preparing to unpack .../07-docker-ce-rootless-extras_5%3a26.1.4-1~debian.11~bullseye_arm64.deb ... Unpacking docker-ce-rootless-extras (5:26.1.4-1~debian.11~bullseye) over (5:26.1.3-1~debian.11~bullseye) ... Preparing to unpack .../08-docker-compose-plugin_2.27.1-1~debian.11~bullseye_arm64.deb ... Unpacking docker-compose-plugin (2.27.1-1~debian.11~bullseye) over (2.27.0-1~debian.11~bullseye) ... Preparing to unpack .../09-linux-dtb-current-sunxi64_24.5.1_arm64.deb ... Armbian 'linux-dtb-current-sunxi64' for '6.6.31-current-sunxi64': 'preinst' starting. Armbian 'linux-dtb-current-sunxi64' for '6.6.31-current-sunxi64': 'preinst' finishing. Unpacking linux-dtb-current-sunxi64 (24.5.1) over (23.11.1) ... Preparing to unpack .../10-linux-image-current-sunxi64_24.5.1_arm64.deb ... Armbian 'linux-image-current-sunxi64' for '6.1.63-current-sunxi64': 'prerm' starting. Armbian 'linux-image-current-sunxi64' for '6.1.63-current-sunxi64': 'prerm' finishing. Armbian 'linux-image-current-sunxi64' for '6.6.31-current-sunxi64': 'preinst' starting. Armbian 'linux-image-current-sunxi64' for '6.6.31-current-sunxi64': 'preinst' finishing. Unpacking linux-image-current-sunxi64 (24.5.1) over (23.11.1) ... Armbian 'linux-image-current-sunxi64' for '6.1.63-current-sunxi64': 'postrm' starting. Armbian 'linux-image-current-sunxi64' for '6.1.63-current-sunxi64': 'postrm' finishing. Preparing to unpack .../11-linux-u-boot-orangepipc2-current_24.5.1_arm64.deb ... Unpacking linux-u-boot-orangepipc2-current (24.5.1) over (23.11.1) ... Setting up linux-image-current-sunxi64 (24.5.1) ... Armbian 'linux-image-current-sunxi64' for '6.6.31-current-sunxi64': 'postinst' starting. dkms: running auto installation service for kernel 6.6.31-current-sunxi64:. update-initramfs: Generating /boot/initrd.img-6.6.31-current-sunxi64 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.31-current-sunxi64 Image Name: uInitrd Created: Sun Jun 16 06:56:09 2024 Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 17266336 Bytes = 16861.66 KiB = 16.47 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.31-current-sunxi64 to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.6.31-current-sunxi64' update-initramfs: Armbian: done. Remove unused generated file: /boot/initrd.img-6.1.63-current-sunxi64 Remove unused generated file: /boot/uInitrd-6.1.63-current-sunxi64 Armbian: update last-installed kernel symlink to 'Image'... '/boot/Image' -> 'vmlinuz-6.6.31-current-sunxi64' Armbian: Debian compat: linux-update-symlinks install 6.6.31-current-sunxi64 boot/vmlinuz-6.6.31-current-sunxi64 I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.6.31-current-sunxi64 I: /initrd.img.old is now a symlink to boot/initrd.img-6.6.31-current-sunxi64 I: /vmlinuz is now a symlink to boot/vmlinuz-6.6.31-current-sunxi64 I: /initrd.img is now a symlink to boot/initrd.img-6.6.31-current-sunxi64 Armbian 'linux-image-current-sunxi64' for '6.6.31-current-sunxi64': 'postinst' finishing. Setting up armbian-zsh (24.5.1) ... cp: cannot create directory '/home/unifi/.oh-my-zsh': No such file or directory cp: cannot create regular file '/home/unifi/.zshrc': No such file or directory chown: cannot access '/home/unifi/.oh-my-zsh': No such file or directory chown: cannot access '/home/unifi/.zshrc': No such file or directory Setting up linux-dtb-current-sunxi64 (24.5.1) ... Armbian 'linux-dtb-current-sunxi64' for '6.6.31-current-sunxi64': 'postinst' starting. Armbian: DTB: symlinking /boot/dtb to /boot/dtb-6.6.31-current-sunxi64... 'dtb' -> 'dtb-6.6.31-current-sunxi64' Armbian 'linux-dtb-current-sunxi64' for '6.6.31-current-sunxi64': 'postinst' finishing. Setting up armbian-config (24.5.1) ... Setting up linux-u-boot-orangepipc2-current (24.5.1) ... Armbian 'uboot-orangepipc2-current' for '2024.01-S866c-Pa03c-H2b63-V1521-B2e16-R448a': 'postinst' starting. Armbian 'uboot-orangepipc2-current' for '2024.01-S866c-Pa03c-H2b63-V1521-B2e16-R448a': 'postinst' finishing. Setting up containerd.io (1.6.33-1) ... Setting up docker-compose-plugin (2.27.1-1~debian.11~bullseye) ... Setting up armbian-firmware (24.5.1) ... Setting up docker-ce-cli (5:26.1.4-1~debian.11~bullseye) ... Setting up docker-ce-rootless-extras (5:26.1.4-1~debian.11~bullseye) ... Setting up armbian-plymouth-theme (24.5.1) ... update-initramfs: deferring update (trigger activated) Setting up docker-ce (5:26.1.4-1~debian.11~bullseye) ... docker.service is a disabled or a static unit not running, not starting it. docker.socket is a disabled or a static unit not running, not starting it. Processing triggers for man-db (2.9.4-2) ... Processing triggers for initramfs-tools (0.140) ... update-initramfs: Generating /boot/initrd.img-6.6.31-current-sunxi64 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.31-current-sunxi64 Image Name: uInitrd Created: Sun Jun 16 06:56:57 2024 Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 17265738 Bytes = 16861.07 KiB = 16.47 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.31-current-sunxi64 to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.6.31-current-sunxi64' update-initramfs: Armbian: done. Edited June 16 by bedna 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 17 Share Posted June 17 On 6/16/2024 at 7:04 AM, bedna said: I have restored a backup and retried 2 times, same thing, so there is presumably something wrong on your side here. Hmm, can you give us a bit more information on how to reproduce this? If I start with a clean image, which you have used? Bullseye is not well maintained by upstream, so we don't provide images anymore. Its suggested to use Bookworm from some time. Edit: https://github.com/armbian/build/blob/main/lib/functions/compilation/packages/armbian-zsh-deb.sh#L40-L54 Looks like this doesn't work well in your case. Needs some adjustments, ideas are welcome. 0 Quote Link to comment Share on other sites More sharing options...
going Posted June 17 Share Posted June 17 16.06.2024 в 08:04, bedna сказал: cp: cannot create directory '/home/unifi/.oh-my-zsh': No such file or directory 16.06.2024 в 08:04, bedna сказал: Unifi is UID 1003, my regular user bedna (1000) is the owner of /home/bedna Do I understand correctly? Are you logged in as a "benda" user? There is another user "unifi" in your OS, but he does not have a home directory? Or does the directory exist but the user "1003" has write rights? Who has "sudo" rights? UID 1003 or 1000? 0 Quote Link to comment Share on other sites More sharing options...
going Posted June 17 Share Posted June 17 3 часа назад, Igor сказал: Edit: https://github.com/armbian/build/blob/main/lib/functions/compilation/packages/armbian-zsh-deb.sh#L40-L54 Looks like this doesn't work well in your case. Needs some adjustments, ideas are welcome. Before these actions, it is necessary to verify users with UID >= 1000. And in the loop for the found users, first check the existence of the home directory and if it exists, then do these actions (cp, chown). 0 Quote Link to comment Share on other sites More sharing options...
