Install Armbian without destroying 3rd partition
Go to solution Solved by Igor,
Hello everybody.
I own a Orange Pi 5 Plus with Debian and 3 partitions: boot, root and storage (fat, ext4, ext4). Now I want to try Armbian but I don't want to overwrite the storage partition, so I shoudn't use dd to write the .img file.
Ant tip to solve this situation?
Thanks.
  • Solution
If you have downloaded "Debian" from Orangepi site, you are already using Armbian. Only some slightly changed old version and without Armbian & community support. To try Armbian, you burn SD card and boot from it. No need to install it anywhere yet. To install it, just run armbian-install and select correct (root) partition. Since this is Linux and your are using 3rd party OS (and bootloader), backup of /storage is recommended before proceeding. Just to be on a safe side.
