It used to function fine, however after not using it for awhile it has quit working. It starts booting normally, then hangs with what's visible on the screen being a bunch of systemd messages, with the last being either something about system variables or mounting FUSE file filesystem, when it's the latter it's followed up with a kernel panic.  I've reflashed several times using both the server and desktop images freshly downloaded, no difference. The power supply I'm using worked before, as did the SD card. Unfortunately I have no way of showing you system logs or such for the time being. Any help would be appreciated.
  On 5/7/2017 at 11:37 PM, sbcidiot said:
as did the SD card.
Expand
Try different one and use mobile phone to make a picture of the screen. We might recognise the problem.
I screwed up another card, this time the green light does not come on. However, I can stick it in my computer and everything comes up. Is there a way to recover this drive (since I'm assuming u-boot or something of the sort is messed up) without starting all over?
