After orangepiplus upgraded the kernel, the native wifi interface card disappeared.
Go to solution Solved by Igor,
I checked the dts settings and it shows that wifi is implemented in mmc1.
mmc@1c10000 {
            reg = <0x1c10000 0x1000>;
            pinctrl-names = "default";
            pinctrl-0 = <0x17>;
            resets = <0x03 0x08>;
            reset-names = "ahb";
            interrupts = <0x00 0x3d 0x04>;
            status = "okay";
            #address-cells = <0x01>;
            #size-cells = <0x00>;
            compatible = "allwinner,sun7i-a20-mmc";
            clocks = <0x03 0x17 0x03 0x4a 0x03 0x4c 0x03 0x4b>;
            clock-names = "ahb\0mmc\0output\0sample";
            vmmc-supply = <0x15>;
            mmc-pwrseq = <0x18>;
            bus-width = <0x04>;
            non-removable;
            phandle = <0x56>;
            sdio_wifi@1 {
                reg = <0x01>;
                phandle = <0x57>;
Edited by Char11e
change cotent
Link to comment
Share on other sites
dmesg also shows that mmc1 has detected the sdio card.
pi@orangepipcplus:~$ dmesg | grep mmc
[    0.000000] Kernel command line: root=UUID=f9fc34f5-ca46-43b7-8daf-4f52710744dd rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=6f12a333-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=6f12a333-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory", will be passed to user space.
[    2.190752] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    2.215138] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    2.219150] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[    2.250971] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.254281] mmc0: new high speed SDHC card at address aaaa
[    2.255979] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[    2.262583]  mmcblk0: p1
[    2.279121]     ubootsource=mmc
[    2.339350] mmc2: new DDR MMC card at address 0001
[    2.341100] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[    2.344746]  mmcblk2: p1
[    2.346628] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB
[    2.350919] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB
[    3.048466] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    3.071233] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    3.108016] mmc1: new high speed SDIO card at address 0001
[    3.989616] EXT4-fs (mmcblk0p1): mounted filesystem f9fc34f5-ca46-43b7-8daf-4f52710744dd ro with writeback data mode. Quota mode: none.
[    7.657890] EXT4-fs (mmcblk0p1): re-mounted f9fc34f5-ca46-43b7-8daf-4f52710744dd r/w. Quota mode: none.
Link to comment
confirm the problem on Orange Pi Zero Plus ...
i think it's because of this line is missing in build config (see attachment)
i've solved the problem by choose another kernel (6.6.31) in armbian-config
Edited by Dmitriy Golovin
board name
Link to comment
