이시형 Posted May 17, 2017 Posted May 17, 2017 The Problem is retry count exceeded... I don't know why is this happening to me. I search the older post the same problem, but i don't know what is the exactly problem. My board is CubieTruck3 A20 Board and i use SD Card.
Solution Igor Posted May 17, 2017 Solution Posted May 17, 2017 16 minutes ago, 이시형 said: My board is CubieTruck3 A20 Board and i use SD Card. Get another SD card - only boot loader is loaded in since it can't read from SD card it tries network boot ... 1
이시형 Posted May 17, 2017 Author Posted May 17, 2017 I'll try. thanks for the fast answer. I think i'll buy Samsung EVO MicroSDCard. Should i buy only 16GB? or can i use higher GB's SDcard? 64GB is MicroSDXC and 32GB is MicroSDHC and also same as 16GB is SDHC
Igor Posted May 17, 2017 Posted May 17, 2017 Just try to write it again (with Etcher as we recommend) and try some different SD card. I have many different brands around and all worked so far ... but some already died. Just get Samsung EVO16 or 32GB, they perform almost the same ... check this thread for details. 1
