NixiElectra Posted August 8, 2024 Posted August 8, 2024 (edited) Hello, I've issue with nameserver. My router DHCP DNS server point to the Pi which has IP 10.6.6.3. But for unknown reason 1.0.0.1 keep added in the /etc/resolv.conf: # This is /run/systemd/resolve/resolv.conf managed by man:systemd-resolved(8). # Do not edit. # # This file might be symlinked as /etc/resolv.conf. If you're looking at # /etc/resolv.conf and seeing this text, you have followed the symlink. # # This is a dynamic resolv.conf file for connecting local clients directly to # all known uplink DNS servers. This file lists all configured search domains. # # Third party programs should typically not access this file directly, but only # through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a # different way, replace this symlink by a static file or a different symlink. # # See man:systemd-resolved.service(8) for details about the supported modes of # operation for /etc/resolv.conf. nameserver 1.0.0.1 nameserver 10.6.6.3 search . I've tried to manually edit and remove it from /etc/resolv.conf but it will come back. I'm using image from https://github.com/armbian/community/releases/download/24.8.0-trunk.495/Armbian_community_24.8.0-trunk.495_Orangepizero2w_bookworm_current_6.6.36_minimal.img.xz 10-dhcp-all-interfaces.yaml # Added by Armbian # # Reference: https://netplan.readthedocs.io/en/stable/netplan-yaml/ # # Let systemd-networkd manage all Ethernet devices on this system, but be configured by Netplan. network: version: 2 renderer: networkd ethernets: all-eth-interfaces: match: name: "e*" dhcp4: yes link-local: [ ipv4 ] Is there anything I'm missing? Edited August 8, 2024 by NixiElectra 0 Quote
Solution Werner Posted August 8, 2024 Solution Posted August 8, 2024 On 8/8/2024 at 11:07 AM, NixiElectra said: I've tried to manually edit and remove it from /etc/resolv.conf but it will come back. Expand On 8/8/2024 at 11:07 AM, NixiElectra said: # This is /run/systemd/resolve/resolv.conf managed by man:systemd-resolved(8). # Do not edit. Expand Think about it Reveal hidden contents You need to adjust systemd-resolved in order to have your changes persistent 0 Quote
NixiElectra Posted August 9, 2024 Author Posted August 9, 2024 On 8/8/2024 at 2:01 PM, Werner said: Think about it Reveal hidden contents You need to adjust systemd-resolved in order to have your changes persistent Expand I found out that there was a file that caused this /etc/systemd/resolved.conf.d/00-armbian-default-dns.conf. After removing that, the issue solved. Now only one nameserver exist in the resolv.conf. Cheers 1 Quote
