spottyrover Posted May 17, 2017 Posted May 17, 2017 I have a orange pi plus 2e The time was ok a few days ago but now it is off by - 12 hrs +53 minutes which is before gmt thanks for your help Dave Do I need to open a port in the router?
martinayotte Posted May 17, 2017 Posted May 17, 2017 Normally, there is a NTP service running on all Armbian. Check if it is running by doing "ps -ef | grep ntp", you should have something like : ntp 720 1 0 May04 ? 00:01:28 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:110 if not, try to run it manually to see if any errors ...
spottyrover Posted May 18, 2017 Author Posted May 18, 2017 Thanks for your help martinayotte It is running. The problem was I changed Routers and it blocked access. New router is now reconfigured. What a waste of 4 hours. LOL Dave
Saad Abdul Majid Posted November 28, 2018 Posted November 28, 2018 I am running Armbian 5.59 on Orange Pi Zero. I am facing difficulty setting correct date and time. NTP service is running. What do I do?
Technicavolous Posted December 4, 2018 Posted December 4, 2018 try armbian-config as root or sudo armbian-config and set the time through the utility.
