jata Posted Thursday at 10:11 PM Share Posted Thursday at 10:11 PM Hello all, I had diet-pi on my rock64 for the last few years but recently decided to install armbian debian community maintained firmware. Everything is working fine but I seem to get a new core fw on an almost daily basis (armbian-bsp-cli-rock64-current) and the board needs to be rebooted each time. An I using the wrong repo or is this normal? Should i consider running stock debian instead of armbian? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted Friday at 12:35 AM Share Posted Friday at 12:35 AM By default the community builds point to the 'beta' channel, otherwise known as 'nightly' or rolling releases, which have updates constantly. If you want something more stable, use armbian-config to switch to the stable channel, and then you should only get updates quarterly. 0 Quote Link to comment Share on other sites More sharing options...
jata Posted Friday at 05:53 AM Author Share Posted Friday at 05:53 AM Thanks you for this info. I had a feeling this was the case. I didn't have armbian-config installed and it installs a load of packages but went ahead anyway. Switched to stable channel so thanks again. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted Friday at 07:18 AM Share Posted Friday at 07:18 AM 1 hour ago, jata said: and it installs a load of packages but went ahead anyway. We are aware of that and we are working on a new armbian-config, but we are low on human capacity and it goes painfully slow. https://github.com/armbian/configng 1 hour ago, jata said: Switched to stable channel so thanks again. The only change is here, apt -> beta, beta -> apt: cat /etc/apt/sources.list.d/armbian.list deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com jammy main jammy-utils jammy-desktop But you need to reinstall related armbian packages. Armbian-config does that for you ... 0 Quote Link to comment Share on other sites More sharing options...
