The lighttpd fails when installed on following two distros:
(1) Armbian_5.25_Orangepipc_Debian_jessie_default_3.4.113
(2) Armbian_5.25_Orangepipc_Ubuntu_xenial_default_3.4.113_desktop
How to solve this problem?
The code below gives the details.
Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
pi@orangepipc:~$ uname -a
Linux orangepipc 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l GNU/Linux
pi@orangepipc:~$ sudo apt-get update
pi@orangepipc:~$ sudo apt-get install lighttpd
pi@orangepipc:~$ sudo systemctl restart lighttpd
pi@orangepipc:~$ sudo systemctl status lighttpd -l
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/ lib / systemd / system / lighttpd.service; enabled)
Active: failed (Result: exit-code) since Mon 2017-05-01 15:42:43 CEST; 40s ago
Process: 917 ExecStart=/usr/sbin/lighttpd -D -f / etc / lighttpd / lighttpd.conf (code=exited, status=255)
Process: 909 ExecStartPre= / usr / sbin / lighttpd -t -f / etc / lighttpd / lighttpd.conf (code=exited, status=0 / SUCCESS)
Main PID: 917 (code=exited, status=255)
May 01 15:42:42 orangepipc lighttpd[909]: Syntax OK
May 01 15:42:43 orangepipc systemd[1]: Started Lighttpd Daemon.
May 01 15:42:43 orangepipc lighttpd[917]: 2017-05-01 15:42:43: (log.c.118) opening errorlog ' / var / log / lighttpd / error.log' failed: No such file or directory
May 01 15:42:43 orangepipc systemd[1]: lighttpd.service: main process exited, code=exited, status=255 / n / a
May 01 15:42:43 orangepipc systemd[1]: Unit lighttpd.service entered failed state.
pi@orangepipc:~$
Its a bug in ramlog ... which is fixed in dev version. Disable it and install again or move to nightly build and install again.
Wrote on mobile
Or disable ramlog and recreate logs manually and start web server again.
Wrote on mobile
Wrote on mobile
Thank you for prompt reply.
Wrote on mobile
This is a noob question, but I have to ask: How to disable ramlog? In which file & folder the logs/ramlog is located?
