peter12 Posted May 19, 2017 Posted May 19, 2017 Hi friends, I am trying to downclock my OPi Zero and set/disable unused cores 1,2,3, limit DRAM speed, limit max cpu core frequency, put voltage down. Is this possible on Opi Zero? I tried e.g. Quote echo 0 | sudo tee /sys/devices/system/cpu/cpu3/online > /dev/null but when I cat /sys/devices/system/cpu/cpu3/online is is always 1. Any idea please? Some advice how to do all of this is highly appreciated. I am trying to downclock Opi Zero to push produced heat down.
gnasch Posted May 20, 2017 Posted May 20, 2017 you might want to try h3consumption utility. best, gnasch
peter12 Posted May 20, 2017 Author Posted May 20, 2017 12 hours ago, gnasch said: you might want to try h3consumption utility. best, gnasch Thanks gnasch! But I read h3consumption works just with H3 boards only and Opi Zero is H2 board. Will it work with OpiZero in this case please?
