Igor Posted July 23, 2024 Posted July 23, 2024 We are thrilled to launch this initiative to recognize and reward the incredible contributors who help keep Armbian running smoothly. All existing and new contributors will be entering the pool to win modern powerful and sleek Intel powered workstation: 1 x Khadas Mind Premium + dock and 1 x Khadas Mind Standard + dock Review: https://www.servethehome.com/khadas-mind-is-a-different-mini-pc-our-review-intel-1360p/ About: Spoiler Exceptional Performance: Khadas Mind Mini Computer is powered by the Newest 13th Gen Intel Core i7-1360P 12-core CPU (Intel Iris Xe Graphics eligible, graphics max dynamic frequency 1.5GHz) with 4 performance cores and 8 efficiency cores 16 threads, max turbo frequency 5.0GHz,18MB cache, which makes it effortlessly handles resource-intensive tasks and multitasking. Whether business operations or creative design, this high-performance chip takes your efficiency to the next level. Effortless Expansion: Khadas mind desktop mini-computer has a built-in dual channel 32GB LPDDR5 5200MT/S RAM+1TB M.2 NVMe PCIe 4.0 2230 SSD, through the additional M.2 NVMe 2230 SSD slots cleverly hidden beneath the magnetic cover plate expandable up to 2TB. Built-in Standby Battery: If you need to change workstations, simply unplug and go, or if there is a sudden power cut, it automatically enters sleep mode so you never lose a day's work. On reconnection, Mind wakes up instantly, ensuring seamless continuity between different workspaces. Ultra Compact and Lightweight: Weights only 450g, and measuring 146x105x20 mm, just 1/4 the size of an A4 paper, it fits in your pocket and saves space on your desk. Highly Efficient Heat-Dissipation System:Mind boasts a custom-designed VC liquid cooling heatsink paired with pure copper fins and a magnetic levitation fan. With dual inlet and single outlet airflow design, Mind can well meet the office and other purposes in terms of heat dissipation, the temperature is within a reasonable range. Versatile and fast transfer interface: USB-C × 2, HDMI 2.0 (18Gpbs) × 1, USB-A 3.2 Gen2 (10Gpbs) × 2 . The HDMI interface supports 4K/60Hz display, the full-featured USB-C interfaces support both 8K/60Hz and 4K/240Hz display, and additional interfaces can be added via Mind Link. Besides, it also supports up to four 4K 60Hz displays on different monitors. More info: https://www.armbian.com/newsflash/armbian-khadas-are-rewarding-contributors/ How to nominate? Post into reply why you think certain forum member contributions stands out and should be added to the pool. 2 Quote
Igor Posted August 5, 2024 Author Posted August 5, 2024 [Task]: Verify all build commands and remove deprecated https://github.com/armbian/documentation/issues/467 0 Quote
Igor Posted October 3, 2024 Author Posted October 3, 2024 [Task:] Adding Armbian to Fastfetch https://armbian.atlassian.net/browse/AR-2336 [Task:] Adjust OpenHab official documentation https://armbian.atlassian.net/browse/AR-2387 [Task:] Create github action to refresh kernel config https://armbian.atlassian.net/browse/AR-1827 Any of those counts. Still two weeks to go. 0 Quote
