Jean-Francois Lessard Posted June 24 Author Posted June 24 That should make it. You can always try to see if it works and search online if not. 0 Quote
dale Posted August 29 Posted August 29 (edited) Quote sudo ./display -c [WARN] Display device directory missing at /sys/class/leds/display; attempting module load [INFO] Successfully loaded module: tm16xx [ERROR] Display device not present after modprobe Hi, @Jean-Francois Lessard I'm using a x98h box with self-built image. I have issue with the tm16xx kernel module using a patch https://github.com/paolosabatino/armbian-build/blob/main/patch/kernel/archive/rockchip64-6.16/general-driver-tm16xx-led-driver.patch The vfd controller is AIP1688 which is similar to fd628. Do you have any idea why it fails? Edited August 29 by dale 0 Quote
Jean-Francois Lessard Posted August 29 Author Posted August 29 Hi @dale What is your DTS node for your display? My first guess is that your DT node is not being picked up/inexistent since the module loads but the display device is not present. You can use dtc /proc/device-tree to see your loaded DT and find your display node, if any. Then, have you checked dmesg for any tm16xx kernel message? Then, you can ls /sys/class/leds to see if any device were created. The display-service/display-utils scripts expect /sys/class/leds/display. That should not be your issue here, but I'm not sure that aip1688 is the same as tm1628 variants. Googling aip1688 list it besides aip1618, so that would be the tm1618 variant. Whatsoever, I think you should have partial working display if using tm1628. To be 100% of which compatible string to use, we would need the aip1688 datasheet but I couldn't find it online. Good luck with your experimentation! Let me know how you results. 0 Quote
dale Posted August 30 Posted August 30 (edited) @Jean-Francois Lessard I'm sorry for the typo. Yes the controller is tm1628. ls /sys/class/leds --> shows empty. Dmesg doesn't show any message for tm16xx. I've attached the working overlay source for openvfd which I have the clock digits working at least with. (The full icons would be card, usb, Low wifi, hi wifi, apps and eth) openvfd_x98h.dts Edited August 30 by dale 0 Quote
Jean-Francois Lessard Posted August 30 Author Posted August 30 @dale you need a display overlay that is compatible with tm16xx. OpenVFD overlays are NOT supported. You can read README.md and dt-bindings documentation at https://github.com/jefflessard/tm16xx-display But note that there has been many changes recently to the code base since the driver is currently in review process to be upstreamed into mainline kernel (targeting v6.18). So double check which bindings version format has been integrated into Armbian rockchip64. The GitHub repo also contains a vfd-convert utility to automatically convert OpenVFD configuration files to expected tm16xx DTSO. But : 1. It requires OpenVFD conf file, not dtso. 2. You may need to go through file history to get the version matching of what has been integrated into Armbian rockchip64. 0 Quote
Jean-Francois Lessard Posted Tuesday at 01:02 AM Author Posted Tuesday at 01:02 AM To anyone interested, I am seeking help to test the latest tm16xx changes for the (hopefully) final upstreaming submittal. You will find in-tree patches here: https://github.com/torvalds/linux/compare/master...jefflessard:linux:tm16xx, just suffix with ".patch" to get all patches in a single download. You will find out-of-tree version, device-specific dtso and latest display-service in the https://github.com/jefflessard/tm16xx-display/tree/v4-feedback branch. Thanks to all of you for you help so far! 0 Quote
dale Posted Tuesday at 06:50 AM Posted Tuesday at 06:50 AM @Jean-Francois Lessard sorry for making you confused. Device tree source for tm16xx driver that I convert from a working openvfd.conf is below /dts-v1/; /plugin/; #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/leds/common.h> &{/} { display_client: spi { #address-cells = <1>; #size-cells = <0>; compatible = "spi-gpio"; sck-gpios = < 7 GPIO_ACTIVE_HIGH>; mosi-gpios = < 2 GPIO_ACTIVE_HIGH>; cs-gpios = < 12 GPIO_ACTIVE_LOW>; num-chipselects = <1>; display@0 { compatible = "fdhisi,fd628"; reg = <0>; spi-3wire; spi-lsb-first; spi-max-frequency = <500000>; digits { #address-cells = <1>; #size-cells = <0>; 01 02 03 04 }; leds { #address-cells = <2>; #size-cells = <0>; led@{GRID0},0 { reg = <{GRID0} 0>; function = "apps"; }; led@{GRID1},1 { reg = <{GRID1} 1>; function = "setup"; }; led@{GRID2},2 { reg = <{GRID2} 2>; function = LED_FUNCTION_USB; }; led@{GRID3},3 { reg = <{GRID3} 3>; function = LED_FUNCTION_SD; }; led@{GRID4},4 { reg = <{GRID4} 4>; function = "colon"; }; led@{GRID5},5 { reg = <{GRID5} 5>; function = "hdmi"; }; led@{GRID6},6 { reg = <{GRID6} 6>; function = "video"; }; }; }; }; }; The convert script I downloaded from this commit https://github.com/jefflessard/tm16xx-display/blob/a93b257ed4c73780fcdefbb1f1dd189599cf6ecc/vfdconf-convert Can you please help get it to work? Thanks! 0 Quote
Jean-Francois Lessard Posted Tuesday at 12:43 PM Author Posted Tuesday at 12:43 PM @dale it seems like vfd-convert has not worked well. Perhaps because of some mix between script version and the template files version. Whatsoever, I've looked closer at the patch link you previously posted, this is the older pre-review dt-bindings syntax. You should be go to start with something like: /dts-v1/; /plugin/; #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/leds/common.h> &{/} { display_client: spi { #address-cells = <1>; #size-cells = <0>; compatible = "spi-gpio"; sck-gpios = <&gpio 7 GPIO_ACTIVE_HIGH>; mosi-gpios = <&gpio 2 GPIO_ACTIVE_HIGH>; cs-gpios = <&gpio 12 GPIO_ACTIVE_LOW>; num-chipselects = <1>; display@0 { compatible = "fdhisi,fd628"; reg = <0x0>; spi-3wire; spi-lsb-first; spi-rx-delay-us = <1>; spi-max-frequency = <500000>; titanmec,digits = [00 01 02 03]; titanmec,segment-mapping = [03 01 02 06 04 05 00]; #address-cells = <2>; #size-cells = <0>; led@4,0 { reg = <4 0>; function = LED_FUNCTION_ALARM; }; led@4,1 { reg = <4 1>; function = LED_FUNCTION_USB; }; led@4,2 { reg = <4 2>; function = "play"; }; led@4,3 { reg = <4 3>; function = "pause"; }; led@4,4 { reg = <4 4>; function = "colon"; }; led@4,5 { reg = <4 5>; function = LED_FUNCTION_LAN; }; led@4,6 { reg = <4 6>; function = LED_FUNCTION_WLAN; }; }; }; }; Note that I haven't tested it, just made it from some copy-paste. If it doesn't work, even partially, you would most likely need to replace &gpio with the right reference to the gpio controller wired to the display. 0 Quote
dale Posted Wednesday at 10:58 PM Posted Wednesday at 10:58 PM Hi, thanks for checking. I check dmesg -T | grep spi_gpio and see the error spi_gpio spi: probe with driver spi_gpio failed with error -22. Also the /sys/class/leds is empty. Do you think the gpio pins are not correct? Below are current gpio pins I try this time mosi-gpios = <&pio 2 11 GPIO_ACTIVE_HIGH>; /* PC11 = data */ sck-gpios = <&pio 2 12 GPIO_ACTIVE_HIGH>; /* PC12 = clock */ cs-gpios = <&pio 7 5 GPIO_ACTIVE_LOW>; /* PH5 = strobe/latch */ 0 Quote
Jean-Francois Lessard Posted Wednesday at 11:35 PM Author Posted Wednesday at 11:35 PM @dale looking at the openvfd_x98h.dtso file you shared, openvfd uses these pins: openvfd_gpio_clk = <&pio 2 7 0>; openvfd_gpio_dat = <&pio 2 2 0>; openvfd_gpio_stb = <&pio 2 12 0>; So you should try with their equivalent: mosi-gpios = <&pio 2 2 GPIO_ACTIVE_HIGH>; /* mosi is the same as openvfd_gpio_dat */ sck-gpios = <&pio 2 7 GPIO_ACTIVE_HIGH>; /* sck is the same as openvfd_gpio_clk */ cs-gpios = <&pio 2 12 GPIO_ACTIVE_LOW>; /* cs is the same as openvfd_gpio_stb */ 0 Quote
dale Posted 6 hours ago Posted 6 hours ago (edited) Hi, I finally got my display to work with below DT overlay source. My device is x98h. Thank you! /dts-v1/; /plugin/; #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/leds/common.h> &{/} { display_client: spi { #address-cells = <1>; #size-cells = <0>; compatible = "spi-gpio"; sck-gpios = <&pio 2 7 GPIO_ACTIVE_HIGH>; mosi-gpios = <&pio 2 2 GPIO_ACTIVE_HIGH>; cs-gpios = <&pio 2 12 GPIO_ACTIVE_LOW>; num-chipselects = <1>; display@0 { compatible = "fdhisi,fd628"; reg = <0x0>; spi-3wire; spi-lsb-first; spi-rx-delay-us = <1>; spi-max-frequency = <500000>; tm16xx,transposed; tm16xx,digits = [00 01 02 03]; tm16xx,segment-mapping = [00 01 02 03 04 05 06]; #address-cells = <2>; #size-cells = <0>; led@4,0 { reg = <4 0>; function = LED_FUNCTION_USB; }; led@4,1 { reg = <4 1>; function = LED_FUNCTION_SD; }; led@4,2 { reg = <4 2>; function = "hi-wifi"; }; led@4,3 { reg = <4 3>; function = "low-wifi"; }; led@4,4 { reg = <4 4>; function = "colon"; }; led@4,5 { reg = <4 5>; function = "apps"; }; led@4,6 { reg = <4 6>; function = LED_FUNCTION_LAN; }; }; }; }; Edited 6 hours ago by dale 0 Quote
dale Posted 6 hours ago Posted 6 hours ago On 9/2/2025 at 8:02 AM, Jean-Francois Lessard said: I am seeking help to test the latest tm16xx changes for the (hopefully) final upstreaming submittal. Can you make a patch for armbian? It will be easy for us to try. 0 Quote
Jean-Francois Lessard Posted 5 hours ago Author Posted 5 hours ago (edited) @dale I'm happy that it's now working! I'll add the x98h dtso to my devices library when I'll have some time (using the latest dt-bindings syntax). You can download the patch of the latest tm16xx version here: https://github.com/torvalds/linux/compare/master...jefflessard:linux:tm16xx.patch Let me know if the latest version works well for you and the updated x98h dtso (if you happen to do it before I have some time). I'll be glad to add you with Tested-by tag when submitting. Edited 5 hours ago by Jean-Francois Lessard 0 Quote
dale Posted 5 hours ago Posted 5 hours ago (edited) 4 minutes ago, Jean-Francois Lessard said: You can download the patch of the latest tm16xx version here: I gave this a try but no success. The structure of original source code doesn't match the one for armbian. It would be great if you could make a patch as in this link Edited 5 hours ago by dale 0 Quote
Jean-Francois Lessard Posted 5 hours ago Author Posted 5 hours ago (edited) Those are standard kernel patches. Do you mean Armbian build system does not support multiple patches in a single file? If so, you can download each of the 14 patches individually and then apply them. Or you can try reformatting the combined patch file as a single patch. Edited 5 hours ago by Jean-Francois Lessard 0 Quote
