Helios64 "kernel headers for this kernel do not seem to be installed."
Go to solution Solved by ebin-dev,
I have a problem, when I enter "sudo apt install zfs-dkms" on my Helios64, I get this error message:
"Module build for kernel 6.6.36-current-rockchip64 was skipped because the
kernel headers for this kernel do not appear to be installed."
I also made sure to install the kernel header in armbian-config and also rebooted.
When I type "apt list --installed | grep linux-headers", I get this listing:
WARNING: apt does not have a stable CLI interface. Use it with caution in scripts.
linux-headers-current-rockchip64/bookworm,now 24.5.1 arm64 [installed]
omv7 itself is installed and running.
The image "Armbian_24.5.3_Helios64_bookworm_current_6.6.36_minimal.img.xz" has been installed.
apt update and apt upgrade were run after installing the image
The plan is to get OMV7 running with zfs on my Helios64
I hope someone can help me with this
Regards
Saam27
You have the 24.5.1 version of kernel headers, but...
of the kernel.  Thus your headers and kernel don't match.
I doubt you will find a 6.6.36 version of the headers, so either down grade your kernel to the version that matches your headers, or use the Armbian build framework to build your own .deb files of both the kernel and headers together so you have a matching version.
Current kernel versions (linux, dtb, headers) for helios64 can be downloaded from beta.armbian.com. I am currently using 6.6.39 ...
Edited by ebin-dev
thanks for the suggestions!
I would upgrade my kernel to 6.6.39 and then install the kernel headers for 6.6.3.9 or downgrade my kernel.
I have now tried changing my kernel to "Linux 6.6.16-current-rockchip64" in armbian-config and then installing the headers.
Then I tried to install zfs-dmks, unfortunately with the same result
I probably need a different kernel than the one suggested in armbian-config
which variant would be better for my Helios64 or does it not matter?
I've never done anything like this before and I'm not that familiar with Linux to install an additional kernel or header afterwards.
Which commands do I need?
Regards
Saam27
  • Solution
To install the latest kernel 6.6.69 just load the three files (image, dtb, headers) into a single folder, and execute 'dpkg -i linux*' inside that folder and reboot.
Your instructions have solved my problem, thank you very much
Regards
