Thofer Posted August 19, 2024 Posted August 19, 2024 Hello, After facing multiple instabilities during previous week, I decided to completely reinstall my helios64 to a fresh image (bookworm) from the download section. But before doing that, I need some help/have some questions: Currently, I’m using emmc to host the system, how can I completely backup and restore the system on an sd-card (you know, just in case...) Does the current image (https://dl.armbian.com/helios64/Bookworm_current_minimal) already contains usb drivers from:and this dtb file: Does the process to install the new image on emmc is the same as the one documented on Kobol site? At the moment, I’m a little bit lost on how to proceed… Thanks a lot for your help. 0 Quote
ebin-dev Posted August 19, 2024 Posted August 19, 2024 (edited) Here is my backup script - it copies the content from the running system - emmc (/) in my case - to sd (/mnt/sd). (create the mount point on emmc if it does not exist: 'mkdir /mnt/sd') As you can see the UUID that starts with 87654321... corresponds to the sd card, and the UUID starting with 12345678... corresponds to emmc. Type 'blkid' to get the UUIDs of your devices and insert them into the script accordingly. Check that the script can be executed (chmod +x backup.sh), insert a formatted sd card (ext4) and let the script run. That`s it. # cat backup.sh #!/bin/bash # Check if user is root if [ $(id -u) != "0" ]; then echo "Error: You must be root to run this script." exit 1 fi cat > install-exclude <<EOF /dev/* /proc/* /sys/* /mnt/sd/* /mnt/ssd/* /mnt/usb/* /mnt/hd/* /run/* # /tmp/* # /root/* EOF exec 2>/dev/null umount /mnt/sd exec 2>&1 mount --uuid 87654321-5709-4000-91ac-099eeefe4685 /mnt/sd rsync -avxSE --delete --exclude-from="install-exclude" / /mnt/sd # change fstab sed -e 's/UUID=12345678-3e1b-4e01-a6be-9ee203b1b54f/UUID=87654321-5709-4000-91ac-099eeefe4685/g' -i /mnt/sd/etc/fstab sed -e 's/UUID=12345678-3e1b-4e01-a6be-9ee203b1b54f/UUID=87654321-5709-4000-91ac-099eeefe4685/g' -i /mnt/sd/boot/armbianEnv.txt umount /mnt/sd rm install-exclude echo "SD - done." Edited August 19, 2024 by ebin-dev 0 Quote
Thofer Posted August 19, 2024 Author Posted August 19, 2024 Hello, @ebin-dev : Thanks a lot for your script it is helping me a lot for the backup part. Can you confirm my guess: Now I have my system saved on the SD Card, I need to download the new system image follow the kobol wiki procedure (https://wiki.kobol.io/helios64/install/emmc/) In addition to that do I need to install the realtek driver r8152 copy the dtb from your post Thanks again for your help. 0 Quote
Solution ebin-dev Posted August 20, 2024 Solution Posted August 20, 2024 10 hours ago, Thofer said: download the new system image Download a new system image with linux 6.6.y, flash it to another sd card (just use etcher) and boot from it. I would recommend to copy the dtb from my post (for the 6.6 branch) and execute 'update-initramfs -u'. If you are using the 2.5G interface, replace the rtl firmware in /lib/firmware/rtl_nic. No need to install a new r8152 driver. You can then copy the system from sd to emmc using armbian-config (this also changes the bootloader on emmc) and boot from emmc. (If there are issues with the new bootloader installed on emmc, flash the following u-boot to emmc (linux-u-boot-edge-helios64_22.02.1_arm64) (see here).) 0 Quote
Thofer Posted August 21, 2024 Author Posted August 21, 2024 Everything went fine. At the moment, the system seems way more stable. 0 Quote
axel Posted January 10, 2025 Posted January 10, 2025 (edited) (message moved to a better suited topic) Edited January 10, 2025 by axel 0 Quote
