prahjister Posted June 7, 2017 Posted June 7, 2017 Can someone please test this img on Orange Pi Lite. 4gb sd card or larger You can use nmtui to connect to wifi Connect to wifi the point browser to port 5000 of the IP address to see if gui starts and doesn't have any issues. http://x.x.x.x:5000 Thank you for your help. login root password octoprint Full instructions here http://www.cnx-software.com/2017/07/11/how-to-use-octoprint-on-orange-pi-lite-board-amlogic-s905x-and-s912-tv-boxes/
ooaa Posted June 13, 2017 Posted June 13, 2017 Hi prahjister Thanks for the img file what is the Path to CuraEngine and can i use the camera come with orange pi late ? Thanks
B.K.O. Posted June 14, 2017 Posted June 14, 2017 I'm also very interested in the 5MP camera opi comes with there is alreadya guy that figured it out. http://sanchosk.blogspot.ro/2016/08/orange-pi-one-and-camera.html there is a forum post (that I'm not able to find at the moment) that makes it copy pastable but still there is no tut to combine all with Octo. This can be all scripted for !!!!!!armbian-config!!!!!!! instead of images. 1
ooaa Posted June 20, 2017 Posted June 20, 2017 Hi B K O I didn't manage to get camera work with Orange Pi Lite and if any one know how let us know. thanks
prahjister Posted June 21, 2017 Author Posted June 21, 2017 Sorry guys thanks for the reply. No Cura Engine on this build. It is really old so didnt see the need Camera does work. Dont recommend opi camera. Not very good. But to use usb camera. First plug in the camera. Go into settings and video adjust the one ip address from 10.0.0.40 to the IP address of your orange PI. Then under power button turn on the webcam Is anyone successfully using this for multiple days?
Luchador Posted June 26, 2017 Posted June 26, 2017 I just start Testing , so far great , I was able to start the device , connect to my network , reach oktoprint, so im close to a few Tests, only one point I didnt get working so far ( sorry im a rel beginner) how to set a fixed IP adress for the wifi connection ? br Thomas
pfeerick Posted June 26, 2017 Posted June 26, 2017 @prahjister Have you set up Avahi on that image? Just wondering if something like http://octoprint.local would work with your image, making IP addresses not necessary? Otherwise it's probably either setting a fixed address on your router, using (sudo) nmtui to configure the connection (assuming network manager is managing the connection) or some ugly /etc/network/interfaces edits.
Luchador Posted June 26, 2017 Posted June 26, 2017 octoprint.local is not working in mycase ( if that information is helping you) one more point i just find out, I could sucessfully connect to the printer now , but the webcam only show me webcamstream loading . Any idea for that Camera Point ? br Thomas
Luchador Posted June 26, 2017 Posted June 26, 2017 Thanks pfeerick the network point i could solve with your tip ( i not found the edit connectione before) so finaly I only not get my logitech webcam runnng, hope someone have an idea here too. tomorrow hope to test with a first print on it BR Thomas
ooaa Posted June 29, 2017 Posted June 29, 2017 I test the image for 10 days and so far everything work great i have one more question what is ( OctoPrint checkout folder path) so we can set auto plugin update. (Please configure the checkout folder of OctoPrint, otherwise this plugin won't be able to update it. ) thanks
prahjister Posted July 4, 2017 Author Posted July 4, 2017 Thank you so much for the feedback. This is for an article I am writing and will update and make it easier with full instructions. Also one for s905x box. Did you find wifi dropping periodically. I think I might have got a bad board. On 6/26/2017 at 9:19 AM, pfeerick said: @prahjister Have you set up Avahi on that image? Just wondering if something like http://octoprint.local would work with your image, making IP addresses not necessary? Otherwise it's probably either setting a fixed address on your router, using (sudo) nmtui to configure the connection (assuming network manager is managing the connection) or some ugly /etc/network/interfaces edits. Expand I will setup avahi as well. Thank yoy Also sorry for ling time between reply. I didn't have notifications setup properly
manuti Posted July 11, 2017 Posted July 11, 2017 Here you can find more about this: http://www.cnx-software.com/2017/07/11/how-to-use-octoprint-on-orange-pi-lite-board-amlogic-s905x-and-s912-tv-boxes/
ooaa Posted July 13, 2017 Posted July 13, 2017 Hi I have one issue some time when i start print my printer restart randomly
prahjister Posted July 15, 2017 Author Posted July 15, 2017 On 7/13/2017 at 3:00 PM, ooaa said: Hi I have one issue some time when i start print my printer restart randomly Expand I had one do that as well until i changed my usb cable. I used a shorter one and it resolved the issue 1
George Chrysostomos Posted March 5, 2018 Posted March 5, 2018 Hi I am. Using octoprint with orange pi lite. I encountered some freeze in middle print, no particular reason, but I think is freezing if for some reason you restart your rooter
