matteobp Posted November 16, 2015 Posted November 16, 2015 I have a Banana PI M1+ with latest Armbian Jessie with 3.4.109 kernel. The dmesg contains many rows like this ones ... [ 1468.309084] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated). Use CAP_NET_ADMIN and alias netdev- instead. ... ... [ 2779.128724] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated). Use CAP_NET_ADMIN and alias netdev- instead. ... I tried to search on Google without success. Can someone help me please? Thanks.
Igor Posted November 17, 2015 Posted November 17, 2015 Is your system working normal? Which modules are you using beside defaults? What you get from: lsmod
matteobp Posted November 17, 2015 Author Posted November 17, 2015 The system seems to work without problem. This is the output of lsmod root@bananapi:~# lsmod Module Size Used by cpufreq_userspace 3524 0 spidev 6366 0 a20_tp 3365 0 8021q 18593 0 garp 6072 1 8021q stp 2032 1 garp llc 5365 2 stp,garp sunxi_ir 4037 0 hidp 17640 0 rfcomm 58686 0 hci_uart 25000 0 bluetooth 264185 5 hidp,hci_uart,rfcomm It happens after login in graphical environment (XFCE). I have checked dmesg with putty from another computer, and no such row until login. So I analyzed better my desktop, and I found out the problem: Network Monitor Applet (added by me together with other applets). I removed it and the message disappeared. Problem solved. Thanks for support. 1
